Hi,
I have the screen:
The screen locker is broken and unlocking is not possible anymore.
In order to unlock switch to a virtual terminal log in and execute the command: loginctl unlock-session 2
Then log out of virtual screen and switch back to running session.
On my pinephone pro
If I understand a forum Lock screen broken after 2022-05-23 update this is because is not the right I have to remplace this by this.
How I can do that on my my pinephone pro?
I have clavier and a mouse and a screen link to my pinephone pro now.
How can I access to a command line on the beginning on my starting pinephone pro?
If you read that and you want to respond in french please respond in English too.
Si vous lisez ceci et que vous voulez répondre en français faite le en anglais aussi s’il vous plaît
Bonjour,
J’ai sur mon pinephone pro l’écran :
J’ai compris qu’il fallait que je change par.
Mais comment je peux accéder à un écran pour taper une commande au démarrage du pinephone pro sous Manjaro plasma ?
Merci
Cordialement
