On my other laptop I had the same problem as described here I don’t use this driver anymore. I now use the video-nvidia-390xx driver and have no switch driver installed.
Here is my lspci -v | grep -E 'VGA|3D'
01:00.0 VGA compatible controller: NVIDIA Corporation GF104GLM [Quadro 4000M] (rev a1) (prog-if 00 [VGA controller])
And here is my inxi -G
Device-1: NVIDIA GF104GLM [Quadro 4000M] driver: nvidia v: 390.154
Device-2: Chicony Integrated HP HD Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: nvidia gpu: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: Quadro 4000M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
So now my DPI is to big and when I change the DefaultDepht
in section Screen
of the config file: /etc/X11/mhwd.d/nvidia.conf
from 24 to 20 I get A black screen after booting from grub. I solve this by going in to the rescue terminal (Ctrl+alt+f2) I reinstall the graphics card driver via mhwd.
So my question is where do I change my DPI? Or is that even possible since my graphics card is old and has to have legacy drivers in order to work.
I’m also currently working on an other problem because my Intel graphics driver isn’t showing up. So just to provide enough information here is my: inxi -Faz:
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e817a2de-5865-4464-a8c7-699536c78f21 rw quiet
resume=UUID=d5291e4f-366e-4c90-beb4-d46c1e4dd94c udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8760w
v: A0001D02 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1630 v: KBC Version 01.39
serial: <superuser required> UEFI: Hewlett-Packard v: 68SAD Ver. F.23
date: 01/18/2012
ID-1: BAT0 charge: 59.3 Wh (95.2%) condition: 62.3/62.3 Wh (100.0%)
volts: 16.4 min: 14.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: N/A
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 969 high: 1391 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 985 3: 798
4: 798 5: 924 6: 798 7: 1260 8: 1391 bogomips: 36735
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GF104GLM [Quadro 4000M] vendor: Hewlett-Packard
driver: nvidia v: 390.154 alternate: nouveau,nvidia_drm non-free:
series: 390.xx+ status: legacy-active (EOL~late 2022) arch: Fermi
code: GF1xx process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0e3b class-ID: 0300
bus-ID: 2-1.4:4 chip-ID: 04f2:b230 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 128 s-size: 381x211mm (15.00x8.31")
s-diag: 436mm (17.15")
Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 128
size: 381x214mm (15x8.43") diag: 437mm (17.2") modes: N/A
direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0beb class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 5020 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 25:00.0 chip-ID: 8086:4238
class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-3: HP hs2340 HSPA+ mobile broadband type: USB
driver: cdc_acm,cdc_ncm,cdc_wdm bus-ID: 1-1.2:4 chip-ID: 03f0:3a1d
class-ID: 0202 serial: <filter>
IF: enp0s26u1u2i6 state: down mac: <filter>
Device-1: HP Broadcom 2070 Bluetooth Combo type: USB driver: btusb v: 0.8
bus-ID: 2-1.6:5 chip-ID: 03f0:231d class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 704.24 GiB used: 22.24 GiB (3.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7PC256HAFU-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5H1Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500VT000-1DK142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: MBC1
scheme: GPT
ID-1: / raw-size: 221.06 GiB size: 216.53 GiB (97.95%) used: 22.24 GiB
(10.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 64 C
Processes: 237 Uptime: 27m wakeups: 3 Memory: 15.56 GiB used: 1.63 GiB
(10.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1360 pm: pacman pkgs: 1355
libs: 324 tools: pamac,yay pm: flatpak pkgs: 5 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
I’ve also tried changing /etc/sddm.conf
to enable HiDPI
on line 30 and 38. But this didn’t do anything.
So I’ve started searching on the Arch forum to look for any other apply able options and found this thread. Which looks A lot to my older fix when I encounter the same problem. Because I needed to change the variable of the line Option "DPI" "96x96"
in the /etc/X11/xorg.conf.d/20-nvidia.conf
file.
But this installation of Manjaro doesn’t have that config file for some reason. Here is my ls
of /etc/X11/xorg.conf.d/
>> 00-keyboard.conf 30-touchpad.conf 90-mhwd.conf
. As you can see there is no nvidia.conf file in this directory. And now I’m clueless of where I need to add the Option "DPI" "96x96"
or where to change that variable.
