How Can I Change Accent Colors in KDE Plasma Themes?
I’m using KDE Plasma and would like to customize the accent colors of my current theme. Is there a built-in way to change accent colors, or do I need to modify theme files manually? Any guidance on adjusting colors while keeping the overall look of the theme consistent would be appreciated.
Hi there, welcome…
The answer is Yes.
If you open the menu, or krunner, and start typing ‘colors’ then you’ll get a launcher for the colours dialog.
Right at the top there is an option to select:
  • Accent colour from wallpaper (changes with wallpaper)
  • Accent colour from scheme (the selected colour scheme)
  • Custom accent colour.
Good choice, and Welcome to the Forum.
