Hi All
I want to change my scheduler to deadline.
I tried to create new file to two place below.
/etc/udev/rules.d/60-ioschedulers.rules
/etc/udev/rules.d/60-schedulers.rules
And tried two commands below, but all doesn’t work.
ACTION==“add|change”, KERNEL==“sd[a-z]”, ATTR{queue/rotational}==“0”, ATTR{queue/scheduler}=“deadline”
ACTION==“add|change”, KERNEL==“sd[a-z]|mmcblk[0-9]|nvme[0-9] ”, ATTR{queue/rotational}==“0”, ATTR{queue/scheduler}=“mq-deadline”
Which one is correct? Thank you.
that is the corect path
and this is the correct way to do have it in the file
# set deadline scheduler for non-rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="mq-deadline"
# set bfq scheduler for rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="bfq"
# set mq-deadline scheduler for non-rotating nvme-disks
ACTION=="add|change", KERNEL=="nvme[0-9]n1", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="mq-deadline"
Thank you.
When I done, and reboot.
But the system showed “[mq-deadline] kyber bfq none”.
My system still no changed to deadline. Why?
xabbu
14 August 2021 11:46
4
You are using mq-deadline
, which is deadline
for multiqueue. Keep in mind that the original deadline
is not available with multiqueue. If you don’t want to use multiqueue you would need to use an old Linux Kernel.
system
Closed
15 August 2021 11:46
5
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
