Hello.
I want my easyeffects to run even if I close the application window. Right now, when I close the window, the easyeffects also closes.
I found one solution where type the terminal command: easyeffects --gapplication-service but when I close the terminal, it also closes.
Can you please give me a way to make it work?
Thank you.
nohup easyeffects --gapplication-service
This is a bug:
opened 04:55PM - 29 Jul 21 UTC
closed 05:30PM - 30 Jul 21 UTC
On Linux, you can close apps and they still keep running and are available to qu… ickly open from the title bar like this:
I was wondering if you could offer that as an option with EasyEffects. I have a potato laptop (Acer One 14 with AMD A6-7310) and it struggles to open Task View in Ubuntu. This makes it super hard to open EasyEffects every time i want to make a small change to the profile. Just as a creature comfort. I know I could probably set up a macro or something to open easyeffects, which is one of the great things about Linux, but I feel this would be a much better option in the long term. Just an idea. Apart from that, I find this project to be incredible, and miles ahead in terms of intutiveness compared to anything else like EqualiserAPO. Kudos on the good work. Also, thanks in advance.
You can make a file easyeffects.desktop and put it in ~/.config/autostart:
[Desktop Entry]
Terminal=false
Name=EasyEffects
Type=Application
Exec=/usr/bin/easyeffects --gapplication-service
Comment=EasyEffects Service
If this doesn’t work you can try changing the Exec command to:
Exec=/usr/bin/nohup /usr/bin/easyeffects --gapplication-service
this works. thank you again sir @ishaan2479 .
but this has some issue for me. at first, I thought its not working but you have to select the line out radio button then the easy sink radio button to have a sound.
but nonetheless, its working.
this one is nice. nohup thank you for this.
system
Closed
20 January 2022 12:38
6
