Recently I have problems with VLC using ALSA that output only in stereo https://forum.manjaro.org/t/vlc-problem-with-ac-3-sound-in-videos/176960
To reset the sound to play surround I had to log out and log in. Is there a way to reset the sound staying in the session, so I do not have to reopen all programs etc. ?
I tried killall pipewire , but that did not bring the sound back even though pipewire and pipewire-pulse processes restarted. I had to restart the PC to bring everything in order.
Which command can I run to reset the sound?
$ sudo systemctl restart pipewire-session-manager
Failed to restart pipewire-session-manager.service: Unit pipewire-session-manager.service not found.
Failed to restart pipewire.service: Unit pipewire.service not found.
$ inxi -zv8
Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=c967ec04-7002-4176-a843-d0269a60e2e9 rw nowatchdog
mitigations=off security=none udev.log_priority=3 noresume nohibernate
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
BIOS: American Megatrends v: 4631 date: 01/14/2025
Device-1: hidpp_battery_0 model: Logitech M215 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.53 GiB used: 2.46 GiB (15.8%)
Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3000 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: G Skill Intl
part-no: F4-3000C16-16GISB serial: N/A
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: no module installed
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 1723 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1723 2: 1723 3: 1723
4: 1723 5: 1723 6: 1723 7: 1723 8: 1723 9: 1723 10: 1723 11: 1723 12: 1723
bogomips: 86398
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xtopology
Type: retbleed status: Vulnerable
Type: spec_rstack_overflow status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,DVI-D-1 bus-ID: 08:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 49.0 C
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1013x570mm (39.88x22.44")
s-diag: 1162mm (45.76")
Monitor-1: DP-3 model: Denon DENON-AVR serial: <filter> built: 2014 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 69 gamma: 1.2 chroma: red:
x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153 y: 0.071 white:
x: 0.282 y: 0.298 size: 708x398mm (27.87x15.67") diag: 918mm (36.1")
ratio: 16:9 modes: 1920x1080, 2880x576, 2880x480, 1280x720, 1440x576,
1440x480, 720x576, 720x480, 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary model: Philips FTV
serial: <filter> built: 2017 res: mode: 3840x2160 hz: 60 scale: 100% (1)
dpi: 68 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green: x: 0.325 y: 0.588
blue: x: 0.145 y: 0.051 white: x: 0.278 y: 0.290
size: 1440x810mm (56.69x31.89") diag: 1652mm (65") ratio: 16:9
modes: 1920x1080, 3840x2160, 1600x1200, 1680x1050, 1400x1050, 1280x1024,
1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 590 Series (radeonsi
polaris10 ACO DRM 3.61 6.14.0-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 590 Series (RADV POLARIS10) driver: mesa radv v: 25.0.3-arch1.1
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.3-arch1.1 (LLVM
19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0
class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 2.52 TiB used: 423.8 GiB (16.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00L5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MTFDDAK256MAY-1AH12ABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: M5T4 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800NS38
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 8B scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
used: 42.43 GiB (9.1%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: statroot
uuid: c967ec04-7002-4176-a843-d0269a60e2e9
ID-2: /data/ssd200 raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 16.45 GiB (7.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: ssd200
uuid: f94e8a24-3ec4-4edb-b49f-0d26ab9fef52
ID-3: /data/swdisk raw-size: 923.5 GiB size: 907.93 GiB (98.31%)
used: 364.53 GiB (40.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: swdisk
uuid: ed96f3d3-edea-43bc-8418-2223e4ec312d
ID-4: /home/<filter>/cryptomount.fredox.vol raw-size: 600 MiB
size: 573.7 MiB (95.62%) used: 405.4 MiB (70.7%) fs: ext4 dev: /dev/dm-1
maj-min: 253:1 mapped: loop0 label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: swap
uuid: be412c02-951e-41a3-b8d0-9ae75cdd1778
ID-1: /dev/sda2 maj-min: 8:2 size: 8.01 GiB fs: ext2 label: cryptswap
uuid: 51aca7eb-b9ff-40c3-81eb-05ac432f2d87
ID-2: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: hd1Tb
uuid: a0f67169-c4c3-48e9-bafe-a73dc0983560
Device-1: 1-7:2 info: Jing-Mold Enterprise 2.4G Dongle
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 05af:0906 class-ID: 0301
Device-2: 1-9:3 info: NZXT Smart Device V2 type: HID
driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2006 class-ID: 0300
serial: <filter>
Device-3: 1-10:4 info: Logitech Nano Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0617
System Temperatures: cpu: 50.5 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 770
Packages: pm: pacman pkgs: 1163 libs: 280 tools: pamac
1: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 325
1: cpu: 2.6% command: firefox pid: 34130 mem: 541.6 MiB (3.4%)
2: cpu: 1.8% command: firefox pid: 34538 mem: 296.7 MiB (1.8%)
3: cpu: 0.7% command: Xorg pid: 746 mem: 134.7 MiB (0.8%)
4: cpu: 0.7% command: firefox pid: 34531 mem: 248.9 MiB (1.5%)
5: cpu: 0.5% command: kwin_x11 pid: 990 mem: 240.7 MiB (1.5%)
Memory top: 5 of 325
1: mem: 541.6 MiB (3.4%) command: firefox pid: 34130 cpu: 2.6%
2: mem: 381.6 MiB (2.4%) command: plasmashell pid: 1044 cpu: 0.2%
3: mem: 314.7 MiB (1.9%) command: doublecmd pid: 3278 cpu: 0.4%
4: mem: 296.7 MiB (1.8%) command: firefox pid: 34538 cpu: 1.8%
5: mem: 254.2 MiB (1.5%) command: konsole pid: 4342 cpu: 0.0%
Processes: 325 Power: uptime: 6h 17m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 hibernate: disabled image: 6.17 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.38
