With the latest 6.2.yy kernel I loose the HDMI audio, once the system “sleeps” or hibernates …
Using a full desktop, so the power supply | battery sleep mecanism is not needed …
( I know this is a “bug” in the 6.2. yy HDMI module so I am using the 5.15 LTS for now in order to avoid this kind of issue …)
So, is there any adjustment to make, in order to disable the sleep \ hibernate detail ?
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
