Hello, since I’ve updated my Atom editor to 1.61.0-beta0 now my keyboard shortcut for opening my home folder opens up that folder into the Atom editor. It also starts an Electron process that hogs up a lot of CPU & RAM and remains open even after Atom is closed.
Any ideas of what might be up with this?
Ty!
Inxi
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=df7a105e-6ebc-4a94-bb06-ba9156e9161c rw quiet apparmor=1
security=apparmor resume=UUID=bd9d7dac-f62e-4ec5-bc1d-7a6957726858
udev.log_priority=3
Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.33 wm: Muffin dm: LightDM
v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20NB001SUS v: ThinkPad E590
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NB001SUS v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R0YET49W (1.32 ) date: 03/14/2022
ID-1: BAT0 charge: 37.5 Wh (100.0%) condition: 37.5/45.7 Wh (81.9%)
volts: 12.3 min: 11.1 model: Celxpert 01AV448 type: Li-poly serial: <filter>
status: full cycles: 476
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K330
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M560
status: discharging
RAM: total: 15.35 GiB used: 5.6 GiB (36.5%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: SK Hynix part-no: HMA81GS6CJR8N-VK
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
serial: <filter>
Info: model: Intel Core i7-8565U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Comet/Whiskey Lake note: check family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 739 high: 800 min/max: 400/4600 base/boost: 1800/2000
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 713 5: 700 6: 700 7: 700
8: 700 bogomips: 32012
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 5986:2113 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1453 s-dpi: 96 s-size: 1185x384mm (46.65x15.12")
s-diag: 1246mm (49.04")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,bottom-l
model: ViewSonic VX2478 Series serial: <filter> built: 2019 res: 2560x1440
hz: 60 dpi: 124 gamma: 1.2 size: 526x296mm (20.71x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 pos: top-right model: Lenovo 0x40ba built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
IF-ID-1: br-d66ff4d0e2b7 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 346.99 GiB (72.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 0108ADLA temp: 38.9 C scheme: GPT
ID-1: / raw-size: 459.75 GiB size: 451.46 GiB (98.20%)
used: 346.99 GiB (76.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: df7a105e-6ebc-4a94-bb06-ba9156e9161c
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 4879-6B7A
ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: bd9d7dac-f62e-4ec5-bc1d-7a6957726858
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:4 info: Acer SunplusIT Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C pch: 43.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 312 Uptime: 4h 26m wakeups: 36 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1719
pacman: 1715 lib: 514 pkg: 0 flatpak: 4 Shell: Bash (sudo) v: 5.1.16
running-in: gnome-terminal inxi: 3.3.16
