How do I customize Pamac's update tray icon?
Hello, I’m trying to change Pamac’s tray icon because it’s bright red when I need to update, it doesn’t fit my plasma theme and I really don’t like it, and I don’t want to hide it, since I still want to be reminded to update. I searched up and figured that tray icons are customized in the Plasma theme, and I found the “icons” folder of my Plasma theme, but I’m not sure what I need to do from there. Do I need to make an icon and call it “pamac-tray-icon-plasma.svg” ? Or is it not possible to change it ? Thanks.
Disable update checking - remove the update-notifier package.
You could also install the package called pamac-tray-icon-plasma. That should make the icon follow your Icon theme. I’m using the Breath icons and it has the same icon as Discover has.
Can you answer the actual question? Which was how to change the icon. I for one would like to know cause with my Icon theme my Pamac icon is transparent.
Hello,
If you look at breath desktoptheme in /usr/share/plasma/desktoptheme/breath/icons/pamac.svgz and open the file in inkscape, you will see there are 4 icons, 2 of the same, at different sizes:
1 32x32 pixels with the xml ID pamac-tray-no-update
1 22x22 pixels with the xml ID 22-22-pamac-tray-no-update
then the second, for when there are updates:
1 32x32 pixels with the xml ID pamac-tray-update
1 22x22 pixels with the xml ID 22-22-pamac-tray-update
Those are arranged in groups, so inside the second one, the circle has the xml class ColorScheme-Highlight or ColorScheme-Negative Text depending on the update you have installed; and has the xml style fill:currentColor; - or something else depending again on the udpate you have, that might perfectly follow the current color-scheme you use (but the Negative text color was always the same, so was not changed previously)
This svgz files must have the type set to text/css and the style id set to current-color-scheme and this has to contain embedded color codes like this:
      .ColorScheme-Text {
        color:#7B7C7E;
      .ColorScheme-Background {
        color:#eff0f1;
      .ColorScheme-Highlight {
        color:#3daee9;
      .ColorScheme-ViewText {
        color:#31363b;
      .ColorScheme-ViewBackground {
        color:#fcfcfc;
      .ColorScheme-ViewHover {
        color:#93cee9;
      .ColorScheme-ViewFocus{
        color:#3daee9;
      .ColorScheme-ButtonText {
        color:#31363b;
      .ColorScheme-ButtonBackground {
        color:#eff0f1;
      .ColorScheme-ButtonHover {
        color:#93cee9;
      .ColorScheme-ButtonFocus{
        color:#3daee9;
Those will change when the color-scheme is changed from Settings. Once you edited, save the file, restart the session …
That has two meanings:
  1. replace it with another already made to follow the Plasma guidelines (that almost needs no explanation and all can do it already)
  2. edit the svg/svgz and modify the file content and add your own design to it (not easy to explain in a row as i did above without missing probably a lot of important stuff)
So, i hope this will help Guidelines and HOWTOs/Icon Workflow Tips - KDE Community Wiki
and with particular example here https://develop.kde.org/docs/extend/plasma/theme/theme-details/
@anon89812132 Awesome, thanks for the detailed explanation!
This brings me to a question or maybe a change request. You say that pamac icon should follow the color scheme. It doesn’t in my case and I use Breath that follows color scheme. Shouldn’t it be yellow color as matray does?
pamac-tray-update as of now on my system states 2 conditions, one with a predefined red color: color:#da4453
<g
     transform="scale(1.4545455)"
     id="pamac-tray-update">
    <rect
       style="opacity:1;fill:none;fill-opacity:1;stroke:none;stroke-width:0.1;stroke-linecap:square;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
       id="rect4183"
       width="22"
       height="22"
       x="0"
       y="0" />
    <g
       transform="translate(3.4948031e-4,-4.4513406e-4)"
       id="g853">
      <path
         inkscape:connector-curvature="0"
         style="fill:currentColor"
         d="M 11.126953,3.0019531 C 9.2851776,2.9719906 7.4335432,3.5755063 5.921875,4.8164062 2.8985906,7.2983061 2.1145626,11.6125 4.0703125,15 L 3.2050781,15.5 5.5039062,16.482422 5.8027344,14 4.9375,14.5 C 3.2230001,11.5304 3.9082004,7.7655435 6.5585938,5.5898438 9.2089874,3.4141439 13.034664,3.4761283 15.613281,5.7363281 L 16.271484,4.984375 C 14.800746,3.6952251 12.968729,3.0319156 11.126953,3.0019531 Z M 16.494141,5.5195312 16.195312,8 17.0625,7.5 c 0.896607,1.5529689 1.131185,3.323632 0.777344,4.970703 0.320602,0.168764 0.618291,0.373397 0.880859,0.619141 C 19.259064,11.093388 19.024658,8.89995 17.927734,7 L 18.792969,6.5 Z M 11,6 7,10 h 2 v 5 h 3.144531 C 12.303295,14.394491 12.599063,13.848255 13,13.388672 V 10 h 2 z M 6.3847656,16.265625 5.7265625,17.017578 c 2.0663121,1.81119 4.8448035,2.380136 7.3632815,1.701172 -0.245353,-0.262183 -0.448572,-0.558857 -0.617188,-0.878906 -2.106154,0.453549 -4.372671,-0.0708 -6.0878904,-1.574219 z"
         class="ColorScheme-Text"
         id="path840" />
      <path
         style="color:#da4453;fill:currentColor;fill-opacity:1;stroke:none"
         d="m 16,13 a 2.9999907,2.9999907 0 0 0 -3,3 2.9999907,2.9999907 0 0 0 3,3 2.9999907,2.9999907 0 0 0 3,-3 2.9999907,2.9999907 0 0 0 -3,-3 z"
         class="ColorScheme-NegativeText"
         id="path842" />
    </g>
  </g>
Is the defined red color intended or is the following code obsolete duplicate/ old code?
      <path
         id="path842" />
Should it be changed? If I remove the color:#da4453 it should follow my color scheme right?
Apparently at some point i overwrite the icon from an older backup … not sure exactly, but once the package will be rebuild and then updated to all branches the change will take place. For now, you can edit the file in a text editor and add replace all whit this:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
   inkscape:version="1.2.1 (9c6d41e410, 2022-07-14)"
   sodipodi:docname="pamac.svgz"
   viewBox="0 0 32 32"
   height="32"
   width="32"
   version="1.1"
   id="svg4153"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:dc="http://purl.org/dc/elements/1.1/">
  <sodipodi:namedview
     inkscape:document-rotation="0"
     inkscape:current-layer="g845"
     inkscape:window-maximized="0"
     inkscape:window-y="3"
     inkscape:window-x="1923"
     inkscape:cy="-1.4915254"
     inkscape:cx="-44.466101"
     inkscape:zoom="5.3636365"
     showgrid="false"
     id="namedview9"
     inkscape:window-height="1047"
     inkscape:window-width="1914"
     inkscape:pageshadow="2"
     inkscape:pageopacity="0"
     guidetolerance="10"
     gridtolerance="10"
     objecttolerance="10"
     borderopacity="1"
     bordercolor="#666666"
     pagecolor="#ffffff"
     inkscape:showpageshadow="0"
     inkscape:pagecheckerboard="0"
     inkscape:deskcolor="#d1d1d1" />
  <metadata
     id="metadata4159">
    <rdf:RDF>
      <cc:Work
         rdf:about="">
        <dc:format>image/svg+xml</dc:format>
        <dc:type
           rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
        <dc:title />
      </cc:Work>
    </rdf:RDF>
  </metadata>
  <defs
     id="defs4157">
    <style
       id="current-color-scheme"
       type="text/css">
      .ColorScheme-Text {
        color:#7B7C7E;
        color:#eff0f1;
        color:#3daee9;
        color:#31363b;
        color:#fcfcfc;
        color:#93cee9;
        color:#3daee9;
        color:#31363b;
        color:#eff0f1;
        color:#93cee9;
        color:#3daee9;
      </style>
  </defs>
  <g
    <rect
       id="rect4183"
       width="22"
       height="22"
       x="0"
       y="0" />
    <g
       id="g853">
      <path
         id="path840" />
      <path
         style="fill:currentColor;"
         class="ColorScheme-Highlight"
         id="path842" />
    </g>
  </g>
  <g
     transform="matrix(1.4545455,0,0,1.4545455,0,-32.000001)"
     id="pamac-tray-no-update">
    <rect
       y="0"
       x="0"
       height="22"
       width="22"
       id="rect855"
       style="opacity:1;fill:none;fill-opacity:1;stroke:none;stroke-width:0.1;stroke-linecap:square;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1" />
    <path
       d="M 11.127929,3.0014267 C 9.2861533,2.9714637 7.4345193,3.5749799 5.9228513,4.8158798 2.8995673,7.2977797 2.1155393,11.611974 4.0712893,14.999474 l -0.865235,0.5 2.298828,0.982422 0.298828,-2.482422 -0.865234,0.5 c -1.7145,-2.9696 -1.0293,-6.7344568 1.621094,-8.9101566 C 9.2099633,3.4136175 13.03564,3.4756019 15.614257,5.7358017 L 16.27246,4.9838486 C 14.801722,3.6946987 12.969705,3.0313892 11.127929,3.0014267 Z m 5.367188,2.5175781 -0.298829,2.4804688 0.867188,-0.5 c 1.7145,2.9696004 1.027347,6.7364104 -1.623047,8.9121094 -2.650394,2.1757 -6.4760697,2.113716 -9.0546867,-0.146484 l -0.658203,0.751953 c 2.941475,2.5783 7.3262717,2.649769 10.3496087,0.167969 3.023285,-2.4818 3.807312,-6.798047 1.851562,-10.1855474 l 0.865235,-0.5 z M 11.000976,5.9994736 7.0009763,9.999474 h 2 v 5 h 3.9999997 v -5 h 2 z"
       id="path867" />
  </g>
  <g
     id="22-22-pamac-tray-update"
     transform="translate(32.000001,10.000001)">
    <rect
       y="0"
       x="0"
       height="22"
       width="22"
       id="rect838"
    <g
       id="g845"
       transform="translate(3.4948031e-4,-4.4513406e-4)">
      <path
         id="path841"
         inkscape:connector-curvature="0" />
      <path
         id="path843"
    </g>
  </g>
  <g
     id="22-22-pamac-tray-no-update"
     transform="translate(32.000001,-22)">
    <rect
       id="rect849"
       width="22"
       height="22"
       x="0"
       y="0" />
    <path
       id="path851"
  </g>
</svg>
If is not what you propose, let me know and will take another look when i get some more time.
Many thanks for the great work!
It’s nothing mission critical, just an observation, so I will wait on my system for the update but will definitely try your coding on a VM.
@anon89812132 Coding above looks fine for me.
Many thanks again!!
Edit: Other users might not like it with accent color and would prefer it as it is with a red dot. It's up to Manjaro team how it should behave in standard out of the box. It's fine both ways.
