Hello everyone,
When I reinstall the operating system, I need some time to set up my speakers, webcam and the microphone. Is there a way that I can save the sound profile I have set up to USB?
Hello everyone,
There should be a .conf for each of those settings. Just copy those files to a safe place.
I do this with conky, tint2, btop, terminator, gimp…
When I do a fresh install, I just repace the newly installed .conf file with my saved config files.
Thank you, I think it’s not so easy! I found this: Link , but I can’t understand wat is to do. I prefer to leave it alone and set up the sound manually during a new installation.
ALSA mixer settings for audio devices are usually saved to /var/lib/alsa/asound.state
To transfer ALSA settings, save settings to home folder
alsactl store -f ~/asound.state
Copy asound.state file to USB
And copy file from USB to /var/lib/alsa/asound.state on reinstalled system
Wow! It worked! Thank you for that!
