Hello,
on one Manjaro Linux i “hostname -i” returns LAN IP, but on other only localhost IP 127.0.0.1
do you have idea how to make it report LAN IP without manually modifying any file?
The correct way of reporting a LAN IP is:
ip address
and according to the hostname’s man page:
-i, --ip-addresses
addresses for the host name
So any address is fine for that tool to display, so:
is impossible to solve…
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
That depends on the hosts file.
When you are using dhcp addressing - the default - the hosts file will contain 127.0.0.1 for local host which is what you get.
When you define the computer name - usually you assign 127.0.1.1 to the hostname when the IP is dhcp assigned and the IP address if you assign a static IP.
