High RAM usage stops audio
When I do some tasks like opening more Firefox instances, with media playing, or running some code etc - whenever the RAM usage is high, the system freezes for a few seconds, and my sound just stops. To be precise, I suspect something happens to Viper4Linux installed in my device. When the sound goes silent, I have to “Reload Driver” in V4L in order to get it to work again.
There is only 8GB RAM and I know it isn’t a lot. But why is sound the only thing that gets stopped when the system is frozen?
Some times the entire V4L gets terminated. Then, I have to go to Audio Mixer, mess with configuration and reopen V4L.
My inxi output:
  Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=d4fb6d47-48d2-4f0e-a794-ee1c9932880a rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: N/A model: H110 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: 5.12 date: 12/31/2020
  System RAM: total: 8 GiB available: 7.67 GiB used: 7 GiB (91.4%)
  Array-1: capacity: 64 GiB slots: 4 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: 04cb part-no: N/A serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1600 min/max: 800/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 24008
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel HD Graphics 630 driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: DP-1,HDMI-A-2
    empty: DP-2,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:5912
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3286x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 pos: bottom-l model: VGA serial: <filter> built: 2020
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 403mm (15.9") ratio: 16:9 modes: max: 1366x768 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,top-right
    model: Lenovo D24-40 serial: <filter> built: 2024 res: 1920x1080 hz: 60
    dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
    ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:5912 memory: 3.74 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: Intel
    HD Graphics 630 (KBL GT2) driver: N/A device-ID: 8086:5912
    surfaces: xcb,xlib
  Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: 1: wireplumber status: off
    2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0
    chip-ID: 10ec:8136 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8192EU 802.11b/g/n WLAN Adapter driver: rtl8xxxu
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
    chip-ID: 0bda:818b class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u5 state: up mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Local Storage: total: 357.72 GiB used: 250.41 GiB (70.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-E100 256G
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: AA20 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT120BX500SSD1
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: R013 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
    size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.26
    scheme: MBR
  ID-1: / raw-size: 43.35 GiB size: 42.12 GiB (97.16%) used: 33.51 GiB (79.6%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: root
    uuid: d4fb6d47-48d2-4f0e-a794-ee1c9932880a
    used: 25.9 MiB (8.6%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: B6AE-2520
  ID-3: /home raw-size: 186.83 GiB size: 183.34 GiB (98.13%)
    used: 164.39 GiB (89.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: home
    uuid: d29146b1-18e8-4782-a8cf-e1ba69862e6f
  ID-4: /mnt/shared raw-size: 72.71 GiB size: 72.71 GiB (100.00%)
    used: 51.07 GiB (70.2%) fs: ntfs dev: /dev/sdb4 maj-min: 8:20
    label: New Volume uuid: C4E229DBE229D30A
  ID-1: swap-1 type: partition size: 8 GiB used: 1.4 GiB (17.5%) priority: -2
    dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 13d1eb82-e509-4b11-9a7b-fda9e62c4487
  ID-1: /dev/sdb1 maj-min: 8:17 size: 39.06 GiB fs: ntfs label: N/A
    uuid: 980895050894E412
  ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sdc1 maj-min: 8:33 size: 3.63 GiB fs: iso9660
  ID-4: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 9D59-BEAA
  Device-1: 1-1:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0300 class-ID: 0301
  Device-2: 1-2:3 info: Logitech Keyboard K120 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
  Device-3: 1-5:4 info: Realtek RTL8192EU 802.11b/g/n WLAN Adapter
    type: Network driver: rtl8xxxu interfaces: 1 rev: 2.1
  Device-4: 1-6:5 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 56.0 C pch: 44.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 245 Power: uptime: 10h 11m states: freeze,mem,disk suspend: s2idle
    image: 3.05 GiB services: upowerd,xfce4-power-manager Init: systemd v: 257
  Packages: 1633 pm: pacman pkgs: 1601 libs: 485 tools: pamac pm: snap
    pkgs: 32 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.36
I am not an advanced user. It took a lot of work to get sound work when I first installed Manjaro + V4L. Since then, I didn’t dare touch anything that works.
Used to plug my headphone directly to PC front output. Same story back then. But since migrating to HDMI, I plug them into the monitor, because it is chosen as default sound output on every reboot.
Output for
systemctl --user status pulseaudio.*
When sound is working
● pulseaudio.service - Sound Service
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; preset:>
     Active: active (running) since Wed 2025-02-26 08:54:53 IST; 10h ago
 Invocation: c955946aa17e484991f42de2f26ceb1e
TriggeredBy: ● pulseaudio.socket
   Main PID: 1546 (pulseaudio)
      Tasks: 8 (limit: 9295)
     Memory: 29.4M (peak: 53.5M, swap: 20.2M, swap peak: 21.8M)
        CPU: 1h 44min 11.448s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulsea>
             ├─1546 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─1642 /usr/lib/pulse/gsettings-helper
Feb 26 19:08:26 god pulseaudio[1546]: q overrun, queuing locally
Feb 26 19:08:31 god pulseaudio[1546]: 5618 events suppressed
Feb 26 19:08:31 god pulseaudio[1546]: q overrun, queuing locally
● pulseaudio.socket - Sound System
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: >
     Active: active (running) since Wed 2025-02-26 08:54:52 IST; 10h ago
 Invocation: 3b86a8d038994b34920e7d13cae5d002
   Triggers: ● pulseaudio.service
     Listen: /run/user/1000/pulse/native (Stream)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio>
Feb 26 08:54:52 god systemd[1537]: Listening on Sound System.
When sound is stopped
     Memory: 24.6M (peak: 53.5M, swap: 20.4M, swap peak: 22M)
        CPU: 1h 44min 25.516s
Feb 26 19:53:50 god pulseaudio[1546]: q overrun, queuing locally
Sound is usually working - but to get a decent tone it may need adjustment.
Are you sure you need the Viper4Linux ?
Disclaimer:
I am not associated with the awesome mates over at Viper. I wish I was, but it is what it is. (Jason, you’re particularly awesome.) You can find their git here: vipersaudio (Euphy Wong) · GitHub and their site here: http://vipersaudio.com/blog/
While all my software is free (GPL), theirs is not. This (my) software makes use of their non-free libraries. I have kept these libraries separate from this code, but it is dependent on them. You can find all the necessary instructions below.
DOES NOT WORK WITH DEEPIN (very well). Check the deepin branch for a patched version. (Props to topjor for this fix.) There is a bug in Deepin where any new audio streams are forced to go to the “default” output device even if they are specifically told to go elsewhere. Please harass the Deepin devs for me.
– GitHub - noahbliss/Viper4Linux: Implementation of the libviper library for modern Linux desktops.
Which means you are using some proprietary libraries - which I suspect is not from the Manjaro repo.
This essentially put your issue in the unsupported category - we cannot help you with third party applications - please seek upstream for support.
Oh, okay. Can I at least control which app gets canned or not when the RAM usage is high? I think I set the priority or something once with the help of ChatGPT. Didn’t work.
Please provide inxi -zv8 so we can try to help you.
Do you have swap activated ?
There is no better substitute for more RAM than
more RAM
Here you go.
    date: 12/31/2020
  System RAM: total: 8 GiB available: 7.67 GiB used: 4.84 GiB (63.2%)
    disabled
    class-ID: 0300
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 chroma: red: x: 0.655 y: 0.337
    green: x: 0.294 y: 0.608 blue: x: 0.141 y: 0.075 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 403mm (15.9") ratio: 16:9
    modes: 1366x768, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 640x480, 720x400
    dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.310 y: 0.620
    blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1366x768,
    1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    inactive: wayland
    surfaces: xcb,xlib
    class-ID: 0403
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Local Storage: total: 357.72 GiB used: 252.03 GiB (70.5%)
    scheme: MBR
    uuid: B6AE-2520
    used: 164.37 GiB (89.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: home
  ID-1: swap-1 type: partition size: 8 GiB used: 3.04 GiB (38.0%)
    priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 9D59-BEAA
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    serial: <filter>
  System Temperatures: cpu: 54.0 C pch: 43.5 C mobo: N/A
    pkgs: 32
    1: http://kartolo.sby.datautama.net.id/manjaro/unstable/$repo/$arch
    2: https://mirrors.xtom.jp/manjaro/unstable/$repo/$arch
    3: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://mirror.kamtv.ru/manjaro/unstable/$repo/$arch
    5: https://mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
    6: https://mnvoip.mm.fcix.net/manjaro/unstable/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
Processes:
  CPU top: 5 of 238
  1: cpu: 16.2% command: viper-gui pid: 1714 mem: 81.0 MiB (1.0%)
  2: cpu: 15.9% command: pulseaudio pid: 1546 mem: 40.0 MiB (0.5%)
  3: cpu: 13.1% command: xfce4-terminal pid: 84782 mem: 48.8 MiB (0.6%)
  4: cpu: 12.0% command: firefox pid: 6102 mem: 522.6 MiB (6.6%)
  5: cpu: 11.8% command: firefox pid: 55448 mem: 386.2 MiB (4.9%)
  Memory top: 5 of 238
  1: mem: 1145.2 MiB (14.5%) command: firefox pid: 6609 cpu: 11.1%
  2: mem: 522.6 MiB (6.6%) command: firefox pid: 6102 cpu: 12.0%
  3: mem: 386.2 MiB (4.9%) command: firefox pid: 55448 cpu: 11.8%
  4: mem: 314.9 MiB (4.0%) command: firefox pid: 6692 cpu: 1.4%
  5: mem: 275.3 MiB (3.5%) command: firefox pid: 75477 cpu: 9.3%
  Processes: 238 Power: uptime: 11h 15m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 3.05 GiB services: upowerd,xfce4-power-manager
I have 8GB swap memory, if that’s what you asked.
GitHub - Audio4Linux/Viper4Linux-GUI: Official UI for Viper4Linux2 · GitHub
On Arch you can use the AUR package (using git) provided by yochananmarqos:
AUR (en) - viper4linux-gui-git (orphan)
Last Packager: yochananmarqos
Last Updated: 2024-09-21 18:11 (UTC)
AUR (en) - jamesdsp-pulse
Maintainer: yochananmarqos
Last Updated: 2024-12-13 02:36 (UTC)
Data from pulseaudio.service is showing a lot of buffer underruns
Viper4Linux and JamesDSP contain a number of audio processing effects that can enhance sound, or have a detrimental effect on human hearing if misused
Each individual effect when turned on requires more RAM to buffer audio and adds latency to the audio stream
Motherboard manufacturer might have a BIOS update
Kernel 6.11 has reached EOL and is no longer supported; it has also been removed from Manjaro repositories. It is highly recommended to switch to another kernel at your earliest opportunity.
Kernels 6.12 (LTS) and 6.6 (LTS) are suggested.
Please post more information about PulseAudio
pacmd list-sinks
pulseaudio --dump-conf
