How can i Install manjaro with enabled compression
I want to Install a small rescue system with the manjaro Installer.
Because i am a Fan of btrfs compression, i want to enabled compression even before the Installer Starts to write into the Filesystem. (The Last question regarding this was 2020)
Ist this posible ?
I would Like to use zstd:15 :wink:
Yes, but on the condition that you mount the volume yourself with the desired compression options — or remount it if calamares has already mounted it — before proceeding with the installation.
Quite commonly — note: I have not tested this with calamares — you can switch to a separate virtual console (tty) by way of the CtrlAltFunction Key key combos, where you would have a (root) shell at your disposal, and as such, you could verify how — i.e. with what options — the filesystem is mounted, and change this if required.
You can then switch back to the graphical environment that calamares is running in and continue the installation.
Problem is when you click that Install button, it immediately creates the partition table, makes the file systems, then starts writing to them. (EFI -> boot -> root I believe)
As btrfs is so flexible, I didn’t mind as you can convert to whatever to you want after (right after you install live). Not optimal, but I’ve always been looking for an alternative.
And I always wished you could setup the destination yourself for dozens of reasons, outside of btrfs even. Everything is still automatic or assumed in the “manual” partitioning.
Even worse :wink:
Even in Manual Partition mode, and when the Filesystem ist mounted (to Pin down the Options to zstd:15)
Calamares does its own mounts, an willst doing so, it changes the options by force to compress=zstd:1
untested, but seems plausible:
/usr/share/calamares/modules/mount.conf
edit
at the end of the file
mountOptions:
    - filesystem: default
      options: [ defaults ]
    - filesystem: efi
      options: [ defaults, umask=0077 ]
    - filesystem: btrfs
      options: [ defaults, compress=zstd:1 ]
    - filesystem: btrfs_swap
      options: [ defaults, noatime ]
before starting the installer
I have done something similar in the past to go around the enforcing of the minimum RAM requirement.
  • Yesterday I installed manjaro, checked the size 4.45GB(gparted),
  • Then i transferred the entire contents of the file system to the RAM disk, (all subvolumes one after the other)
  • I deleted the content of all subvolumes, changed the mount options, remounted and checked the compression to be zstd:15
  • Then i transferred everything back again from the Ramdisk using’ zstd:15
The result is rather disappointing. I checked the size to be 4.35GB(gparted). So i gained 100MB :frowning:
Yes this seems to be an easy way.
Summary:
Don’t bother trying this; the benefits are minimal and the time investment is too great.
Whoever put this ISO together is a true master of their craft and has done everything to optimize the installation. Hats off! :footprints: @philm @Yochanan @linux-aarhus (or whoever did this)
All that remains after the installation is to adjust the compression settings to your liking; this is easily done in the /etc/fstab, where the default setting is compression=zstd:1.
