How can I fix these ACPI errors?
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG2.WKEN], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG2._DSW], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG2._PR0], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG2._PR3], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG3.WKEN], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG3._DSW], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG3._PR0], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG3._PR3], AE_ALREADY_EXISTS (20220331/dswload2-326)
Aug 25 09:28:03 msi kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20220331/psargs-330)
Aug 25 09:28:03 msi kernel: ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS05._PLD due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Aug 25 09:28:03 msi kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Aug 25 09:28:03 msi kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Aug 25 09:28:03 msi kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS03._PLD due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Aug 25 09:28:03 msi kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Aug 25 09:28:04 msi kernel:
Aug 25 09:28:14 msi gdm-password][1347]: gkr-pam: unable to locate daemon control file
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=8c250394-6d85-47ea-b6c7-5536d2f9dd5a rw quiet splash apparmor=1
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: Micro-Star product: GP66 Leopard 11UG v: REV:1.0
  Mobo: Micro-Star model: MS-1543 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E1543IMS.323 date: 04/20/2022
  ID-1: BAT1 charge: 8.4 Wh (13.5%) condition: 62.1/63.2 Wh (98.2%) volts: 15.5
    min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A status: charging
  System RAM: total: 16 GiB note: est. available: 15.33 GiB
    used: 3.68 GiB (24.0%)
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x46
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 2112 high: 2300 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
    4: 2300 5: 2300 6: 800 7: 2300 8: 800 9: 2300 10: 2300 11: 2300 12: 2300
    13: 2300 14: 2300 15: 2300 16: 2300 bogomips: 73744
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm
    non-free: 535.xx+ status: current (as of 2023-08) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
    chip-ID: 10de:249d class-ID: 0300
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-13:5 chip-ID: 5986:211c
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: Sharp LQ156M1JW03 built: 2021 res: 1920x1080
    hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel UHD Graphics (TGL GT1)
    direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:43c8 class-ID: 0401
  Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
    class-ID: 0403
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: off tools: pw-cli
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel port: 3000 bus-ID: 0000:02:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 0000:04:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:6 chip-ID: 8087:0032
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 24.7 GiB (5.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.8 temp: 39.9 C
    scheme: GPT
  ID-1: / raw-size: 150.39 GiB size: 146.97 GiB (97.73%)
    used: 24.68 GiB (16.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: N/A uuid: 8c250394-6d85-47ea-b6c7-5536d2f9dd5a
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: EFI
    uuid: D0F6-442D
  ID-3: /mnt/Files raw-size: 115.85 GiB size: 113.48 GiB (97.95%)
    used: 20.1 MiB (0.0%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: Files uuid: b94da24b-b64f-4b04-ad44-b2b79caa363a
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 1442-ADBF
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 199.42 GiB fs: ntfs label: N/A
    uuid: 701C486E1C483200
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 674 MiB fs: ntfs label: N/A
    uuid: BE92644E92640CE9
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 10 GiB fs: ntfs label: DriverCD
    uuid: B83813143812D16C
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 3-1:2 info: China Resource Semico USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 500mA chip-ID: 1a2c:4094 class-ID: 0300
  Device-2: 3-3:3 info: SiGma Micro Usb Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 1c4f:0048 class-ID: 0301
  Device-3: 3-9:4 info: SteelSeries ApS KLC type: HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:113a class-ID: 0300
  Device-4: 3-13:5 info: Bison HD Webcam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:211c class-ID: 0e02
  Device-5: 3-14:6 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-4: 4-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 38.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 351 Uptime: 7m wakeups: 1 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1407 libs: 352 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.29
The errors are defined as bug in the ACPI implementation - so you can ignore them.
Perhaps you can find hints at MSI GS65 - ArchWiki
this indicates that your bios doesn’t use the “advanced error reporting” mechanism. nothing to worry, you could change your system by installing additional acpi-packages and try if that solves it. but there is a more common used way by ignoring the “AE”-reporting because it doesn’t harm anything.
to do so you’ll have to edit /etc/default/grub and add
pci=noaer
to the existing entries at
GRUB_CMDLINE_LINUX_DEFAULT="
you’ll need sudo rights to save it after editing.
then you’ll have to run
sudo mkinitcpio -P
sudo update-grub
and reboot.
https://docs.kernel.org/admin-guide/kernel-parameters.html
