How can i add amdgpu.dc=0
to kernel parameters
You edit the file /etc/default/grub
Where you see:
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
for example, you change it to
GRUB_CMDLINE_LINUX_DEFAULT="quiet amdgpu.dc=0"
Save it and then run from terminal:
sudo update-grub
Reboot the system and that parameter will be used.
