Is there a way make the hostpot button (or a h. button) available in the top bar ? it’s a bit tedious to go through to the hamburger button, activate button etc.
Thanks, but it doesn’t seem to be able to create buttons ?
This extension shows button in taskbar, only if the app supports Tray-icons…
I do not use hotspots - in pamac are some apps listet for…
Is this what you are looking for:
Yes thats what I meant. So there is no way to force a normal setting as shortcut or to appear in the taskbar ?
https://extensions.gnome.org/extension/2464/wifi-disconnector/
is near your demandbut not really helpful?
Its nearly that but one to activate a hostpot. How do you find all of this ?
Modern Computers make it posible…
Look in Pamac for:
wifiman and wifiman-indicator
you need “Tray Icons reloaded” too at:
https://extensions.gnome.org/extension/2890/tray-icons-reloaded/
