whenever I open an application a tiny little icon of that application follows the cursor can I disable this feature in Manjaro KDE plasma?
Hi,
Go to System Settings > Applications > Launch Feedback
Change the cursor behaviour there.
Thank you @NGr It worked Perfectly.
