I want a system that is as minimal as possible (which is why I have also installed Manjaro KDE minimal ISO). What bothers me at the moment is KDE Connect, which I will never use. How can I remove it without leaving any residue and without damaging anything else?
If you’ve never actually used it, my guess is that there shouldn’t be any files apart from what’s owned by the package. To be certain, search ~/.config for any relevant files.
Though there may be some packages that are dependencies of KDE Connect that won’t get removed so you’ll have to check those manually.
That’s because3e of the --orphans argument. It adds to the list of things to remove everything not needed by another package. You can omit it if you wish. I only included it because you specified:
That’s a good thing. I’m just not sure if pulseaudio-qt could still be needed, but since I have PipeWire running, I guess that’s fine. In an emergency, there is always a snapshot (Btrfs) .
In principle that should be safe, but it’s always best to double-check each package before going ahead. I have had situations where some of the so-called orphans were actually needed.
