I’ve just come from Ubuntu and there there is a GUI app called “Startup Applications” where you can configure what apps and scripts run on OS startup. Is there an equivalent for Manjaro? If not where is this configured so that I can edit it? (I assume the app effectively just wraps a config file somewhere)
I had a couple of apps (Dropbox & Insync) configured with quite convoluted delay and kick scripts in Ubuntu in order to make them work but the Manjaro boot sequence seems a lot more brisk so I’m not sure I need them anymore so I want to experiment with removing some of these and adding the apps back directly instead.
I’ve never got this option to work correctly, just tried again and a delay value of 60 does not make the test application i used start 60 seconds later.
@Hanzel - I found the same. I trialed that but it did nothing useful that I could see so I added the launch script back in with the sleep from before - Manjaro seems to need far less delays than Ubuntu did but still some.
Dropbox runs fine on Manjaro and doesn’t need the delay script but Insync is… Problematic - that’s a long story involving a horribly convoluted launch script.
