Hello, im new to linux, i didnt know how to manually do partitioning like i do in Windows, so i just erased everything on SSD and let Manjaro install.
Now, im booted, and im even writing from the OS (very nice btw), BUT. I have another hard disk, 1TB, and i wanna know how can i make that my partition for everything but OS related? which i guess is named Home partition.
Edit : Im trying to make my HDD be the partition for Home, as my SSD is small (128 gb) so i want to use my HDD for everything else but OS
See if this helps… ![]()
completely broke the os with that guide, currently on live version from USB.
If you broke your system with what I wrote in that post, then either you didn’t read it very well, or you didn’t do as I wrote, or both.
sudo telinit 1 - command not found
Use…
sudo systemctl isolate rescue.target
… instead.
now it worked, thank you
