I’m new to Linux/Manjaro(Plasma). When using FireFox it starts lagging after about 150-200 tabs are opened across multiple windows, which is about 10-12g of used RAM out of 32g. I didn’t have this issue with FireFox when using Windows (21g RAM) or MacOS(8g RAM). Is there a way to fix this or do I need to use a different Web Browser or do I need to use a different Manjaro desktop environment? Not being able to have 200+ tabs open is a detriment to my use-case. I mainly use firefox for privacy and addons like ublock, sessions manager, open bookmarks slowly, ect… If any other information is needed I’m more than glad to post it. As of now there have been no error messages, that I’m aware of.
inxi -Fanzy (this command was done after FireFox started to lag. At this point 223 tabs are open across 35 windows)
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8d08b34a-88e0-4761-82ea-a44bc8345f62 rw quiet splash
resume=UUID=d3e555bb-45ab-4029-bc76-e6f3c7ee1c27 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8P67 DELUXE v: Rev 1.xx
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 1503 date: 03/11/2011
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3699 high: 3700 min/max: 1600/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3700 2: 3700 3: 3700
4: 3699 bogomips: 26409
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GF100 [GeForce GTX 470] driver: nouveau v: kernel non-free:
series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157
kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: lanes: 16
ports: active: HDMI-A-1 empty: DVI-I-1,DVI-I-2 bus-ID: 01:00.0
chip-ID: 10de:06cd class-ID: 0300 temp: 52.0 C
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NVC0 device-ID: 10de:06cd
memory: 1.2 GiB unified: no display-ID: :1.0
vendor: ASUSTeK P8P67 Deluxe driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF100 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0be5 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: a000 bus-ID: 0f:00.0
IF: enp15s0 state: down mac: <filter>
Info: services: NetworkManager,wpa_supplicant
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.5:3 chip-ID: 8087:0032
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 5.46 TiB used: 169.24 GiB (3.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD4003FZEX-00Z4SA0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
ID-1: / raw-size: 896.76 GiB size: 881.61 GiB (98.31%) used: 13.69 GiB (1.6%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 34.46 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 52.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Memory: total: 32 GiB available: 31.33 GiB used: 12.81 GiB (40.9%)
Processes: 283 Power: uptime: 1h 28m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 12.52 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1194 libs: 361 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
