Hi,
First:
I could’t find proper category for my question. Please help me to find one.
Then:
I have a 240 gb ssd and I reserved about 35 gb for a second os (ubuntu). Now I want to relcaim it for timeshift backups. It is on sda1 partition flagged as boot not auntomounted with b and Manjaro is on sda2. I don’t need to backup ubuntu os and I just want to sweep it away and use for timehift backups. What is the most secure way for it? Can I just rm -r it, update the grub and add a fstab entry mounted to, say, /mnt/timeshift point? Since the partition is flagged as boot, is it possible?
Here are some info:
~]$ sudo parted -l
[sudo] password for ceres:
Model: ATA KINGSTON SUV400S (scsi)
Disk /dev/sda: 240GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 35,0GB 35,0GB primary ext4 boot
2 35,0GB 231GB 196GB primary ext4
3 231GB 240GB 8996MB primary linux-swap(v1)
~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 223,6G 0 disk
├─sda1 8:1 0 32,6G 0 part
├─sda2 8:2 0 182,6G 0 part /
└─sda3 8:3 0 8,4G 0 part [SWAP]
~]$ blkid
/dev/sda1: UUID="2d99665a-c61b-41ab-85f3-87b335872c67" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="dee2daa7-01"
/dev/sda2: UUID="6b0569e6-71a6-459e-99cc-ac225fe06b91" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="dee2daa7-02"
/dev/sda3: UUID="19a0c71e-ed32-45ea-8489-9e31e24b22d7" TYPE="swap" PARTUUID="dee2daa7-03"
~]$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=6b0569e6-71a6-459e-99cc-ac225fe06b91 / ext4 defaults,noatime 0 1
UUID=19a0c71e-ed32-45ea-8489-9e31e24b22d7 none swap sw 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
) and timeshift did its job. Happy partitions, happy me!
