I was using Manjaro. And, I had Windows alongside Manjaro. I have installed Debian without “removing” any OS (I had removed Prime OS). And, I was using grub-loader of Manjaro earlier (Manjaro’s grub loader was detecting Prime OS by some new codes). But, I have installed grub-loader of Debian mistakenly. Even, currently I am using grub-loader of Debian. I can access Windows and Debian without any problem. But, I try to start Manjaro. I get bunch of error.
I had tried to update grub in Debian also. I got another error again
bash: update-grub: command not found
So, I had thought to install grub loader again. I got the same error again
bash: grub-install: command not found
How can I access Manjaro without any error?
grub.cfg of Manjaro :
[Istiak grub]# cat grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos6'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6 93d7c69b-c3e2-475e-9b22-292c8d37a6ff
else
search --no-floppy --fs-uuid --set=root 93d7c69b-c3e2-475e-9b22-292c8d37a6ff
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=5
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 5 ; then
set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.10-x86_64 root=UUID=93d7c69b-c3e2-475e-9b22-292c8d37a6ff rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
initrd /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
menuentry 'Manjaro Linux (Kernel: 5.10.42-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.42-1-MANJARO x64-advanced-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry 'Manjaro Linux (Kernel: 5.10.42-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.42-1-MANJARO x64-fallback-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /boot/initramfs-5.10-x86_64-fallback.img
menuentry 'Manjaro Linux (Kernel: 4.14.235-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.14.235-1-MANJARO x64-advanced-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.14-x86_64 root=UUID=93d7c69b-c3e2-475e-9b22-292c8d37a6ff rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
initrd /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
menuentry 'Manjaro Linux (Kernel: 4.14.235-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.14.235-1-MANJARO x64-fallback-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /boot/initramfs-4.14-x86_64-fallback.img
menuentry 'Manjaro Linux (Kernel: 4.9.271-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.271-1-MANJARO x64-advanced-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.9-x86_64 root=UUID=93d7c69b-c3e2-475e-9b22-292c8d37a6ff rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
initrd /boot/intel-ucode.img /boot/initramfs-4.9-x86_64.img
menuentry 'Manjaro Linux (Kernel: 4.9.271-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.271-1-MANJARO x64-fallback-93d7c69b-c3e2-475e-9b22-292c8d37a6ff' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /boot/initramfs-4.9-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 10 (on /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-chain-10C4F74DC4F73416' {
savedefault
insmod part_msdos
insmod ntfs
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 10C4F74DC4F73416
else
search --no-floppy --fs-uuid --set=root 10C4F74DC4F73416
fi
parttool ${root} hidden-
drivemap -s (hd0) ${root}
chainloader +1
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "Prime OS" {
set root='(hd0,2)'
linux /android/kernel root=/dev/ram0 androidboot.hardware=android_x86_64 androidboot.selinux=permissive quiet SRC=/android DATA=/data vga=788
initrd /android/initrd.img
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
search --fs-uuid --no-floppy --set=root --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6 93d7c69b-c3e2-475e-9b22-292c8d37a6ff
linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
