I have set the password to 12345678 but when enter same password and it doesn’t even send the password (verified from wireshark live capture, there is no authentication packets).
With the same device I can connect to WPA2 access point in my office. Doesn’t that mean it supports WPA2, but somehow choosing WPA3? Also when i changed it in the settings (network settings of my manjaro system), it didn’t make any difference. Still WPA3.
Btw there it shows WPA/WPA2 Personal, which was WPA3 Personal earlier.
Well, I don’t know how you set that up in Manjaro. Did you use NetworkManager, and if so, how exactly did you do that? And did you restart the network (or reload the daemon)?
Yes. When I do restart NetworkManager, in my case it doesn’t show Hotspot button in network applet, so I have to logout and login again. Then it creates a new network with same SSID and WPA 3 Personal.
