On CoreCTRL Setup page it give incomplete nstructions on creating a file and add a code. I am not sure using the command sudo mkdir is the best choice and don’t know how to edit the file. I think it may be using nano but I am not sure.
Then it have instructions to have Full AMD GPU controls but on those I am even more lost. I am on Manjaro KDE.
$ inxi -Fxxxz
System: Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: X570 Steel Legend serial: <filter> UEFI: American Megatrends v: P2.20
date: 11/26/2019
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 rev: 0 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115254
Speed: 4146 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4146 2: 3521 3: 3793 4: 4041 5: 3667
6: 4084 7: 3897 8: 4252 9: 4249 10: 4295 11: 3574 12: 4068 13: 4220 14: 4144 15: 4237 16: 3524
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: XFX Pine
driver: amdgpu v: kernel bus-ID: 10:00.0 chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon
alternate: fbdev,vesa resolution: 2560x1440~144Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.40.0 5.12.19-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.1
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 10:00.1
chip-ID: 1002:ab38 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f000 bus-ID: 0a:00.0 chip-ID: 8086:2526
class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-3:3 chip-ID: 8087:0025
class-ID: e001
Drives: Local Storage: total: 2.29 TiB used: 1.14 TiB (49.8%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 002C temp: 37.9 C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD20EZAZ-00GGJB0 size: 1.82 TiB speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0A80 scheme: GPT
Partition: ID-1: / size: 459.5 GiB used: 299.93 GiB (65.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 60.5 C mobo: N/A gpu: amdgpu temp: 54.0 C mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 700
Info: Processes: 415 Uptime: 37m wakeups: 0 Memory: 15.56 GiB used: 4.95 GiB (31.8%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1962 pacman: 1926 flatpak: 25 snap: 11 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
) if rules.d not exists , re-install
