So recently I installed Manjaro. Glad to be here. My first impression about Linux in general is very easy and welcoming thanks to Manjaro. So I didn’t notice it at first but now I found out that my laptop microphone (the default onboard one) wasn’t working. It produces this horrible static white noises that won’t go away.
After digging around on the forums I tried to installed some drivers in the Terminal doing these commands:
mhwd -d --pci
The result returned two Audio devices:
PCI 300.1: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:03:00.1
SysFS BusID: 0000:03:00.1
Hardware Class: sound
Model: "ATI Audio device"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x1637
SubVendor: pci 0x1002 "ATI Technologies Inc"
SubDevice: pci 0x1637
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xfe788000-0xfe78bfff (rw,non-prefetchable)
IRQ: 85 (541 events)
Module Alias: "pci:v00001002d00001637sv00001002sd00001637bc04sc03i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Attached to: #20 (PCI bridge)
and
PCI 300.6: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:03:00.6
SysFS BusID: 0000:03:00.6
Model: "AMD Family 17h (Models 10h-1fh) HD Audio Controller"
Vendor: pci 0x1022 "AMD"
Device: pci 0x15e3 "Family 17h (Models 10h-1fh) HD Audio Controller"
SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
SubDevice: pci 0x1c0e
Memory Range: 0xfe780000-0xfe787fff (rw,non-prefetchable)
IRQ: 86 (4505 events)
Module Alias: "pci:v00001022d000015E3sv00001043sd00001C0Ebc04sc03i00"
Driver Info #0:
When I tried to install new driver (I thought because if I update the driver it will work) the result came back as:
sudo mhwd -a pci free 0403 ✔
Warning: No config found for device: 0000:03:00.1 (0403:1002:1637) Multimedia controller ATI Technologies Inc
Warning: No config found for device: 0000:03:00.6 (0403:1022:15e3) Multimedia controller AMD Family 17h (Models 10h-1fh) HD Audio Controller
How should I fix this?
My neofetch:
OS: Manjaro Linux x86_64
Kernel: 5.15.12-1-MANJARO
Shell: zsh 5.8
Resolution: 1920x1080
DE: GNOME 41.2
WM: Mutter
CPU: AMD Ryzen 5 4500U with Radeon Graphics (6)
GPU: AMD ATI 03:00.0 Renoir
Memory: 2804MiB / 7427MiB
Appreciate the help.
mod. edit: objectified thread title
