Thank you so much for the help. At the beginning every bit of help matters a lot.
On Win10 I always used full disc encryption with Veracrypt with triple layer with Twofish+Serpent+AES+, mouse movemenet generated hash etc, so I was wanted this feature here on Linux as well and sadly it can be done only during install and I have no clue how to setup the Twofish and multi layer encryption etc here on Linux so for my its already a big downgrade with this plain American gov AES…
Its double or nothing in my eyes, if you encrypt than you do encrypt at ultimate level or you just dont do it at all otherwise whats the point if anyone can break it… if not today than years or a decade later…
Thanks for mentioning Clonezilla, I know that from 2010 or so when I used in on my Windows system and I loved it, had it on a Live CD! It worked flawlessly, but that is not automated process but a fully manual backup. I really want a fully auto recovery solution like Timeshift with its sophisticated schedule settings. Also, Clonezilla supports only LUKS2 not LUKS1 (if that matters to me) and doesnt support incremental but full backups only so its slow and a hassle to use it compared to Timeshift as far as I can tell yet based on forums and Youtube…
Finally I already successfully shrinked my oversized 38GB swap partition on this LVM LUKS setup by inactivating, unmounting it than resizing and after an hour of errors during boot I edited the fstab file based on Googling
Now I have 3GB swap only and it auto mounts without error. So I am happy with this for now and I did not have to reinstall the OS bec of this.
Timeshift is still an issue, It works perfectly with Rsync now for me, backuops are there after boots, per hour and per day and mount too. Btrfs backup is not working for me, it cannot sense my Btrfs volume on my root partition…
For teh LVM with LUKS part, I did not want it or stick to it as I do hate swap files in general and it was disabled on my Wion10 too qwith 16GB RAM and blazing fast Samsung OEM nvme SSD, but most forums and guides says that you must have a swap file or partion on Lunux systems if you wanna avoid troubles. While I also did read that swap file is NOW working within a LUKS after kernel 5.0+.
To answer your suggestion, now I am thinking on following that advice. So maybe I could just reinstall my Manjaro without the complicated LVM and set a swap file later within my main root partition, still have all (except boot) encraypted but can I still have it Btrfs for Timeshift and other possible advantages by time? If yes, I am reinstalling manjaro right away as you said. Juts to eliminate the LVM…? Whats the advantage of this now?
FYI:
There is an intzeresting link at: linux DOT com
training-tutorials/how-full-encrypt-your-linux-system-lvm-luks/
