Hitching/Stuttering Unless Mouse Is Moving
When trying to scroll in a browser (Tried both firefox and brave) I get a lot of stuttering and hitching, unless I constantly move my mouse. In which case it becomes a perfectly smooth experience. Same goes for when I try to play a video using VLC, choppy and freezes until I start moving my mouse.
Tried a couple different kernel versions and it’s still the same.
  Kernel: 5.13.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=92fb4bf5-b585-422e-bb7e-cce62c8e09b2 rw quiet apparmor=1
  security=apparmor resume=UUID=1bdcc5e9-8d4e-42ba-9cf1-153d51671825
  udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
  v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: 1.E0
  date: 05/14/2021
  RAM: total: 15.55 GiB used: 2.42 GiB (15.5%)
  Info: 8-Core model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
  L2: 4 MiB bogomips: 140066
  Speed: 4375 MHz min/max: N/A Core speeds (MHz): 1: 4375 2: 4375 3: 4375
  4: 4375 5: 4375 6: 4371 7: 4375 8: 4375 9: 4375 10: 4375 11: 4375 12: 4375
  13: 4375 14: 4375 15: 4375 16: 4375
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  conditional, RSB filling
  Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: eVga.com. driver: nvidia
  v: 390.143 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0 chip-ID: 10de:1b80
  class-ID: 0300
  Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
  s-diag: 987mm (38.8")
  Monitor-1: DP-2 res: 3440x1440 dpi: 109 size: 798x335mm (31.4x13.2")
  diag: 865mm (34.1")
  OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 390.143
  direct render: Yes
  Device-1: NVIDIA GP104 High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f0
  class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.0-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
  bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  v: kernel port: d000 bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
  IF: wlp41s0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-4:3 chip-ID: 8087:0aa7 class-ID: e001
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 3.51 TiB used: 302.07 GiB (8.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: SSD2SC120G1SA754D117-820
  size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 5B scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: CS1311 240GB SSD
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 1122 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-21M2NA0
  rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA200
  rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: MBR
  ID-5: /dev/sde maj-min: 8:64 type: USB model: TO Exter nal USB 3.0
  size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
  serial: <filter> rev: 0104 scheme: MBR
  ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%)
  used: 97.58 GiB (46.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
  uuid: 92fb4bf5-b585-422e-bb7e-cce62c8e09b2
  used: 292 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
  uuid: D060-415A
  ID-3: /run/media/mike/New Volume raw-size: 465.76 GiB
  size: 465.76 GiB (100.00%) used: 204.49 GiB (43.9%) fs: fuseblk
  dev: /dev/sde1 maj-min: 8:65 label: New Volume uuid: 3E2C6EB12C6E643D
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1.2 MiB (0.0%) priority: -2
  dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: 1bdcc5e9-8d4e-42ba-9cf1-153d51671825
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: <superuser required>
  label: N/A uuid: C678-F079
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 111.19 GiB fs: <superuser required>
  label: N/A uuid: 26C2809CC280723B
  ID-4: /dev/sda4 maj-min: 8:4 size: 499 MiB fs: <superuser required>
  label: N/A uuid: 722627132626D83D
  ID-5: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: <superuser required>
  label: N/A uuid: A2248792248767DD
  ID-6: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: <superuser required>
  label: N/A uuid: 9E1A901C1A8FF017
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 1-1:2 info: Logitech Gaming Keyboard G610 type: Keyboard,HID
  power: 500mA chip-ID: 046d:c338 class-ID: 0300 serial: <filter>
  Device-2: 1-4:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Device-1: 2-2:2 info: Unknown JMS578 based SATA bridge type: Mass Storage
  driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
  chip-ID: 0080:a001 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech G502 Proteus Spectrum Optical Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
  serial: <filter>
  Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 47.6 C mobo: 0 C gpu: nvidia temp: 55 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 10%
  Processes: 316 Uptime: 12m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1069 lib: 296 flatpak: 0 Shell: Bash
  v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
Any help would be greatly appreciated.
try disabling composting.
That solved it.
Thanks for your help!
