I installed wine and a few apps under wine.
Then I decided to uninstall wine and all what I installed under it.
I did it throw the “Add/Remove Software” and uninstalled wine, removed “orphans” then rebooted.
Now:
Hi @Aragorn
I am on:
Branch: Stable
Desktop Environment: KDE
CPU: Processors: 4 × Intel® Core™ i5-3210M CPU @ 2.50GHz
GPU: Mesa DRI Intel® HD Graphics 4000
Kernel: 5.15.32-1-MANJARO
Log out of Plasma completely — you have to be looking at the login screen — and then press Ctrl+Alt+F3. Log in as yourself with your user name and password. Then issue the following commands…
rm -rf .wine
rm -rf .cache/*
exit
Now press Alt+F1 and log back into Plasma. The menu entries should now be gone.
I logged out and did the commands.
Nothing changed!
Though
Seemed to be deleting lots of files (I guess so as I noticed it took a second to get get the cursor after finishing.
Then I deleted the wine files and folders as @megavolt
