How can I switch to Nouveau? (dual-seat)
I have a dual-seat system. When I try to apply the latest update, only seat 0 works afterwards. Seat 1 remains black.
Seat 0 has an AMD graphics, seat 1 has an Nvidia graphics card.
nvidia-driver-assistant
Detected GPUs:
  NVIDIA GeForce GTX 1050 Ti - (pci_id 0x1C82)
Detected system:
  Manjaro Linux
Please copy and paste the following command to install the legacy kernel module flavour:
  sudo pacman -S linux618-nvidia-580xx
inxi -zv8
  Kernel: 6.18.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=cd556c7c-28ab-4b2e-b08b-02a18221390a rw rootflags=subvol=@
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x serial: <filter>
    part-nu: SKU uuid: d7dbc013-28af-7b9b-4efd-bcfce78dbade Firmware: UEFI
    vendor: American Megatrends v: 3634 date: 09/10/2025
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
    status: discharging
  System RAM: total: 32 GiB available: 30.64 GiB used: 2.56 GiB (8.4%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3200C16-16GIS serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:01.1
    children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1 class-ID: 0403
    type: audio
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 4 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics socket: AM4 bits: 64
    type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500014
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2393 min/max: 422/4674 boost: enabled
    base/boost: 3800/4650 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 2393 2: 2393 3: 2393 4: 2393
    5: 2393 6: 2393 7: 2393 8: 2393 9: 2393 10: 2393 11: 2393 12: 2393
    13: 2393 14: 2393 15: 2393 16: 2393 bogomips: 121364
    xsaves xtopology
    affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
    v: 580.119.02 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-2
    empty: DVI-D-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 01:00.0
    chip-ID: 10de:1c82 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: DP-1 empty: HDMI-A-1 bus-ID: 08:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 32.0 C
  Display: unspecified server: X.org v: 1.21.1.21 compositor: xfwm4
    v: 4.20.0 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch
    display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: DP-1 model: LG (GoldStar) Ultra HD serial: <filter> built: 2018
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1600x900, 1280x1024, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x480, 640x480
  Monitor-2: DP-2 model: LG (GoldStar) HDR 4K serial: <filter> built: 2020
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
    x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    renoir ACO DRM 3.64 6.18.2-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no
    gpu: nvidia-settings,nvidia-smi x11: xprop
  Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
    bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Jieli UACDemoV1.0 driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.4:5 chip-ID: 4c4a:4155
    class-ID: 0102 serial: <filter>
  API: ALSA v: k6.18.2-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.82 TiB used: 305.3 GiB (16.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
    model: EXCERIA PLUS G3 SSD size: 1.82 TiB block-size: physical: 512 B
    fw-rev: ELFA01.2 temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 900 GiB size: 900 GiB (100.00%) used: 305.3 GiB (33.9%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
    label: manjaro25 uuid: cd556c7c-28ab-4b2e-b08b-02a18221390a
  ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
    used: 8.6 MiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 7B77-AD5F
  ID-3: /home raw-size: 900 GiB size: 900 GiB (100.00%)
    used: 305.3 GiB (33.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
    maj-min: 259:3 label: manjaro25 uuid: cd556c7c-28ab-4b2e-b08b-02a18221390a
  ID-4: /var/cache raw-size: 900 GiB size: 900 GiB (100.00%)
  ID-5: /var/log raw-size: 900 GiB size: 900 GiB (100.00%)
  ID-1: swap-1 type: partition size: 50 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: swap
    uuid: 34d8f1dc-84ce-4101-b7d5-394f8024e854
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 40 GiB fs: btrfs label: N/A
    uuid: 263d1186-0f94-4a14-b2f7-191140536109
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 869.02 GiB fs: btrfs
    label: manjaro26 uuid: ec9c739c-c626-4379-91ad-acf07f20b95d
  Hub-2: 1-1:2 info: Manufacturer hub ports: 4 rev: 2.0
    chip-ID: 0a05:7211 class-ID: 0900
  Device-1: 1-1.1:5 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
    vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
  Device-2: 1-1.2:6 info: MosArt Wireless Keyboard/Mouse
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 062a:4101 class-ID: 0301
  Device-3: 1-1.3:7 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-4: 1-1.4:8 info: Xenta 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d57:fa23 class-ID: 0301
  Device-5: 1-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-3: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-2:2 info: Genesys Logic SD Card Reader and Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 3-2:2 info: Transcend Information microSD/SD/CF UHS-II Card Reader
    [RDF8 RDF9] ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 8564:4000 class-ID: 0900
  Device-1: 3-2.1:3 info: QinHeng CH340 serial converter
    type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
    chip-ID: 1a86:7523 class-ID: ff00
  Hub-7: 3-2.2:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-2.2.2:7 info: Logitech Unifying Receiver
  Device-2: 3-2.2.3:8 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
  Device-3: 3-2.4:5 info: Jieli UACDemoV1.0 type: audio
    driver: snd-usb-audio interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 4c4a:4155 class-ID: 0102
    serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 38.1 C mobo: N/A gpu: amdgpu temp: 32.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1742 libs: 392 tools: pamac,trizen pm: flatpak
    pkgs: 0
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    3: https://manjaro.kurdy.org/stable/$repo/$arch
    4: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 424
  1: cpu: 3.5% command: chromium pid: 3119 mem: 271.4 MiB (0.8%)
  2: cpu: 2.6% command: chromium pid: 2366 mem: 412.1 MiB (1.3%)
  3: cpu: 2.4% command: Xorg pid: 1310 mem: 139.2 MiB (0.4%)
  4: cpu: 1.6% command: chromium pid: 2817 mem: 165.1 MiB (0.5%)
  5: cpu: 1.0% command: xfdesktop pid: 2116 mem: 131.8 MiB (0.4%)
  Memory top: 5 of 424
  1: mem: 412.1 MiB (1.3%) command: chromium pid: 2366 cpu: 2.6%
  2: mem: 271.4 MiB (0.8%) command: chromium pid: 3119 cpu: 3.5%
  3: mem: 200.2 MiB (0.6%) command: lightdm-gtk-greeter pid: 1417 cpu: 0.9%
  4: mem: 165.1 MiB (0.5%) command: chromium pid: 2817 cpu: 1.6%
  5: mem: 139.2 MiB (0.4%) command: Xorg pid: 1310 cpu: 2.4%
  Processes: 424 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.13 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 258
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Zsh v: 5.9 running-in: kitty inxi: 3.3.40
So I rolled back (timeshift) and am now back to a working system with both seats. I’d like to switch to the Noveau driver before trying the update again.
What’s the best way to do that?
The best way is to uninstall anything Nvidia-related. nouveau is in the kernel, but if you have the proprietary driver installed, it’ll use that instead. So purge your system of anything Nvidia-related.
Manjaro Linux only provided 580 as rolling driver; the rolling driver is now at 590.
I think this means your nvidia-driver-assistant needs an update.
The current package version is 0.23.48.01-6
The current script will likely suggest linux618-nvidia-575xx but you could also use 570xx.
Because the linux618-nvidia is at 590.xx, this will make your 1050 unsupported and likely result in a black screen.
mhwd -r pci video-nvidia
mhwd -i pci video-linux
The 580xx driver may at some future point replace 570xx and 575xx if Nvidia manage to stablise it, after all it is their new legacybranch.
So i did:
trizen -R linux612-nvidia linux618-nvidia nvidia-settings nvidia-utils lib32-nvidia-utils
Fehler: Der Vorgang konnte nicht gestartet werden (Kann Datenbank nicht sperren)
Fehler: Datenbank konnte nicht gesperrt werden: Die Datei existiert bereits
  Wenn Sie sicher sind, dass nicht bereits ein
  Paketmanager läuft, können Sie /var/lib/pacman/db.lck entfernen
sudo rm /var/lib/pacman/db.lck
I think it has to do with the update notifier in the GUI, because this keeps happening to me.
trizen -R linux612-nvidia linux618-nvidia nvidia-settings nvidia-utils lib32-nvidia-utils nvidia-prime                                                   1 ✘  13s 
:: Pacman command: /usr/bin/sudo /usr/bin/pacman -R linux612-nvidia linux618-nvidia nvidia-settings nvidia-utils lib32-nvidia-utils nvidia-prime
Abhängigkeiten werden geprüft …
:: ffmpeg benötigt optional nvidia-utils: Nvidia NVDEC/NVENC support
:: ffmpeg4.4 benötigt optional nvidia-utils: Nvidia NVDEC/NVENC support
:: lib32-vulkan-icd-loader benötigt optional lib32-vulkan-driver: packaged vulkan driver
:: libvdpau benötigt optional nvidia-utils: driver for NVIDIA
:: sdl3 benötigt optional vulkan-driver: vulkan renderer
:: vulkan-icd-loader benötigt optional vulkan-driver: packaged vulkan driver
Pakete (6) lib32-nvidia-utils-580.119.02-1  linux612-nvidia-580.119.02-3  linux618-nvidia-580.119.02-3  nvidia-prime-1.0-5  nvidia-settings-580.119.02-2  nvidia-utils-580.119.02-2
Gesamtgröße der entfernten Pakete:  1355,22 MiB
After a reboot, seat1 is black again. The nouveau driver from the kernel doesn’t seem to understand that it’s supposed to take over. :frowning:
OK, this did not work.
trizen -S linux612-nvidia linux618-nvidia nvidia-settings nvidia-utils lib32-nvidia-utils nvidia-prime
This did not help to restore seat 1. I had to rolback again (thanks to btrfs and timeshift)
I would have used mhwd to remove the Nvidia stuff. :thinking:
My partner’s system has a GTX 970 (Maxwell) GPU using nvidia 470xx legacy driver
because 570xx 575xx drivers do not have a libxnvctl package for conky yet
$ mhwd -li
> Installed PCI configs:
    video-nvidia-470xx            2023.03.23               false            PCI
The rolling driver does not support your GPU and unless it is a laptop you have no use for nvidia-prime either.
Choose a legacy branch like the linux<kernel>-nvidia-570xx for this card.
I will try this:
maxi
maxi v0.7.27 (15.06.2025) for java 21
Currently running: 6.18.2-1-MANJARO (linux618)
 linux612 vmlinuz-6.12-x86_64 initramfs-6.12-x86_64.img=209M fallback=<none>
 linux618 vmlinuz-6.18-x86_64 initramfs-6.18-x86_64.img=305M fallback=<none>
Info about: /lib/modules
 modules612 6.12.63-1-MANJARO=245M <none>=
 modules618 6.18.2-1-MANJARO =251M <none>=
It seems that video-hybrid-amd-nvidia-prime is installed, because there is integrated AMD-graphics(seat0) and a dedicated nvidia-card(seat1)
sudo mhwd -r pci video-hybrid-amd-nvidia-prime
sudo mhwd -i video-linux
Error: invalid use of option: -i/--install
Error: because it seems to be already installed :wink:
:face_with_peeking_eye: because i forgot pci
reboot
This did work so far. seat1 is alive
:partying_face:
Now i have to update and reboot again.
Everything is fine now !
:+1:
No - the error is because you forgot the required pci argument.
In any case - I glad you got it working :slight_smile:
