I’m a new guy with manjaro, how do I get my wallpaper to randomly change. I did it before but I can’t remember.
Thanks
Thanks
It would be good to know what DE you are using. If you are unsure please post the output of inxi -S --no-host
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.14.2
Distro: Manjaro Linux
Thanks for replyijng
To simply change wallpapers: Right click on the desktop and click on Desktop Settings . Choose Background from the folder option, and choose any one of the default backgrounds or a custom one.
To set up cycling wallpapers: You can enable this option by checking the Change the background box. The frequency in which the images are changed and the order in which they are chosen can be changed by selecting an interval period from the drop-down list and optionally selecting the Random Order checkbox.
Thank you all!!!
I feel so silly seeing the simplicity of the answer. The fact that you took the time shows just how kind you all are.
He seemed like a new user, so he could had been using the most recent July 2020 build of inxi. From what I had observed in the manual included with that build, this is mentioned:
inximanual, July 26th 2020, line 585-592 (reformatted, with emphasis):
-z,--filter: Adds security filters for IP addresses, serial numbers, MAC, location (-w), and user home directory name. RemovesHost:. On by default for IRC clients.
So, couldn’t he had just done inxi -Sz instead? Or am I just being smooth brain and not seeing a difference between Host: and Hostname?
Kernel: 5.8.1-arch1-1 x86_64 bits: 64 Desktop: GNOME 3.36.5
nothing wrong in asking for that
They are saying that it’s easier to type inxi -Sz instead of inxi -S --no-host
Check this out. Output with -z is much cleaner.
https://www.diffchecker.com/kwYm9BaC
I know… i need learn more english , sorry mistake i made
