As the title suggests, I am trying to enable hardware virtualization.
I know this is simple, so can someone simply tell me how?
If your CPU supports it, you can enable it in your BIOS settings.
Thing is, it’s already a virtual machine, and I’m trying to virtualize a pc on a virtualized pc.
Hardware refers to something physical. A virtualized OS needs a physical machine to run it on.
Are you talking about something like running a virtualbox whithin a virtualbox?
Yeah, like @omano posted lol…
Tthis is way over my head.
Yeah, I’m going to commit virtualboxception.
Then look at some answers here maybe? virtual machine inside virtual machine - Ø¨ØØ« Googleâ
Technically possible on specific hardware/software.
Ok so I have done it.
I just had to go into the settings of the VM > System > Processor > Enable Nested VT- /AMD-V
