I think that title of this topic says everything.
I have 2 modules. slot 2 and 4 from the CPU
Inxi don’t show anything about.
dmidecode -t memory shows:
Memory Device
Array Handle: 0x0010
Error Information Handle: 0x0019
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Bank Locator: P0 CHANNEL A
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 3600 MT/s
Manufacturer: Kingston
Serial Number: 39CA9D07
Asset Tag: Not Specified
Part Number: KHX3600C17D4/16GX
Rank: 2
Configured Memory Speed: 3600 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Aragorn
December 16, 2020, 10:19pm
#2
man dmidecode
Hint: Look in the output for the word “interleave”.
chomsky
December 16, 2020, 10:29pm
#3
With this terrifying command…
sudo dmidecode -t 17 | awk 'BEGIN { FS=":"; OFS="\t" } /Size|Channel/ { line = (line ? line OFS : "") $2 } /^$/ { print line; line="RAM" }' | grep -iv 'no'
man dmidecode | grep interleave
gives me nothing
output of this command is :
chomsky
December 16, 2020, 10:55pm
#5
Do this:
sudo dmidecode | grep Interleaved
If you see data depth of 2 you are running dual channel
TriMoon
December 17, 2020, 1:51pm
#6
You should consult your motherboard’s documentation wrt to placement of the DIMM’s.
It will describe you if and when it supports dual channel mode.
In other words it all depends on your Motherboard in combination with placement of the DIMM’s and type of DIMM’s used.
Interleaved Data Depth: Unknown
It’s MSI tomahawk x570. I’m sure that it supports Dual channel. I placed memory as said in manual but wanted to check it in the system.
I have huge stability issues and looking for every reason I can
