I have an installation of snap just to use microk8s for work.
However, I seem to have no control as to when microk8s is running and it uses a lot of resources on my laptop. And running sudo systemctl stop snapd snapd.socket seems to not do anything with those services.
Does anyone know why?
And how can I configure them in a way that only when I start them, they actually run?
Use sudo systemctl disable --now snapd.socket to stop snapd to start on boot. You can start the service whenever you need by sudo systemctl start snapd.socket. I am not sure but you can also stop kubelet.service if there’s any
The above command not only stops them but also prevents them from starting automatically. You can then start them manually with…
systemctl start snapd.service snapd.socket
… whenever you need them, and you replace the start with stop for stopping them. You can even create an alias for that and add it to your ~/.bashrc or ~/.zshrc, depending on what shell you use.
alias startsnap="systemctl start snapd.service snapd.socket"
alias stopsnap="systemctl stop snapd.service snapd.socket"
Note: You will have to log out and back in in order for those aliases to take effect.
