Hello. I need to use a kernel with some patches applied and I have no experience with it at all. I do have the patches in .patch format.
I am following this guide, pulling the 5.12 kernel from the Manjaro repository. I’m using that guide because it is my understanding that it is the easier/better way to do it in Manjaro.
I’m adding my patches as 1000-mypatch1.patch
, 1001-mypatch2.patch
, and so on, to the root of the local linux512
repository, and then running makepkg -s
as the guide stated. This is still running, it seems to take a very long time.
(Edit: I just learned I need to add the .patch
files to the PKGBUILD
file and run updpkgsums
before they are in effect. I also need to do makepkg -Cs
so it will remove the previous build before attempting a new one. Correct me if I’m wrong here.)
I’m stumped as to what to do after this.
- How do I add this Kernel to the grub menu with a custom name as to differentiate it from the official Manjaro kernels that are kept up-to-date by the system?
- How do I update it later, do I just
git pull
,makepkg -s
and install it over? - How do I uninstall it if I don’t want to have it on the menu anymore?
- Will it get overwritten by updates from Manjaro?
- How do I keep it as the default boot option even if Manjaro updates the official kernels?
Any guidance is appreciated. I just don’t want to break anything and be able to revert it if something goes wrong.
