Hey guys. Pretty straightforward question. I’ve tried to find this out before yet haven’t been able to find anything ever on it, Googling, basic CL knowledge, etc.
Just trying to find out a simple way to double check if a WiFi connection is 5G or 2G
Thanks in advance!
Teo
16 August 2024 07:10
3
For the exact same purpose i use wavemon
. Maximize the terminal window to see all controls.
This information is available using simple internet search
you should really learn to use the search engines before asking questions
Linux how to get information about my current wifi connection using command line
Why create an account just to ask this question ?
Within the first two results → How to Display Wireless/WiFi Information in Real-time in Linux | Baeldung on Linux
And the answer is...
nmcli -f DEVICE,SSID,IN-USE,FREQ,BARS dev wifi
I rephrased you topic title otherwise it could be mistaken for a guide - which it is not
system
Closed
19 August 2024 07:35
5
