I would like to use zswap instead of zram on my Raspberry Pi 4B.
I have the zswap-arm package installed but it does not seem to be enabled by default because I have the following :
[root@pi ~]# cat /sys/module/zswap/parameters/enabled
N
[root@pi ~]#
Can someone please advise me on how to properly disable zram and enable zswap and also what are the best parameters for zswap.
Please be patient with me because I am new to Manjaro and systemd. I used to use Slackware on my raspberry pi 4B.
Thank You.
Thanks Darksky. The first command worked but the second failed as shown here.
[david@pi ~]$ sudo systemctl disable zswap-arm
[sudo] password for david:
Removed /etc/systemd/system/multi-user.target.wants/zswap-arm.service.
[david@pi ~]$ sudo -Rdd zswap-arm
sudo: you are not permitted to use the -R option with zswap-arm
[david@pi ~]$
and, from journalctl
Dec 04 16:51:09 pi sudo[6939]: david : TTY=pts/1 ; PWD=/home/david ; USER=root ; COMMAND=/usr/bin/systemctl disable zswap-arm
Dec 04 16:52:31 pi sudo[7004]: david : user not allowed to change root directory to dd ; TTY=pts/1 ; PWD=/home/david ; USER=root ; COMMAND=zswap-arm
However, the first command has disabled zram (both the swap and the kernel module).
I didn’t try disabling the zswap-arm service before because I thought that it was for zswap not zram !
Now all I have to do is make sure that the zswap is working correctly. I don’t seem to have dmesg to check and I am a bit of a novice at journalctl. Can you advise me on this please.
