Hi guys. I reinstalled linux to a newer version. And I want to add CoreCtrl (software for AMD video cards - https://gitlab.com/corectrl/corectrl) to the autostart. But I can’t find the GUI for autostart. I tried this way: "System Settings → Workspace → Window Management → Window Rules → Add New" but this attempt failed.
System
sudo neofetch
██████████████████ ████████ master@PC
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: OPTIMUS OPTIMUS E-Sport GB550-CR3
████████ ████████ Kernel: 6.1.22-1-MANJARO
████████ ████████ ████████ Uptime: 6 mins
████████ ████████ ████████ Packages: 1232 (pacman)
████████ ████████ ████████ Shell: zsh 5.9
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: GNOME 43.4
████████ ████████ ████████ WM: Mutter
████████ ████████ ████████ WM Theme: CustomAccentColors
████████ ████████ ████████ Theme: Adw-dark [GTK2/3]
████████ ████████ ████████ Icons: Papirus-Dark-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 5 3600 (12) @ 3.600GHz
GPU: AMD ATI Radeon RX 6400/6500 XT/6500M
Memory: 3280MiB / 15900MiB
Kernel: 6.1.22-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c07fd6aa-bf43-452e-8f08-1e9f6e8343b5 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: ATs product: OPTIMUS v: OPTIMUS E-Sport GB550-CR3
serial: <filter> Chassis: OPTIMUS type: 3 v: OPTIMUS E-Sport GB550-CR3
serial: <filter>
Mobo: Gigabyte model: B550 GAMING X V2 v: 2022-03-07 serial: N/A
UEFI: American Megatrends LLC. v: F14 date: 01/04/2022
RAM: total: 15.53 GiB used: 3.52 GiB (22.7%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMK8GX4M1D3000C16
serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: N/A
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2200 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: ondemand
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 86287
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 24 [Radeon RX 6400/6500 XT/6500M] vendor: Sapphire PULSE
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1 bus-ID: 09:00.0 chip-ID: 1002:743f
class-ID: 0300
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: amdgpu note: X driver n/a display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung LS24AG30x
serial: <filter> built: 2022 res: 1920x1080 hz: 144 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon RX 6500 XT (navi24
LLVM 15.0.7 DRM 3.49 6.1.22-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.22-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB
driver: r8188eu bus-ID: 1-2:3 chip-ID: 2357:010c class-ID: 0000
serial: <filter>
IF: wlp4s0f0u2 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 894.27 GiB used: 22.6 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM22.7 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: B1H5 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: 62B3 scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 21.52 GiB (37.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: c07fd6aa-bf43-452e-8f08-1e9f6e8343b5
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: A610-701A
ID-3: /home raw-size: 387.95 GiB size: 380.79 GiB (98.16%)
used: 1.07 GiB (0.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: 70bcd36f-f478-4563-901a-5955c30803f2
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: \xd0\x97\xd0\xb0\xd1\x80\xd0\xb5\xd0\xb7\xd0\xb5\xd1\x80\xd0\xb2\xd0\xb8\xd1\x80\xd0\xbe\xd0\xb2\xd0\xb0\xd0\xbd\xd0\xbe \xd1\x81\xd0\xb8\xd1\x81\xd1\x82\xd0\xb5\xd0\xbc\xd0\xbe\xd0\xb9
uuid: EC86DA3F86DA09CA
ID-2: /dev/sda2 maj-min: 8:2 size: 222.99 GiB fs: ntfs label: N/A
uuid: 4EF8F17FF8F1659D
ID-3: /dev/sda3 maj-min: 8:3 size: 541 MiB fs: ntfs label: N/A
uuid: 568641EC8641CD65
ID-4: /dev/sdb1 maj-min: 8:17 size: 223.57 GiB fs: ntfs label: Disk1
uuid: 4096BDEF7F8C83A3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 1-2:3 info: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
type: Network driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 2357:010c class-ID: 0000 serial: <filter>
Device-3: 1-3:4 info: Integrated Express RGB LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 048d:5702 class-ID: 0300
Device-4: 1-5:5 info: A4Tech USB Device type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 09da:7466 class-ID: 0300
Device-5: 1-6:6 info: Evision GK630 Gaming Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 3299:4e5a class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.6 C mobo: 27.0 C gpu: amdgpu temp: 34.0 C
mem: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1769
Processes: 340 Uptime: 13m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1232 libs: 324 tools: gnome-software,pamac pm: flatpak pkgs: 0
Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.26
