In 2019 I used kernel 4.19 and was quite happy with it, but then I upgraded to 5.x and got a noticeable increase in temperature and fan speeds. I didn’t really understood that it depended on the kernel and thought it was something to do with the features in the new version of Manjaro, but now I decided to downgrade the kernel to 4.19 and found that the notebook became cool and quiet as before with the same version of Manjaro. Switching it back to 5.xx makes it hot and loud again. I tried “recommended” 5.4 and 5.10 and “experimental” 5.16rc4…" but the power usage is always MUCH higher than with 4.19 even when the notebook is not used (it’s reported like 25W vs 8W). I can stay happy with 4.19 kernel, but there appeared a problem that I did not have before: when I try to copy a file to a removable drive such as a usb flash drive or an SD-card, I always get an error message “Cannot copy… (Errno: 18)”. When I reboot with kernel 5.x, the same file is copied to the same location fine, then I reboot with 4.19 and cannot copy anything again neither from the USB drive, nor into it. Copying files with root priveleges returns the same error. While Manjaro with kernel 4 can still copy the files from one local place to another local place without errors. Can anyone suggest something to solve it? Any solution is welcome - to lower the heat in kernel 5 or to make kernel 4 copy files to removable devices This all happens on the same manjaro version and configuration, the only thing I did is rebooted the system and selected another kernel version in GRUB.
I’ve made screenshots of power usage and powertop, but this forum does not allow me to attach images or add urls to external image hosting sites.
Provide the output of your system information inxi -Fazy and kernel message sudo dmesg.
If possible, sudo dmesg on kernel 4.x and 5.x and compare the result. I expect an erratic ACPI problem.
Enclose the output of the above commands with triple backtick " ` " for formatting in here.
After you mentioned ACPI, I should note that I use the following code to turn off Nvidia card and remove it from devices. Actually, it is the thing that removes extra heat from this notebook and if something prevents it from working properly, this may explain why the notebook is so hot. Here is the code:
sudo modprobe nvidia “NVreg_DynamicPowerManagement=0x02”
sudo echo on > /sys/bus/pci/devices/0000:01:00.0/power/control
sudo echo ‘_SB.PCI0.PEG0.PEGP._OFF’ > /proc/acpi/call
sudo echo -n 1 > ‘/sys/bus/pci/devices/0000:01:00.0/remove’
The commands are stored in /etc/rc.d/rc.local file and there is a service /etc/systemd/system/rc.local.service that executes /etc/rc.d/rc.local every time the system starts.
I’m not sure if all of it is the best solution to do the thing, but I tried many other solutions and this is the only thing that really gave noticeable decrease in temperature and fan noise on my notebook.
And the requested information is below:
KERNEL 4 (cool and quiet, but cannot copy files):
Kernel: 4.19.220-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=d4df29af-139e-4d27-b026-f8345840a53f rw quiet
resume=/dev/disk/by-uuid/7805e5b0-f80b-4d8e-8bb8-5d9f1ef1d2d7
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MAIBENBEN product: HeiMai 7 v: N/A
Mobo: MAIBENBEN model: HeiMai 7 serial: <superuser required> UEFI: INSYDE
v: 1.07.01TOYC date: 04/15/2019
ID-1: BAT0 charge: 40.8 Wh (90.7%) condition: 45.0/47.5 Wh (94.7%)
volts: 12.2 min: 10.8 model: Notebook BAT type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Pentium Gold G5420 bits: 64 type: MT MCP
arch: Coffee Lake family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3301 high: 3519 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3289 2: 3002 3: 3519
4: 3394 bogomips: 30336
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Device-1: Intel CoffeeLake-S GT1 [UHD Graphics 610] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e90 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: intel display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 135 size: 360x200mm (14.2x7.9")
diag: 412mm (16.2")
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Sound Server-1: ALSA v: k4.19.220-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.4 TiB used: 808.49 GiB (56.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 004C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXA7301Q scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 63.21 GiB (64.5%)
fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 32.3 MiB (32.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: partition size: 16.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
System Temperatures: cpu: 44.0 C pch: 47.0 C mobo: N/A
Processes: 190 Uptime: 0m wakeups: 1 Memory: 15.38 GiB used: 1.03 GiB (6.7%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1604 lib: 453 Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
[ 0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[ 0.000000] Linux version 4.19.220-1-MANJARO (builduser@fv-az72-805) (gcc version 11.1.0 (GCC)) #1 SMP Wed Dec 8 09:52:19 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=d4df29af-139e-4d27-b026-f8345840a53f rw quiet resume=/dev/disk/by-uuid/7805e5b0-f80b-4d8e-8bb8-5d9f1ef1d2d7 udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[3]: 576, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 640, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000037456fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000037457000-0x0000000037d56fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000037d57000-0x000000004df6dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000004df6e000-0x000000004e16dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000004e16e000-0x000000004f59dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000004f59e000-0x000000004fc8dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000004fc8e000-0x000000004fd0dfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000004fd0e000-0x000000004fd0efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000004fd0f000-0x000000005d7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004a07fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.60 by INSYDE Corp.
[ 0.000000] efi: ACPI=0x4fd0d000 ACPI 2.0=0x4fd0d014 SMBIOS=0x4e321000 SMBIOS 3.0=0x4e31f000 ESRT=0x4e31d818 MEMATTR=0x3e4f4018
[ 0.000000] SMBIOS 3.0.1 present.
[ 0.000000] DMI: MAIBENBEN HeiMai 7/HeiMai 7, BIOS 1.07.01TOYC 04/15/2019
[ 0.000000] tsc: Detected 3800.000 MHz processor
[ 0.000007] tsc: Detected 3792.000 MHz TSC
[ 0.000007] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000008] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000013] last_pfn = 0x4a0800 max_arch_pfn = 0x400000000
[ 0.000015] MTRR default type: write-back
[ 0.000016] MTRR fixed ranges enabled:
[ 0.000017] 00000-9FFFF write-back
[ 0.000017] A0000-BFFFF uncachable
[ 0.000018] C0000-FFFFF write-protect
[ 0.000018] MTRR variable ranges enabled:
[ 0.000019] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000020] 1 base 0060000000 mask 7FE0000000 uncachable
[ 0.000020] 2 base 005C000000 mask 7FFC000000 uncachable
[ 0.000020] 3 base 005A000000 mask 7FFE000000 uncachable
[ 0.000021] 4 base 0059000000 mask 7FFF000000 uncachable
[ 0.000021] 5 base 2000000000 mask 6000000000 uncachable
[ 0.000022] 6 base 1000000000 mask 7000000000 uncachable
[ 0.000022] 7 base 0800000000 mask 7800000000 uncachable
[ 0.000023] 8 base 4000000000 mask 4000000000 uncachable
[ 0.000023] 9 disabled
[ 0.000612] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000729] last_pfn = 0x4fd0f max_arch_pfn = 0x400000000
[ 0.006170] esrt: Reserving ESRT space from 0x000000004e31d818 to 0x000000004e31d8a0.
[ 0.006176] Scanning 1 areas for low memory corruption
[ 0.006179] Using GB pages for direct mapping
[ 0.006510] Secure boot disabled
[ 0.006511] RAMDISK: [mem 0x3406e000-0x34ceffff]
[ 0.006513] ACPI: Early table checksum verification disabled
[ 0.006515] ACPI: RSDP 0x000000004FD0D014 000024 (v02 INSYDE)
[ 0.006517] ACPI: XSDT 0x000000004FCC3188 0000DC (v01 INSYDE H2O BIOS 00000001 01000013)
[ 0.006521] ACPI: FACP 0x000000004FCF6000 00010C (v05 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006524] ACPI: DSDT 0x000000004FCC5000 02DD87 (v02 INTEL SKL 00000000 INTL 20160422)
[ 0.006526] ACPI: FACS 0x000000004FC4C000 000040
[ 0.006527] ACPI: UEFI 0x000000004FD0C000 000236 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006529] ACPI: SSDT 0x000000004FD0A000 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
[ 0.006531] ACPI: SSDT 0x000000004FD06000 0035B2 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
[ 0.006532] ACPI: SSDT 0x000000004FD04000 00187A (v02 PegSsd PegSsdt 00001000 INTL 20160422)
[ 0.006534] ACPI: UEFI 0x000000004FD03000 000042 (v01 INTEL CFL 00000002 01000013)
[ 0.006536] ACPI: SSDT 0x000000004FD02000 00046F (v02 Intel_ Tpm2Tabl 00001000 INTL 20160422)
[ 0.006537] ACPI: SSDT 0x000000004FD01000 000046 (v02 MeSsdt MeSsdt 00003000 INTL 20160422)
[ 0.006539] ACPI: TPM2 0x000000004FD00000 000034 (v03 INTEL EDK2 00000002 01000013)
[ 0.006540] ACPI: LPIT 0x000000004FCFE000 000094 (v01 INTEL CFL 00000002 01000013)
[ 0.006542] ACPI: WSMT 0x000000004FCFD000 000028 (v01 INTEL CFL 00000002 01000013)
[ 0.006543] ACPI: SSDT 0x000000004FCFB000 00166A (v02 INTEL PtidDevc 00001000 INTL 20160422)
[ 0.006545] ACPI: DBGP 0x000000004FCFA000 000034 (v01 INSYDE 00000002 ACPI 00040000)
[ 0.006547] ACPI: DBG2 0x000000004FCF9000 000061 (v00 INSYDE 00000002 ACPI 00040000)
[ 0.006548] ACPI: SSDT 0x000000004FCF8000 00045A (v02 Intel PerfTune 00001000 INTL 20160422)
[ 0.006550] ACPI: ASF! 0x000000004FCF7000 0000A5 (v32 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006552] ACPI: HPET 0x000000004FCF5000 000038 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006553] ACPI: APIC 0x000000004FCF4000 00012C (v03 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006555] ACPI: MCFG 0x000000004FCF3000 00003C (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006556] ACPI: DMAR 0x000000004FCC4000 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.006558] ACPI: SSDT 0x000000004FCBF000 0035BA (v01 Insyde NvdTable 00001000 INTL 20160422)
[ 0.006559] ACPI: FPDT 0x000000004FCBE000 000044 (v01 INTEL CFL 00000002 01000013)
[ 0.006561] ACPI: BGRT 0x000000004FCBD000 000038 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006562] ACPI: Reserving FACP table memory at [mem 0x4fcf6000-0x4fcf610b]
[ 0.006563] ACPI: Reserving DSDT table memory at [mem 0x4fcc5000-0x4fcf2d86]
[ 0.006563] ACPI: Reserving FACS table memory at [mem 0x4fc4c000-0x4fc4c03f]
[ 0.006564] ACPI: Reserving UEFI table memory at [mem 0x4fd0c000-0x4fd0c235]
[ 0.006564] ACPI: Reserving SSDT table memory at [mem 0x4fd0a000-0x4fd0bb1b]
[ 0.006565] ACPI: Reserving SSDT table memory at [mem 0x4fd06000-0x4fd095b1]
[ 0.006565] ACPI: Reserving SSDT table memory at [mem 0x4fd04000-0x4fd05879]
[ 0.006566] ACPI: Reserving UEFI table memory at [mem 0x4fd03000-0x4fd03041]
[ 0.006566] ACPI: Reserving SSDT table memory at [mem 0x4fd02000-0x4fd0246e]
[ 0.006566] ACPI: Reserving SSDT table memory at [mem 0x4fd01000-0x4fd01045]
[ 0.006567] ACPI: Reserving TPM2 table memory at [mem 0x4fd00000-0x4fd00033]
[ 0.006567] ACPI: Reserving LPIT table memory at [mem 0x4fcfe000-0x4fcfe093]
[ 0.006568] ACPI: Reserving WSMT table memory at [mem 0x4fcfd000-0x4fcfd027]
[ 0.006568] ACPI: Reserving SSDT table memory at [mem 0x4fcfb000-0x4fcfc669]
[ 0.006569] ACPI: Reserving DBGP table memory at [mem 0x4fcfa000-0x4fcfa033]
[ 0.006569] ACPI: Reserving DBG2 table memory at [mem 0x4fcf9000-0x4fcf9060]
[ 0.006569] ACPI: Reserving SSDT table memory at [mem 0x4fcf8000-0x4fcf8459]
[ 0.006570] ACPI: Reserving ASF! table memory at [mem 0x4fcf7000-0x4fcf70a4]
[ 0.006570] ACPI: Reserving HPET table memory at [mem 0x4fcf5000-0x4fcf5037]
[ 0.006571] ACPI: Reserving APIC table memory at [mem 0x4fcf4000-0x4fcf412b]
[ 0.006571] ACPI: Reserving MCFG table memory at [mem 0x4fcf3000-0x4fcf303b]
[ 0.006572] ACPI: Reserving DMAR table memory at [mem 0x4fcc4000-0x4fcc40a7]
[ 0.006572] ACPI: Reserving SSDT table memory at [mem 0x4fcbf000-0x4fcc25b9]
[ 0.006573] ACPI: Reserving FPDT table memory at [mem 0x4fcbe000-0x4fcbe043]
[ 0.006573] ACPI: Reserving BGRT table memory at [mem 0x4fcbd000-0x4fcbd037]
[ 0.006582] ACPI: Local APIC address 0xfee00000
[ 0.006725] No NUMA configuration found
[ 0.006726] Faking a node at [mem 0x0000000000000000-0x00000004a07fffff]
[ 0.006728] NODE_DATA(0) allocated [mem 0x4a07fc000-0x4a07fffff]
[ 0.006750] Zone ranges:
[ 0.006751] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.006751] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.006752] Normal [mem 0x0000000100000000-0x00000004a07fffff]
[ 0.006753] Device empty
[ 0.006753] Movable zone start for each node
[ 0.006753] Early memory node ranges
[ 0.006754] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.006754] node 0: [mem 0x0000000000100000-0x0000000037456fff]
[ 0.006755] node 0: [mem 0x0000000037d57000-0x000000004df6dfff]
[ 0.006755] node 0: [mem 0x000000004fd0e000-0x000000004fd0efff]
[ 0.006755] node 0: [mem 0x0000000100000000-0x00000004a07fffff]
[ 0.007148] Zeroed struct page in unavailable ranges: 41459 pages
[ 0.007149] Initmem setup node 0 [mem 0x0000000000001000-0x00000004a07fffff]
[ 0.007150] On node 0 totalpages: 4120077
[ 0.007151] DMA zone: 64 pages used for memmap
[ 0.007151] DMA zone: 22 pages reserved
[ 0.007152] DMA zone: 3998 pages, LIFO batch:0
[ 0.007212] DMA32 zone: 4890 pages used for memmap
[ 0.007213] DMA32 zone: 312943 pages, LIFO batch:63
[ 0.013323] Normal zone: 59424 pages used for memmap
[ 0.013323] Normal zone: 3803136 pages, LIFO batch:63
[ 0.064440] Reserving Intel graphics memory at [mem 0x59800000-0x5d7fffff]
[ 0.064808] ACPI: PM-Timer IO Port: 0x1808
[ 0.064809] ACPI: Local APIC address 0xfee00000
[ 0.064813] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.064814] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.064814] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.064814] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.064815] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.064815] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.064815] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.064816] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.064816] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.064816] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.064816] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.064817] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.064817] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.064817] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.064818] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.064818] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.064856] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.064858] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.064859] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.064859] ACPI: IRQ0 used by override.
[ 0.064860] ACPI: IRQ9 used by override.
[ 0.064861] Using ACPI (MADT) for SMP configuration information
[ 0.064862] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.064867] e820: update [mem 0x3dd21000-0x3ddd7fff] usable ==> reserved
[ 0.064872] TSC deadline timer available
[ 0.064873] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.064885] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.064886] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.064887] PM: Registered nosave memory: [mem 0x37457000-0x37d56fff]
[ 0.064888] PM: Registered nosave memory: [mem 0x3dd21000-0x3ddd7fff]
[ 0.064888] PM: Registered nosave memory: [mem 0x4df6e000-0x4e16dfff]
[ 0.064889] PM: Registered nosave memory: [mem 0x4e16e000-0x4f59dfff]
[ 0.064889] PM: Registered nosave memory: [mem 0x4f59e000-0x4fc8dfff]
[ 0.064889] PM: Registered nosave memory: [mem 0x4fc8e000-0x4fd0dfff]
[ 0.064890] PM: Registered nosave memory: [mem 0x4fd0f000-0x5d7fffff]
[ 0.064891] PM: Registered nosave memory: [mem 0x5d800000-0xdfffffff]
[ 0.064891] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.064891] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.064891] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.064892] PM: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[ 0.064892] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ 0.064892] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[ 0.064893] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[ 0.064893] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[ 0.064893] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.064893] PM: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[ 0.064894] PM: Registered nosave memory: [mem 0xff600000-0xffffffff]
[ 0.064895] [mem 0x5d800000-0xdfffffff] available for PCI devices
[ 0.064895] Booting paravirtualized kernel on bare hardware
[ 0.064897] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.142009] random: get_random_bytes called from start_kernel+0x84/0x515 with crng_init=0
[ 0.142016] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.142126] percpu: Embedded 51 pages/cpu s172032 r8192 d28672 u524288
[ 0.142131] pcpu-alloc: s172032 r8192 d28672 u524288 alloc=1*2097152
[ 0.142132] pcpu-alloc: [0] 0 1 2 3
[ 0.142144] Built 1 zonelists, mobility grouping on. Total pages: 4055677
[ 0.142144] Policy zone: Normal
[ 0.142146] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=d4df29af-139e-4d27-b026-f8345840a53f rw quiet resume=/dev/disk/by-uuid/7805e5b0-f80b-4d8e-8bb8-5d9f1ef1d2d7 udev.log_priority=3
[ 0.144480] Calgary: detecting Calgary via BIOS EBDA area
[ 0.144481] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.169075] Memory: 16049856K/16480308K available (12300K kernel code, 1367K rwdata, 3576K rodata, 1624K init, 3672K bss, 430452K reserved, 0K cma-reserved)
[ 0.169131] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.169136] Kernel/User page tables isolation: enabled
[ 0.175380] ftrace: allocating 35541 entries in 139 pages
[ 0.184947] rcu: Hierarchical RCU implementation.
[ 0.184947] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.184948] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.185892] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.186260] Console: colour dummy device 80x25
[ 0.186263] console [tty0] enabled
[ 0.186271] ACPI: Core revision 20180810
[ 0.186565] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.186604] hpet clockevent registered
[ 0.186654] APIC: Switch to symmetric I/O mode setup
[ 0.186656] DMAR: Host address width 39
[ 0.186656] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.186659] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.186660] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.186662] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.186663] DMAR: RMRR base: 0x0000004f573000 end: 0x0000004f592fff
[ 0.186663] DMAR: RMRR base: 0x00000059000000 end: 0x0000005d7fffff
[ 0.186664] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.186665] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.186665] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.188235] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.188236] x2apic enabled
[ 0.188261] Switched APIC routing to cluster x2apic.
[ 0.193033] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.236620] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d51a4e4511, max_idle_ns: 881590775377 ns
[ 0.236628] Calibrating delay loop (skipped), value calculated using timer frequency.. 7584.00 BogoMIPS (lpj=37920000)
[ 0.236629] pid_max: default: 32768 minimum: 301
[ 0.237315] Security Framework initialized
[ 0.237316] Yama: becoming mindful.
[ 0.237320] AppArmor: AppArmor disabled by boot time parameter
[ 0.238601] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.239267] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.239294] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.239314] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.239441] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.239441] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.239461] CPU0: Thermal monitoring enabled (TM1)
[ 0.239474] process: using mwait in idle threads
[ 0.239475] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.239476] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.239477] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.239478] Spectre V2 : Mitigation: Full generic retpoline
[ 0.239478] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.239478] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.239483] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.239484] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.239485] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.239502] SRBDS: Mitigation: Microcode
[ 0.239502] MDS: Mitigation: Clear CPU buffers
[ 0.242998] Freeing SMP alternatives memory: 32K
[ 0.247977] smpboot: CPU0: Intel(R) Pentium(R) Gold G5420 CPU @ 3.80GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.248054] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.248082] ... version: 4
[ 0.248083] ... bit width: 48
[ 0.248083] ... generic registers: 4
[ 0.248084] ... value mask: 0000ffffffffffff
[ 0.248084] ... max period: 00007fffffffffff
[ 0.248084] ... fixed-purpose events: 3
[ 0.248085] ... event mask: 000000070000000f
[ 0.248120] rcu: Hierarchical SRCU implementation.
[ 0.248889] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.248928] smp: Bringing up secondary CPUs ...
[ 0.248988] x86: Booting SMP configuration:
[ 0.248989] .... node #0, CPUs: #1 #2
[ 0.250264] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.250264] #3
[ 0.250264] smp: Brought up 1 node, 4 CPUs
[ 0.250264] smpboot: Max logical packages: 1
[ 0.250264] smpboot: Total of 4 processors activated (30336.00 BogoMIPS)
[ 0.250264] devtmpfs: initialized
[ 0.250264] x86/mm: Memory block size: 128MB
[ 0.256846] PM: Registering ACPI NVS region [mem 0x4f59e000-0x4fc8dfff] (7274496 bytes)
[ 0.256846] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.256846] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.256846] pinctrl core: initialized pinctrl subsystem
[ 0.256989] RTC time: 14:24:22, date: 01/02/22
[ 0.257086] NET: Registered protocol family 16
[ 0.257148] audit: initializing netlink subsys (disabled)
[ 0.257152] audit: type=2000 audit(1641133462.080:1): state=initialized audit_enabled=0 res=1
[ 0.257152] cpuidle: using governor ladder
[ 0.257152] cpuidle: using governor menu
[ 0.257152] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.257152] ACPI: bus type PCI registered
[ 0.257152] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.257152] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.257152] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.257152] PCI: Using configuration type 1 for base access
[ 0.257383] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.257383] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.257383] ACPI: Added _OSI(Module Device)
[ 0.257383] ACPI: Added _OSI(Processor Device)
[ 0.257383] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.257383] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.257383] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.257383] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.290187] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.296640] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.299696] ACPI: Dynamic OEM Table Load:
[ 0.299696] ACPI: SSDT 0xFFFF991ECE39C100 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160422)
[ 0.299696] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.299696] ACPI: SSDT 0xFFFF991ECDE09C00 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
[ 0.299696] ACPI: SSDT 0xFFFF991ECE37F000 0006EC (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
[ 0.299696] ACPI: SSDT 0xFFFF991ECDE07800 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160422)
[ 0.299696] ACPI: SSDT 0xFFFF991ECE37B800 000724 (v02 PmRef HwpLvt 00003000 INTL 20160422)
[ 0.299696] ACPI: SSDT 0xFFFF991ECE30D000 0005FC (v02 PmRef ApIst 00003000 INTL 20160422)
[ 0.299696] ACPI: SSDT 0xFFFF991ECDE0B800 000317 (v02 PmRef ApHwp 00003000 INTL 20160422)
[ 0.306880] ACPI: Dynamic OEM Table Load:
[ 0.306886] ACPI: SSDT 0xFFFF991ECE35D000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160422)
[ 0.307663] ACPI: Dynamic OEM Table Load:
[ 0.307663] ACPI: SSDT 0xFFFF991ECDE09000 00030A (v02 PmRef ApCst 00003000 INTL 20160422)
[ 0.307663] ACPI: EC: EC started
[ 0.307663] ACPI: EC: interrupt blocked
[ 0.307663] ACPI: \_SB_.PCI0.LPCB.EC__: Used as first EC
[ 0.307663] ACPI: \_SB_.PCI0.LPCB.EC__: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.307663] ACPI: \_SB_.PCI0.LPCB.EC__: Used as boot DSDT EC to handle transactions
[ 0.307663] ACPI: Interpreter enabled
[ 0.307663] ACPI: (supports S0 S3 S4 S5)
[ 0.307663] ACPI: Using IOAPIC for interrupt routing
[ 0.307663] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.307804] ACPI: Enabled 6 GPEs in block 00 to 7F
[ 0.307917] ACPI: Power Resource [PG00] (on)
[ 0.354818] ACPI: Power Resource [V0PR] (on)
[ 0.354905] ACPI: Power Resource [V1PR] (on)
[ 0.354988] ACPI: Power Resource [V2PR] (on)
[ 0.355619] ACPI: Power Resource [WRST] (on)
[ 0.357475] ACPI: Power Resource [PIN] (off)
[ 0.357776] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.357780] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.359924] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[ 0.359925] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.361958] PCI host bridge to bus 0000:00
[ 0.361959] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.361960] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.361961] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.361961] pci_bus 0000:00: root bus resource [mem 0x5d800000-0xdfffffff window]
[ 0.361962] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.361963] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.361968] pci 0000:00:00.0: [8086:3e0f] type 00 class 0x060000
[ 0.362737] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.362768] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.363600] pci 0000:00:02.0: [8086:3e90] type 00 class 0x030000
[ 0.363607] pci 0000:00:02.0: reg 0x10: [mem 0xd2000000-0xd2ffffff 64bit]
[ 0.363611] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0xbfffffff 64bit pref]
[ 0.363613] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.363624] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.364471] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.364491] pci 0000:00:12.0: reg 0x10: [mem 0xd451c000-0xd451cfff 64bit]
[ 0.365337] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.365353] pci 0000:00:14.0: reg 0x10: [mem 0xd4500000-0xd450ffff 64bit]
[ 0.365403] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.366197] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.366215] pci 0000:00:14.2: reg 0x10: [mem 0xd4518000-0xd4519fff 64bit]
[ 0.366226] pci 0000:00:14.2: reg 0x18: [mem 0xd451d000-0xd451dfff 64bit]
[ 0.367032] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[ 0.367068] pci 0000:00:14.3: reg 0x10: [mem 0xd4510000-0xd4513fff 64bit]
[ 0.367159] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.367962] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.367984] pci 0000:00:16.0: reg 0x10: [mem 0xd451e000-0xd451efff 64bit]
[ 0.368050] pci 0000:00:16.0: PME# supported from D3hot
[ 0.368866] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.368882] pci 0000:00:17.0: reg 0x10: [mem 0xd451a000-0xd451bfff]
[ 0.368887] pci 0000:00:17.0: reg 0x14: [mem 0xd4522000-0xd45220ff]
[ 0.368893] pci 0000:00:17.0: reg 0x18: [io 0x5080-0x5087]
[ 0.368899] pci 0000:00:17.0: reg 0x1c: [io 0x5088-0x508b]
[ 0.368904] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.368910] pci 0000:00:17.0: reg 0x24: [mem 0xd4521000-0xd45217ff]
[ 0.368942] pci 0000:00:17.0: PME# supported from D3hot
[ 0.369768] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[ 0.369846] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.369862] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 0.370703] pci 0000:00:1c.0: [8086:a33c] type 01 class 0x060400
[ 0.370771] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.370784] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.371619] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.371698] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.371713] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.372556] pci 0000:00:1f.0: [8086:a304] type 00 class 0x060100
[ 0.373494] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.373534] pci 0000:00:1f.3: reg 0x10: [mem 0xd4514000-0xd4517fff 64bit]
[ 0.373570] pci 0000:00:1f.3: reg 0x20: [mem 0xd4100000-0xd41fffff 64bit]
[ 0.373644] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.374486] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.374511] pci 0000:00:1f.4: reg 0x10: [mem 0xd451f000-0xd451f0ff 64bit]
[ 0.374537] pci 0000:00:1f.4: reg 0x20: [io 0x5040-0x505f]
[ 0.375335] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.375348] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.376170] pci 0000:01:00.0: [10de:1f91] type 00 class 0x030000
[ 0.376186] pci 0000:01:00.0: reg 0x10: [mem 0xd3000000-0xd3ffffff]
[ 0.376194] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.376201] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.376206] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.376212] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.376252] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.376277] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8 GT/s x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[ 0.376324] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.376335] pci 0000:01:00.1: reg 0x10: [mem 0xd4000000-0xd4003fff]
[ 0.376441] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.376442] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.376444] pci 0000:00:01.0: bridge window [mem 0xd3000000-0xd40fffff]
[ 0.376446] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.376514] pci 0000:02:00.0: [144d:a808] type 00 class 0x010802
[ 0.376540] pci 0000:02:00.0: reg 0x10: [mem 0xd4400000-0xd4403fff 64bit]
[ 0.376728] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.376731] pci 0000:00:1b.0: bridge window [mem 0xd4400000-0xd44fffff]
[ 0.376787] pci 0000:03:00.0: [10ec:5287] type 00 class 0xff0000
[ 0.376813] pci 0000:03:00.0: reg 0x10: [mem 0xd4305000-0xd4305fff]
[ 0.376868] pci 0000:03:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
[ 0.376950] pci 0000:03:00.0: supports D1 D2
[ 0.376950] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.377038] pci 0000:03:00.1: [10ec:8168] type 00 class 0x020000
[ 0.377063] pci 0000:03:00.1: reg 0x10: [io 0x3000-0x30ff]
[ 0.377087] pci 0000:03:00.1: reg 0x18: [mem 0xd4304000-0xd4304fff 64bit]
[ 0.377102] pci 0000:03:00.1: reg 0x20: [mem 0xd4300000-0xd4303fff 64bit]
[ 0.377190] pci 0000:03:00.1: supports D1 D2
[ 0.377191] pci 0000:03:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.377302] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.377304] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.377305] pci 0000:00:1c.0: bridge window [mem 0xd4300000-0xd43fffff]
[ 0.377448] pci 0000:04:00.0: [8086:f1a8] type 00 class 0x010802
[ 0.377477] pci 0000:04:00.0: reg 0x10: [mem 0xd4200000-0xd4203fff 64bit]
[ 0.406672] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.406681] pci 0000:00:1d.0: bridge window [mem 0xd4200000-0xd42fffff]
[ 0.727393] ACPI: EC: interrupt unblocked
[ 0.727412] ACPI: EC: event unblocked
[ 0.727429] ACPI: \_SB_.PCI0.LPCB.EC__: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.727429] ACPI: \_SB_.PCI0.LPCB.EC__: Used as boot DSDT EC to handle transactions and events
[ 0.727478] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.727478] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.727478] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.727478] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.727478] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.727478] vgaarb: loaded
[ 0.727478] ACPI: bus type USB registered
[ 0.727478] usbcore: registered new interface driver usbfs
[ 0.727478] usbcore: registered new interface driver hub
[ 0.727478] usbcore: registered new device driver usb
[ 0.727478] pps_core: LinuxPPS API ver. 1 registered
[ 0.727478] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.727478] PTP clock support registered
[ 0.727478] EDAC MC: Ver: 3.0.0
[ 0.727478] Registered efivars operations
[ 0.727478] PCI: Using ACPI for IRQ routing
[ 0.776619] PCI: pci_cache_line_size set to 64 bytes
[ 0.776747] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.776748] e820: reserve RAM buffer [mem 0x37457000-0x37ffffff]
[ 0.776748] e820: reserve RAM buffer [mem 0x3dd21000-0x3fffffff]
[ 0.776749] e820: reserve RAM buffer [mem 0x4df6e000-0x4fffffff]
[ 0.776749] e820: reserve RAM buffer [mem 0x4fd0f000-0x4fffffff]
[ 0.776750] e820: reserve RAM buffer [mem 0x4a0800000-0x4a3ffffff]
[ 0.776804] NetLabel: Initializing
[ 0.776804] NetLabel: domain hash size = 128
[ 0.776805] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.776812] NetLabel: unlabeled traffic allowed by default
[ 0.777416] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.777418] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.779466] clocksource: Switched to clocksource tsc-early
[ 0.785210] VFS: Disk quotas dquot_6.6.0
[ 0.785217] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.785257] pnp: PnP ACPI init
[ 0.785513] system 00:00: [io 0x1800-0x18fe] has been reserved
[ 0.785514] system 00:00: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.785515] system 00:00: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.785515] system 00:00: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.785516] system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.785517] system 00:00: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.785518] system 00:00: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.785520] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.785759] system 00:01: [io 0x2000-0x20fe] has been reserved
[ 0.785760] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.785799] pnp 00:02: disabling [io 0x3322-0x3323] because it overlaps 0000:00:1c.0 BAR 13 [io 0x3000-0x3fff]
[ 0.785814] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.785814] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.785816] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.785830] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.785899] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.785901] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.785918] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.785968] pnp 00:06: Plug and Play ACPI device, IDs SYN1222 PNP0f13 (active)
[ 0.786201] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.786202] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.786203] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.786203] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.786204] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.786205] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.786205] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.786206] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.786208] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.096979] pnp: PnP ACPI: found 8 devices
[ 1.102180] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.102183] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 1.102184] pci 0000:03:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[ 1.102190] pci 0000:01:00.0: BAR 6: assigned [mem 0xd4080000-0xd40fffff pref]
[ 1.102191] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.102192] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 1.102194] pci 0000:00:01.0: bridge window [mem 0xd3000000-0xd40fffff]
[ 1.102195] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 1.102198] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 1.102206] pci 0000:00:1b.0: bridge window [mem 0xd4400000-0xd44fffff]
[ 1.102211] pci 0000:03:00.0: BAR 6: assigned [mem 0xd4310000-0xd431ffff pref]
[ 1.102212] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 1.102213] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 1.102215] pci 0000:00:1c.0: bridge window [mem 0xd4300000-0xd43fffff]
[ 1.102220] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 1.102224] pci 0000:00:1d.0: bridge window [mem 0xd4200000-0xd42fffff]
[ 1.102229] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 1.102230] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 1.102230] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.102231] pci_bus 0000:00: resource 7 [mem 0x5d800000-0xdfffffff window]
[ 1.102232] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 1.102232] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 1.102233] pci_bus 0000:01: resource 1 [mem 0xd3000000-0xd40fffff]
[ 1.102233] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 1.102234] pci_bus 0000:02: resource 1 [mem 0xd4400000-0xd44fffff]
[ 1.102235] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 1.102235] pci_bus 0000:03: resource 1 [mem 0xd4300000-0xd43fffff]
[ 1.102236] pci_bus 0000:04: resource 1 [mem 0xd4200000-0xd42fffff]
[ 1.102336] NET: Registered protocol family 2
[ 1.102470] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.103656] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.103683] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.103776] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.103844] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.103863] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.103886] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.103936] NET: Registered protocol family 1
[ 1.103939] NET: Registered protocol family 44
[ 1.103946] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.105389] pci 0000:01:00.1: Linked as a consumer to 0000:01:00.0
[ 1.105389] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 1.105511] PCI: CLS 64 bytes, default 64
[ 1.105555] Unpacking initramfs...
[ 1.193832] Freeing initrd memory: 12808K
[ 1.246682] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.246686] software IO TLB: mapped [mem 0x492d9000-0x4d2d9000] (64MB)
[ 1.246765] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d51a4e4511, max_idle_ns: 881590775377 ns
[ 1.246795] clocksource: Switched to clocksource tsc
[ 1.246968] Scanning for low memory corruption every 60 seconds
[ 1.247306] Initialise system trusted keyrings
[ 1.247313] Key type blacklist registered
[ 1.247343] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 1.247940] zbud: loaded
[ 1.248760] Key type asymmetric registered
[ 1.248761] Asymmetric key parser 'x509' registered
[ 1.248766] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.248779] io scheduler noop registered
[ 1.248779] io scheduler deadline registered
[ 1.248796] io scheduler cfq registered
[ 1.248796] io scheduler mq-deadline registered
[ 1.248797] io scheduler kyber registered
[ 1.248808] io scheduler bfq registered
[ 1.248818] io scheduler bfq-sq registered (default)
[ 1.248818] BFQ I/O-scheduler: v10 (with cgroups support)
[ 1.248828] io scheduler bfq-mq registered
[ 1.248828] BFQ I/O-scheduler: v10 (with cgroups support)
[ 1.249270] pcieport 0000:00:01.0: Signaling PME with IRQ 122
[ 1.249416] pcieport 0000:00:1b.0: Signaling PME with IRQ 123
[ 1.249434] pcieport 0000:00:1b.0: AER enabled with IRQ 123
[ 1.249465] dpc 0000:00:1b.0:pcie008: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.249606] pcieport 0000:00:1c.0: Signaling PME with IRQ 124
[ 1.249751] pcieport 0000:00:1d.0: Signaling PME with IRQ 125
[ 1.249769] pcieport 0000:00:1d.0: AER enabled with IRQ 125
[ 1.249794] dpc 0000:00:1d.0:pcie008: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.249834] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.249874] efifb: probing for efifb
[ 1.249885] efifb: showing boot graphics
[ 1.250653] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 1.250654] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 1.250654] efifb: scrolling: redraw
[ 1.250655] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.250675] fbcon: Deferring console take-over
[ 1.250675] fb0: EFI VGA frame buffer device
[ 1.250679] intel_idle: MWAIT substates: 0x11142120
[ 1.250680] intel_idle: v0.4.1 model 0x9E
[ 1.250784] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.250835] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.250843] ACPI: Power Button [PWRB]
[ 1.250864] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 1.250870] ACPI: Sleep Button [SLPB]
[ 1.250889] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 1.250894] ACPI: Lid Switch [LID0]
[ 1.250916] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.250921] ACPI: Power Button [PWRF]
[ 1.251519] ACPI: Invalid active0 threshold
[ 1.251623] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.251623] ACPI: Thermal Zone [TZ0] (45 C)
[ 1.251744] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.252054] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.252054] AMD IOMMUv2 functionality not available on this system
[ 1.252303] nvme nvme0: pci function 0000:02:00.0
[ 1.252330] nvme nvme1: pci function 0000:04:00.0
[ 1.252351] usbcore: registered new interface driver usbserial_generic
[ 1.252354] usbserial: USB Serial support registered for generic
[ 1.252487] rtc_cmos 00:03: RTC can wake from S4
[ 1.253520] rtc_cmos 00:03: registered as rtc0
[ 1.253529] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.253559] intel_pstate: Intel P-state driver initializing
[ 1.253567] intel_pstate: Disabling energy efficiency optimization
[ 1.253689] intel_pstate: HWP enabled
[ 1.253710] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.253735] intel_pmc_core: initialized
[ 1.253852] NET: Registered protocol family 10
[ 1.257374] Segment Routing with IPv6
[ 1.257388] NET: Registered protocol family 17
[ 1.257536] mce: Using 10 MCE banks
[ 1.257545] RAS: Correctable Errors collector initialized.
[ 1.257570] microcode: sig=0x906ea, pf=0x2, revision=0xea
[ 1.257600] microcode: Microcode Update Driver: v2.2.
[ 1.257606] sched_clock: Marking stable (1267221696, -9624423)->(1266038401, -8441128)
[ 1.257717] registered taskstats version 1
[ 1.257722] Loading compiled-in X.509 certificates
[ 1.259819] Loaded X.509 cert 'Build time autogenerated kernel key: e7d5591365240a64cbdfe99af1c0c86748d66d16'
[ 1.259831] zswap: loaded using pool lzo/zbud
[ 1.263175] Key type big_key registered
[ 1.264120] Magic number: 6:975:433
[ 1.264305] rtc_cmos 00:03: setting system clock to 2022-01-02 14:24:23 UTC (1641133463)
[ 1.488121] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1.491317] nvme0n1: p1
[ 1.505263] nvme1n1: p1 p2 p3 p4 p5
[ 1.751332] Freeing unused decrypted memory: 2040K
[ 1.920005] Freeing unused kernel image memory: 1624K
[ 1.957405] Write protecting the kernel read-only data: 18432k
[ 1.958261] Freeing unused kernel image memory: 2008K
[ 1.958386] Freeing unused kernel image memory: 520K
[ 1.965138] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.965138] x86/mm: Checking user space page tables
[ 1.971704] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.971705] Run /init as init process
[ 2.061357] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:SENM] at 0x60,0x64 irq 1,12
[ 2.689504] SCSI subsystem initialized
[ 2.690784] i8042: Detected active multiplexing controller, rev 1.1
[ 2.692930] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.692934] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 2.692936] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 2.692938] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 2.692939] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 2.693013] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.693017] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 2.694091] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 2.694094] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 2.694248] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.694249] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.694250] usb usb1: Product: xHCI Host Controller
[ 2.694251] usb usb1: Manufacturer: Linux 4.19.220-1-MANJARO xhci-hcd
[ 2.694252] usb usb1: SerialNumber: 0000:00:14.0
[ 2.694359] hub 1-0:1.0: USB hub found
[ 2.694375] hub 1-0:1.0: 16 ports detected
[ 2.695854] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.695855] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.695857] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.695898] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.695898] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.695899] usb usb2: Product: xHCI Host Controller
[ 2.695900] usb usb2: Manufacturer: Linux 4.19.220-1-MANJARO xhci-hcd
[ 2.695900] usb usb2: SerialNumber: 0000:00:14.0
[ 2.696138] hub 2-0:1.0: USB hub found
[ 2.696151] hub 2-0:1.0: 8 ports detected
[ 2.696683] usb: port power management may be unreliable
[ 2.698204] random: fast init done
[ 2.698354] libata version 3.00 loaded.
[ 2.699335] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 2.700852] ahci 0000:00:17.0: version 3.0
[ 2.701119] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x10 impl SATA mode
[ 2.701124] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[ 2.701651] scsi host0: ahci
[ 2.701730] scsi host1: ahci
[ 2.701789] scsi host2: ahci
[ 2.701843] scsi host3: ahci
[ 2.701895] scsi host4: ahci
[ 2.701936] ata1: DUMMY
[ 2.701936] ata2: DUMMY
[ 2.701937] ata3: DUMMY
[ 2.701937] ata4: DUMMY
[ 2.701943] ata5: SATA max UDMA/133 abar m2048@0xd4521000 port 0xd4521300 irq 138
[ 2.986728] usb 1-5: new low-speed USB device number 2 using xhci_hcd
[ 3.027176] ata5: SATA link down (SStatus 4 SControl 300)
[ 3.064218] PM: Image not found (code -22)
[ 3.123653] EXT4-fs (nvme1n1p4): mounted filesystem with ordered data mode. Opts: (null)
[ 3.181639] usb 1-5: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
[ 3.181644] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.181648] usb 1-5: Product: Usb Mouse
[ 3.181651] usb 1-5: Manufacturer: SIGMACHIP
[ 3.222973] cgroup: cgroup2: unknown option "memory_recursiveprot"
[ 3.226280] systemd[1]: systemd 249.7-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 3.247415] systemd[1]: Detected architecture x86-64.
[ 3.247793] systemd[1]: Hostname set to <tol-pc>.
[ 3.313145] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 3.336631] usb 1-8: new high-speed USB device number 3 using xhci_hcd
[ 3.381105] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
[ 3.382434] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.383333] systemd[1]: Created slice Slice /system/getty.
[ 3.383506] systemd[1]: Created slice Slice /system/modprobe.
[ 3.383661] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 3.383760] systemd[1]: Created slice User and Session Slice.
[ 3.383814] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.383850] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.384041] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.384068] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.384080] systemd[1]: Reached target Login Prompts.
[ 3.384096] systemd[1]: Reached target Path Units.
[ 3.384106] systemd[1]: Reached target Remote File Systems.
[ 3.384116] systemd[1]: Reached target Slice Units.
[ 3.384136] systemd[1]: Reached target Local Verity Protected Volumes.
[ 3.384184] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.384356] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.385134] systemd[1]: Listening on Process Core Dump Socket.
[ 3.385634] systemd[1]: Listening on Journal Audit Socket.
[ 3.385698] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.385763] systemd[1]: Listening on Journal Socket.
[ 3.385840] systemd[1]: Listening on udev Control Socket.
[ 3.385891] systemd[1]: Listening on udev Kernel Socket.
[ 3.386350] systemd[1]: Mounting Huge Pages File System...
[ 3.386775] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.387212] systemd[1]: Mounting Kernel Debug File System...
[ 3.387855] systemd[1]: Mounting Kernel Trace File System...
[ 3.388681] systemd[1]: Starting Create List of Static Device Nodes...
[ 3.389308] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.389984] systemd[1]: Starting Load Kernel Module configfs...
[ 3.390679] systemd[1]: Starting Load Kernel Module drm...
[ 3.391436] systemd[1]: Starting Load Kernel Module fuse...
[ 3.392260] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.392382] systemd[1]: Starting Set Up Additional Binary Formats...
[ 3.392428] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.393830] systemd[1]: Starting Load Kernel Modules...
[ 3.394493] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.394556] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 3.395233] systemd[1]: Starting Coldplug All udev Devices...
[ 3.396587] systemd[1]: Mounted Huge Pages File System.
[ 3.396712] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.396797] systemd[1]: Mounted Kernel Debug File System.
[ 3.396886] systemd[1]: Mounted Kernel Trace File System.
[ 3.397169] systemd[1]: Finished Create List of Static Device Nodes.
[ 3.397453] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 3.397594] systemd[1]: Finished Load Kernel Module configfs.
[ 3.397824] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.397965] systemd[1]: Finished Load Kernel Module drm.
[ 3.398117] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 226 (systemd-binfmt)
[ 3.398727] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 3.399311] acpi_call: loading out-of-tree module taints kernel.
[ 3.399325] acpi_call: module verification failed: signature and/or required key missing - tainting kernel
[ 3.399352] systemd[1]: Mounting Kernel Configuration File System...
[ 3.401833] EXT4-fs (nvme1n1p4): re-mounted. Opts: (null)
[ 3.403668] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.403796] systemd[1]: Mounted Kernel Configuration File System.
[ 3.403884] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 3.404775] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 3.405364] systemd[1]: Starting Load/Save Random Seed...
[ 3.405423] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 3.405899] fuse init (API version 7.27)
[ 3.406100] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.406316] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 3.406909] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 3.407068] systemd[1]: Finished Load Kernel Module fuse.
[ 3.407369] systemd[1]: Finished Set Up Additional Binary Formats.
[ 3.408111] systemd[1]: Mounting FUSE Control File System...
[ 3.411898] systemd[1]: Mounted FUSE Control File System.
[ 3.420891] vboxdrv: Found 4 processor cores
[ 3.431587] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 3.432670] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 3.433786] systemd[1]: Starting Journal Service...
[ 3.434926] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 3.446765] vboxdrv: TSC mode is Invariant, tentative frequency 3791998854 Hz
[ 3.446766] vboxdrv: Successfully loaded version 6.1.30 r148432 (interface 0x00320000)
[ 3.447665] VBoxNetAdp: Successfully started.
[ 3.449741] VBoxNetFlt: Successfully started.
[ 3.457580] Linux agpgart interface v0.103
[ 3.465455] systemd[1]: Finished Coldplug All udev Devices.
[ 3.465488] audit: type=1130 audit(1641133465.689:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.474872] systemd[1]: Started Journal Service.
[ 3.474933] audit: type=1130 audit(1641133465.699:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.480276] systemd-journald[240]: Received client request to flush runtime journal.
[ 3.511888] audit: type=1130 audit(1641133465.739:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.537773] audit: type=1130 audit(1641133465.769:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.542113] usb 1-8: New USB device found, idVendor=5986, idProduct=9102, bcdDevice= 6.01
[ 3.542114] usb 1-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 3.542116] usb 1-8: Product: BisonCam,NB Pro
[ 3.542117] usb 1-8: Manufacturer: Sonix Technology Co., Ltd.
[ 3.546893] audit: type=1130 audit(1641133465.779:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.607465] ACPI: AC Adapter [AC] (on-line)
[ 3.633960] input: Intel HID events as /devices/platform/INT33D5:00/input/input9
[ 3.655390] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.655392] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.655393] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.655394] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.670581] nvidia: module license 'NVIDIA' taints kernel.
[ 3.670583] Disabling lock debugging due to kernel taint
[ 3.686638] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[ 3.767327] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 3.770238] nvidia 0000:01:00.0: enabling device (0106 -> 0107)
[ 3.770325] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.781498] pci 0000:01:00.1: Dropping the link to 0000:01:00.0
[ 3.813070] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.44 Fri Oct 22 06:13:12 UTC 2021
[ 3.823718] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 3.837566] nvidia-uvm: Loaded the UVM driver, major device number 237.
[ 3.841231] audit: type=1130 audit(1641133466.069:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.847664] audit: type=1130 audit(1641133466.079:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.867574] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.867576] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.970840] random: crng init done
[ 3.974844] audit: type=1130 audit(1641133466.199:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4.030643] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.056654] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.44 Fri Oct 22 06:05:22 UTC 2021
[ 4.058830] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.058831] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 4.080771] VFIO - User Level meta-driver version: 0.3
[ 4.083873] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 4.093550] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 4.095380] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.101850] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.276349] Intel(R) Wireless WiFi driver for Linux
[ 4.276350] Copyright(c) 2003- 2015 Intel Corporation
[ 4.291424] iwlwifi 0000:00:14.3: loaded firmware version 38.755cfdd8.0 op_mode iwlmvm
[ 4.302368] Setting dangerous option enable_fbc - tainting kernel
[ 4.303707] checking generic (80000000 7f0000) vs hw (80000000 40000000)
[ 4.303709] fb: switching to inteldrmfb from EFI VGA
[ 4.303840] [drm] Replacing VGA console driver
[ 4.330897] Adding 16881660k swap on /dev/nvme1n1p3. Priority:-2 extents:1 across:16881660k SSFS
[ 4.336636] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.336637] [drm] Driver supports precise vblank timestamp query.
[ 4.345670] audit: type=1130 audit(1641133466.569:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-745C\x2d3287 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4.349461] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 4.368110] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 1
[ 4.368210] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 4.368445] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input10
[ 4.369977] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.370116] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input11
[ 4.370252] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.374925] fbcon: inteldrmfb (fb0) is primary device
[ 4.374925] fbcon: Deferring console take-over
[ 4.374928] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 4.447334] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 4.447387] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 4.461770] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 4.461855] input: PC Speaker as /devices/platform/pcspkr/input/input13
[ 4.488768] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.488770] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.488771] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 4.488771] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.488772] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.488773] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 4.488774] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 4.488774] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 4.494871] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9462, REV=0x318
[ 4.499126] libphy: r8169: probed
[ 4.499407] r8169 0000:03:00.1 eth0: RTL8411, 80:fa:5b:73:1f:22, XID 5c800800, IRQ 148
[ 4.499408] r8169 0000:03:00.1 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 4.503575] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 4.503576] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 4.503577] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 4.503577] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 4.503578] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 4.503578] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 4.523626] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 4.524850] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 4.524897] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 4.524937] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 4.524976] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 4.525012] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 4.525048] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 4.525084] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 4.525121] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 4.528905] cryptd: max_cpu_qlen set to 1000
[ 4.545093] iwlwifi 0000:00:14.3: base HW address: 04:ed:33:2d:74:8b
[ 4.662586] SSE version of gcm_enc/dec engaged.
[ 4.675917] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 4.676116] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 5.189821] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 5.298404] iTCO_vendor_support: vendor-support=0
[ 5.300476] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 5.300509] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[ 5.300515] iTCO_wdt: probe of iTCO_wdt failed with error -16
[ 5.389361] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.394768] media: Linux media interface: v0.10
[ 5.396187] usbcore: registered new interface driver usbhid
[ 5.396188] usbhid: USB HID core driver
[ 5.401668] kauditd_printk_skb: 4 callbacks suppressed
[ 5.401669] audit: type=1130 audit(1641133467.629:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.403946] audit: type=1130 audit(1641133467.629:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.405945] audit: type=1130 audit(1641133467.629:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.409375] videodev: Linux video capture interface: v2.00
[ 5.445604] audit: type=1101 audit(1641133467.669:18): pid=701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.446207] audit: type=1110 audit(1641133467.669:19): pid=701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.451622] audit: type=1105 audit(1641133467.679:20): pid=701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.453453] audit: type=1106 audit(1641133467.679:21): pid=701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.453851] audit: type=1104 audit(1641133467.679:22): pid=701 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.511177] uvcvideo: Found UVC 1.00 device BisonCam,NB Pro (5986:9102)
[ 5.518070] input: BisonCam,NB Pro: BisonCam,NB Pr as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input24
[ 5.518110] usbcore: registered new interface driver uvcvideo
[ 5.518110] USB Video Class driver (1.1.1)
[ 5.522819] audit: type=1130 audit(1641133467.749:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.523321] audit: type=1130 audit(1641133467.749:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.563691] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 5.638160] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1C4F:0034.0001/input/input25
[ 5.638245] hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:14.0-5/input0
[ 5.641045] intel_rapl: Found RAPL domain package
[ 5.641046] intel_rapl: Found RAPL domain core
[ 5.641047] intel_rapl: Found RAPL domain uncore
[ 5.641047] intel_rapl: Found RAPL domain dram
[ 5.648973] mousedev: PS/2 mouse device common for all mice
[ 5.659124] psmouse serio2: synaptics: queried max coordinates: x [..5674], y [..4764]
[ 5.782226] psmouse serio2: synaptics: queried min coordinates: x [1266..], y [1086..]
[ 5.782231] psmouse serio2: synaptics: Your touchpad (PNP: SYN1222 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 5.867881] Bluetooth: Core ver 2.22
[ 5.867899] NET: Registered protocol family 31
[ 5.867900] Bluetooth: HCI device and connection manager initialized
[ 5.867903] Bluetooth: HCI socket layer initialized
[ 5.867905] Bluetooth: L2CAP socket layer initialized
[ 5.867908] Bluetooth: SCO socket layer initialized
[ 5.879612] usbcore: registered new interface driver btusb
[ 5.880465] Bluetooth: hci0: Firmware revision 0.1 build 207 week 35 2021
[ 6.217640] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 6.258107] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.258109] Bluetooth: BNEP filters: protocol multicast
[ 6.258111] Bluetooth: BNEP socket layer initialized
[ 6.264699] NET: Registered protocol family 38
[ 6.268467] psmouse serio2: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2b1, caps: 0xf00223/0x840300/0x26800/0x0, board id: 3189, fw id: 2302754
[ 6.306247] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input14
[ 6.508042] IPv6: ADDRCONF(NETDEV_UP): enp3s0f1: link is not ready
[ 6.508675] Generic PHY r8169-301:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-301:00, irq=IGNORE)
[ 6.652361] IPv6: ADDRCONF(NETDEV_UP): enp3s0f1: link is not ready
[ 6.665711] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[ 6.832546] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 6.838281] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[ 6.838837] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[ 7.019472] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 7.025335] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[ 7.025822] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[ 7.180432] IPv6: ADDRCONF(NETDEV_UP): wlp0s20f3: link is not ready
[ 9.412327] Bluetooth: RFCOMM TTY layer initialized
[ 9.412331] Bluetooth: RFCOMM socket layer initialized
[ 9.412335] Bluetooth: RFCOMM ver 1.11
[ 11.228744] kauditd_printk_skb: 47 callbacks suppressed
[ 11.228748] audit: type=1131 audit(1641133473.459:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.012014] audit: type=1131 audit(1641133479.239:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.528044] audit: type=1131 audit(1641133498.759:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 73.830365] audit: type=1100 audit(1641133536.059:75): pid=1366 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tol" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 73.831169] audit: type=1101 audit(1641133536.059:76): pid=1366 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tol" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 73.831677] audit: type=1110 audit(1641133536.059:77): pid=1366 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 73.833168] audit: type=1105 audit(1641133536.059:78): pid=1366 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
(continued)
KERNEL 5 (hot and loud, but can copy files):
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MAIBENBEN product: HeiMai 7 v: N/A
Mobo: MAIBENBEN model: HeiMai 7 serial: <superuser required> UEFI: INSYDE
v: 1.07.01TOYC date: 04/15/2019
ID-1: BAT0 charge: 40.8 Wh (90.7%) condition: 45.0/47.5 Wh (94.7%)
volts: 12.2 min: 10.8 model: Notebook BAT type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Pentium Gold G5420 bits: 64 type: MT MCP
arch: Coffee Lake family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 30409
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Device-1: Intel CoffeeLake-S GT1 [UHD Graphics 610] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e90 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 135 size: 360x200mm (14.2x7.9")
diag: 412mm (16.2")
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.4 TiB used: 808.49 GiB (56.5%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXA7301Q temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 30.9 C scheme: MBR
ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 63.21 GiB (64.5%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 32.3 MiB (32.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 45.0 C pch: 56.0 C mobo: N/A
Processes: 208 Uptime: 0m wakeups: 1 Memory: 15.35 GiB
used: 1010.1 MiB (6.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1604 lib: 453 Shell: Bash v: 5.1.12
running-in: konsole inxi: 3.3.11
[ 0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[ 0.000000] Linux version 5.10.84-1-MANJARO (builduser@fv-az72-805) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 8 09:50:30 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d4df29af-139e-4d27-b026-f8345840a53f rw quiet resume=/dev/disk/by-uuid/7805e5b0-f80b-4d8e-8bb8-5d9f1ef1d2d7 udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[3]: 576, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 640, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000037456fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000037457000-0x0000000037d56fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000037d57000-0x000000004df6dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000004df6e000-0x000000004e16dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000004e16e000-0x000000004f59dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000004f59e000-0x000000004fc8dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000004fc8e000-0x000000004fd0dfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000004fd0e000-0x000000004fd0efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000004fd0f000-0x000000005d7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004a07fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.60 by INSYDE Corp.
[ 0.000000] efi: ACPI=0x4fd0d000 ACPI 2.0=0x4fd0d014 TPMFinalLog=0x4f595000 SMBIOS=0x4e321000 SMBIOS 3.0=0x4e31f000 ESRT=0x4e31d818 MEMATTR=0x3e4f4018
[ 0.000000] SMBIOS 3.0.1 present.
[ 0.000000] DMI: MAIBENBEN HeiMai 7/HeiMai 7, BIOS 1.07.01TOYC 04/15/2019
[ 0.000000] tsc: Detected 3800.000 MHz processor
[ 0.000000] tsc: Detected 3799.900 MHz TSC
[ 0.000005] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000007] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000012] last_pfn = 0x4a0800 max_arch_pfn = 0x400000000
[ 0.000015] MTRR default type: write-back
[ 0.000015] MTRR fixed ranges enabled:
[ 0.000016] 00000-9FFFF write-back
[ 0.000017] A0000-BFFFF uncachable
[ 0.000017] C0000-FFFFF write-protect
[ 0.000018] MTRR variable ranges enabled:
[ 0.000019] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000019] 1 base 0060000000 mask 7FE0000000 uncachable
[ 0.000020] 2 base 005C000000 mask 7FFC000000 uncachable
[ 0.000020] 3 base 005A000000 mask 7FFE000000 uncachable
[ 0.000021] 4 base 0059000000 mask 7FFF000000 uncachable
[ 0.000022] 5 base 2000000000 mask 6000000000 uncachable
[ 0.000022] 6 base 1000000000 mask 7000000000 uncachable
[ 0.000023] 7 base 0800000000 mask 7800000000 uncachable
[ 0.000023] 8 base 4000000000 mask 4000000000 uncachable
[ 0.000024] 9 disabled
[ 0.000370] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000644] last_pfn = 0x4fd0f max_arch_pfn = 0x400000000
[ 0.006240] esrt: Reserving ESRT space from 0x000000004e31d818 to 0x000000004e31d8a0.
[ 0.006247] check: Scanning 1 areas for low memory corruption
[ 0.006250] Using GB pages for direct mapping
[ 0.006544] Secure boot disabled
[ 0.006544] RAMDISK: [mem 0x340ed000-0x34ceffff]
[ 0.006547] ACPI: Early table checksum verification disabled
[ 0.006549] ACPI: RSDP 0x000000004FD0D014 000024 (v02 INSYDE)
[ 0.006552] ACPI: XSDT 0x000000004FCC3188 0000DC (v01 INSYDE H2O BIOS 00000001 01000013)
[ 0.006556] ACPI: FACP 0x000000004FCF6000 00010C (v05 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006560] ACPI: DSDT 0x000000004FCC5000 02DD87 (v02 INTEL SKL 00000000 INTL 20160422)
[ 0.006562] ACPI: FACS 0x000000004FC4C000 000040
[ 0.006564] ACPI: UEFI 0x000000004FD0C000 000236 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006566] ACPI: SSDT 0x000000004FD0A000 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
[ 0.006568] ACPI: SSDT 0x000000004FD06000 0035B2 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
[ 0.006570] ACPI: SSDT 0x000000004FD04000 00187A (v02 PegSsd PegSsdt 00001000 INTL 20160422)
[ 0.006572] ACPI: UEFI 0x000000004FD03000 000042 (v01 INTEL CFL 00000002 01000013)
[ 0.006574] ACPI: SSDT 0x000000004FD02000 00046F (v02 Intel_ Tpm2Tabl 00001000 INTL 20160422)
[ 0.006576] ACPI: SSDT 0x000000004FD01000 000046 (v02 MeSsdt MeSsdt 00003000 INTL 20160422)
[ 0.006578] ACPI: TPM2 0x000000004FD00000 000034 (v03 INTEL EDK2 00000002 01000013)
[ 0.006580] ACPI: LPIT 0x000000004FCFE000 000094 (v01 INTEL CFL 00000002 01000013)
[ 0.006582] ACPI: WSMT 0x000000004FCFD000 000028 (v01 INTEL CFL 00000002 01000013)
[ 0.006584] ACPI: SSDT 0x000000004FCFB000 00166A (v02 INTEL PtidDevc 00001000 INTL 20160422)
[ 0.006586] ACPI: DBGP 0x000000004FCFA000 000034 (v01 INSYDE 00000002 ACPI 00040000)
[ 0.006588] ACPI: DBG2 0x000000004FCF9000 000061 (v00 INSYDE 00000002 ACPI 00040000)
[ 0.006590] ACPI: SSDT 0x000000004FCF8000 00045A (v02 Intel PerfTune 00001000 INTL 20160422)
[ 0.006593] ACPI: ASF! 0x000000004FCF7000 0000A5 (v32 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006595] ACPI: HPET 0x000000004FCF5000 000038 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006597] ACPI: APIC 0x000000004FCF4000 00012C (v03 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006599] ACPI: MCFG 0x000000004FCF3000 00003C (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006601] ACPI: DMAR 0x000000004FCC4000 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.006603] ACPI: SSDT 0x000000004FCBF000 0035BA (v01 Insyde NvdTable 00001000 INTL 20160422)
[ 0.006605] ACPI: FPDT 0x000000004FCBE000 000044 (v01 INTEL CFL 00000002 01000013)
[ 0.006607] ACPI: BGRT 0x000000004FCBD000 000038 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000)
[ 0.006609] ACPI: Reserving FACP table memory at [mem 0x4fcf6000-0x4fcf610b]
[ 0.006609] ACPI: Reserving DSDT table memory at [mem 0x4fcc5000-0x4fcf2d86]
[ 0.006610] ACPI: Reserving FACS table memory at [mem 0x4fc4c000-0x4fc4c03f]
[ 0.006611] ACPI: Reserving UEFI table memory at [mem 0x4fd0c000-0x4fd0c235]
[ 0.006611] ACPI: Reserving SSDT table memory at [mem 0x4fd0a000-0x4fd0bb1b]
[ 0.006612] ACPI: Reserving SSDT table memory at [mem 0x4fd06000-0x4fd095b1]
[ 0.006612] ACPI: Reserving SSDT table memory at [mem 0x4fd04000-0x4fd05879]
[ 0.006613] ACPI: Reserving UEFI table memory at [mem 0x4fd03000-0x4fd03041]
[ 0.006614] ACPI: Reserving SSDT table memory at [mem 0x4fd02000-0x4fd0246e]
[ 0.006614] ACPI: Reserving SSDT table memory at [mem 0x4fd01000-0x4fd01045]
[ 0.006615] ACPI: Reserving TPM2 table memory at [mem 0x4fd00000-0x4fd00033]
[ 0.006615] ACPI: Reserving LPIT table memory at [mem 0x4fcfe000-0x4fcfe093]
[ 0.006616] ACPI: Reserving WSMT table memory at [mem 0x4fcfd000-0x4fcfd027]
[ 0.006617] ACPI: Reserving SSDT table memory at [mem 0x4fcfb000-0x4fcfc669]
[ 0.006617] ACPI: Reserving DBGP table memory at [mem 0x4fcfa000-0x4fcfa033]
[ 0.006618] ACPI: Reserving DBG2 table memory at [mem 0x4fcf9000-0x4fcf9060]
[ 0.006619] ACPI: Reserving SSDT table memory at [mem 0x4fcf8000-0x4fcf8459]
[ 0.006619] ACPI: Reserving ASF! table memory at [mem 0x4fcf7000-0x4fcf70a4]
[ 0.006620] ACPI: Reserving HPET table memory at [mem 0x4fcf5000-0x4fcf5037]
[ 0.006621] ACPI: Reserving APIC table memory at [mem 0x4fcf4000-0x4fcf412b]
[ 0.006621] ACPI: Reserving MCFG table memory at [mem 0x4fcf3000-0x4fcf303b]
[ 0.006622] ACPI: Reserving DMAR table memory at [mem 0x4fcc4000-0x4fcc40a7]
[ 0.006623] ACPI: Reserving SSDT table memory at [mem 0x4fcbf000-0x4fcc25b9]
[ 0.006623] ACPI: Reserving FPDT table memory at [mem 0x4fcbe000-0x4fcbe043]
[ 0.006624] ACPI: Reserving BGRT table memory at [mem 0x4fcbd000-0x4fcbd037]
[ 0.006633] ACPI: Local APIC address 0xfee00000
[ 0.006776] No NUMA configuration found
[ 0.006777] Faking a node at [mem 0x0000000000000000-0x00000004a07fffff]
[ 0.006779] NODE_DATA(0) allocated [mem 0x4a07fc000-0x4a07fffff]
[ 0.025363] Zone ranges:
[ 0.025364] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.025365] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.025366] Normal [mem 0x0000000100000000-0x00000004a07fffff]
[ 0.025367] Device empty
[ 0.025368] Movable zone start for each node
[ 0.025368] Early memory node ranges
[ 0.025369] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.025370] node 0: [mem 0x0000000000100000-0x0000000037456fff]
[ 0.025370] node 0: [mem 0x0000000037d57000-0x000000004df6dfff]
[ 0.025371] node 0: [mem 0x000000004fd0e000-0x000000004fd0efff]
[ 0.025371] node 0: [mem 0x0000000100000000-0x00000004a07fffff]
[ 0.025373] Initmem setup node 0 [mem 0x0000000000001000-0x00000004a07fffff]
[ 0.025374] On node 0 totalpages: 4120077
[ 0.025375] DMA zone: 64 pages used for memmap
[ 0.025375] DMA zone: 22 pages reserved
[ 0.025376] DMA zone: 3998 pages, LIFO batch:0
[ 0.025377] DMA32 zone: 4890 pages used for memmap
[ 0.025377] DMA32 zone: 312943 pages, LIFO batch:63
[ 0.025378] Normal zone: 59424 pages used for memmap
[ 0.025378] Normal zone: 3803136 pages, LIFO batch:63
[ 0.025380] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.025396] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.026791] On node 0, zone DMA32: 2304 pages in unavailable ranges
[ 0.026838] On node 0, zone DMA32: 7584 pages in unavailable ranges
[ 0.044037] On node 0, zone Normal: 753 pages in unavailable ranges
[ 0.044235] On node 0, zone Normal: 30720 pages in unavailable ranges
[ 0.044261] Reserving Intel graphics memory at [mem 0x59800000-0x5d7fffff]
[ 0.044628] ACPI: PM-Timer IO Port: 0x1808
[ 0.044629] ACPI: Local APIC address 0xfee00000
[ 0.044633] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.044634] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.044634] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.044635] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.044635] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.044636] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.044636] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.044637] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.044637] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.044638] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.044638] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.044638] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.044639] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.044639] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.044640] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.044640] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.044676] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.044677] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.044678] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.044679] ACPI: IRQ0 used by override.
[ 0.044680] ACPI: IRQ9 used by override.
[ 0.044681] Using ACPI (MADT) for SMP configuration information
[ 0.044682] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.044686] e820: update [mem 0x3dd21000-0x3ddd7fff] usable ==> reserved
[ 0.044692] TSC deadline timer available
[ 0.044692] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.044707] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.044708] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.044709] PM: hibernation: Registered nosave memory: [mem 0x37457000-0x37d56fff]
[ 0.044711] PM: hibernation: Registered nosave memory: [mem 0x3dd21000-0x3ddd7fff]
[ 0.044712] PM: hibernation: Registered nosave memory: [mem 0x4df6e000-0x4e16dfff]
[ 0.044712] PM: hibernation: Registered nosave memory: [mem 0x4e16e000-0x4f59dfff]
[ 0.044713] PM: hibernation: Registered nosave memory: [mem 0x4f59e000-0x4fc8dfff]
[ 0.044713] PM: hibernation: Registered nosave memory: [mem 0x4fc8e000-0x4fd0dfff]
[ 0.044714] PM: hibernation: Registered nosave memory: [mem 0x4fd0f000-0x5d7fffff]
[ 0.044715] PM: hibernation: Registered nosave memory: [mem 0x5d800000-0xdfffffff]
[ 0.044715] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.044716] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.044716] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.044716] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[ 0.044717] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ 0.044717] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[ 0.044718] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[ 0.044718] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[ 0.044719] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.044719] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[ 0.044719] PM: hibernation: Registered nosave memory: [mem 0xff600000-0xffffffff]
[ 0.044721] [mem 0x5d800000-0xdfffffff] available for PCI devices
[ 0.044721] Booting paravirtualized kernel on bare hardware
[ 0.044723] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.048245] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.048349] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[ 0.048354] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[ 0.048355] pcpu-alloc: [0] 0 1 2 3
[ 0.048370] Built 1 zonelists, mobility grouping on. Total pages: 4055677
[ 0.048371] Policy zone: Normal
[ 0.048372] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d4df29af-139e-4d27-b026-f8345840a53f rw quiet resume=/dev/disk/by-uuid/7805e5b0-f80b-4d8e-8bb8-5d9f1ef1d2d7 udev.log_priority=3
[ 0.048987] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.049267] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.049302] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.075926] Memory: 16015148K/16480308K available (14344K kernel code, 2065K rwdata, 9168K rodata, 1740K init, 4204K bss, 464900K reserved, 0K cma-reserved)
[ 0.075931] random: get_random_u64 called from __kmem_cache_create+0x2a/0x4c0 with crng_init=0
[ 0.076009] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.076019] Kernel/User page tables isolation: enabled
[ 0.076032] ftrace: allocating 41939 entries in 164 pages
[ 0.086247] ftrace: allocated 164 pages with 3 groups
[ 0.086312] rcu: Preemptible hierarchical RCU implementation.
[ 0.086312] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.086313] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.086314] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.086314] Trampoline variant of Tasks RCU enabled.
[ 0.086315] Rude variant of Tasks RCU enabled.
[ 0.086315] Tracing variant of Tasks RCU enabled.
[ 0.086316] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.086316] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.088717] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.089228] Console: colour dummy device 80x25
[ 0.089238] printk: console [tty0] enabled
[ 0.089250] ACPI: Core revision 20200925
[ 0.089508] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.089595] APIC: Switch to symmetric I/O mode setup
[ 0.089597] DMAR: Host address width 39
[ 0.089598] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.089601] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.089602] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.089604] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.089605] DMAR: RMRR base: 0x0000004f573000 end: 0x0000004f592fff
[ 0.089609] DMAR: RMRR base: 0x00000059000000 end: 0x0000005d7fffff
[ 0.089611] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.089612] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.089613] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.091172] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.091173] x2apic enabled
[ 0.091197] Switched APIC routing to cluster x2apic.
[ 0.095948] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.109520] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d8bf270d8d, max_idle_ns: 881590865083 ns
[ 0.109523] Calibrating delay loop (skipped), value calculated using timer frequency.. 7602.45 BogoMIPS (lpj=12666333)
[ 0.109525] pid_max: default: 32768 minimum: 301
[ 0.111580] LSM: Security Framework initializing
[ 0.111585] Yama: becoming mindful.
[ 0.111614] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.111630] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.111822] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.111837] process: using mwait in idle threads
[ 0.111839] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.111839] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.111841] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.111842] Spectre V2 : Mitigation: Full generic retpoline
[ 0.111843] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.111843] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.111844] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.111845] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.111846] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.111849] SRBDS: Mitigation: Microcode
[ 0.111850] MDS: Mitigation: Clear CPU buffers
[ 0.112021] Freeing SMP alternatives memory: 36K
[ 0.112954] smpboot: CPU0: Intel(R) Pentium(R) Gold G5420 CPU @ 3.80GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.113072] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.113084] ... version: 4
[ 0.113085] ... bit width: 48
[ 0.113086] ... generic registers: 4
[ 0.113086] ... value mask: 0000ffffffffffff
[ 0.113087] ... max period: 00007fffffffffff
[ 0.113088] ... fixed-purpose events: 3
[ 0.113088] ... event mask: 000000070000000f
[ 0.113188] rcu: Hierarchical SRCU implementation.
[ 0.113830] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.113873] smp: Bringing up secondary CPUs ...
[ 0.113971] x86: Booting SMP configuration:
[ 0.113972] .... node #0, CPUs: #1 #2
[ 0.117246] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.117246] #3
[ 0.117605] smp: Brought up 1 node, 4 CPUs
[ 0.117605] smpboot: Max logical packages: 1
[ 0.117605] smpboot: Total of 4 processors activated (30411.83 BogoMIPS)
[ 0.119847] devtmpfs: initialized
[ 0.119847] x86/mm: Memory block size: 128MB
[ 0.120357] PM: Registering ACPI NVS region [mem 0x4f59e000-0x4fc8dfff] (7274496 bytes)
[ 0.120357] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.120357] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.120357] pinctrl core: initialized pinctrl subsystem
[ 0.120357] PM: RTC time: 14:27:58, date: 2022-01-02
[ 0.120357] NET: Registered protocol family 16
[ 0.120357] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.120394] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.120523] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.120534] audit: initializing netlink subsys (disabled)
[ 0.120555] audit: type=2000 audit(1641133678.029:1): state=initialized audit_enabled=0 res=1
[ 0.120555] thermal_sys: Registered thermal governor 'fair_share'
[ 0.120555] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.120555] thermal_sys: Registered thermal governor 'step_wise'
[ 0.120555] thermal_sys: Registered thermal governor 'user_space'
[ 0.120555] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.120555] cpuidle: using governor ladder
[ 0.120555] cpuidle: using governor menu
[ 0.120555] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.120555] ACPI: bus type PCI registered
[ 0.120555] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.120555] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.120555] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.120555] PCI: Using configuration type 1 for base access
[ 0.120555] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.120555] Kprobes globally optimized
[ 0.122875] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.122875] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.122940] ACPI: Added _OSI(Module Device)
[ 0.122941] ACPI: Added _OSI(Processor Device)
[ 0.122941] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.122942] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.122943] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.122944] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.122945] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.160160] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.162218] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.167314] ACPI: Dynamic OEM Table Load:
[ 0.167321] ACPI: SSDT 0xFFFF97B840CF9500 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160422)
[ 0.168390] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.169057] ACPI: Dynamic OEM Table Load:
[ 0.169062] ACPI: SSDT 0xFFFF97B840D2AC00 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
[ 0.170224] ACPI: Dynamic OEM Table Load:
[ 0.170229] ACPI: SSDT 0xFFFF97B840B3F000 0006EC (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
[ 0.171477] ACPI: Dynamic OEM Table Load:
[ 0.171481] ACPI: SSDT 0xFFFF97B84113CC00 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160422)
[ 0.172539] ACPI: Dynamic OEM Table Load:
[ 0.172544] ACPI: SSDT 0xFFFF97B840B38800 000724 (v02 PmRef HwpLvt 00003000 INTL 20160422)
[ 0.173852] ACPI: Dynamic OEM Table Load:
[ 0.173856] ACPI: SSDT 0xFFFF97B840B3D800 0005FC (v02 PmRef ApIst 00003000 INTL 20160422)
[ 0.175059] ACPI: Dynamic OEM Table Load:
[ 0.175063] ACPI: SSDT 0xFFFF97B840D2A400 000317 (v02 PmRef ApHwp 00003000 INTL 20160422)
[ 0.176292] ACPI: Dynamic OEM Table Load:
[ 0.176297] ACPI: SSDT 0xFFFF97B840B8B000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160422)
[ 0.177966] ACPI: Dynamic OEM Table Load:
[ 0.177970] ACPI: SSDT 0xFFFF97B840D2B000 00030A (v02 PmRef ApCst 00003000 INTL 20160422)
[ 0.180094] ACPI: EC: EC started
[ 0.180094] ACPI: EC: interrupt blocked
[ 0.181051] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.181052] ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
[ 0.181052] ACPI: Interpreter enabled
[ 0.181088] ACPI: (supports S0 S3 S4 S5)
[ 0.181089] ACPI: Using IOAPIC for interrupt routing
[ 0.181120] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.181439] ACPI: Enabled 6 GPEs in block 00 to 7F
[ 0.181965] ACPI: Power Resource [PG00] (on)
[ 0.216166] ACPI: Power Resource [V0PR] (on)
[ 0.216258] ACPI: Power Resource [V1PR] (on)
[ 0.216347] ACPI: Power Resource [V2PR] (on)
[ 0.216996] ACPI: Power Resource [WRST] (on)
[ 0.218912] ACPI: Power Resource [PIN] (off)
[ 0.219229] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.219233] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.221403] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.221404] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.223426] PCI host bridge to bus 0000:00
[ 0.223427] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.223428] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.223429] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.223429] pci_bus 0000:00: root bus resource [mem 0x5d800000-0xdfffffff window]
[ 0.223430] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.223431] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.223447] pci 0000:00:00.0: [8086:3e0f] type 00 class 0x060000
[ 0.224190] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.224222] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.225152] pci 0000:00:02.0: [8086:3e90] type 00 class 0x030000
[ 0.225158] pci 0000:00:02.0: reg 0x10: [mem 0xd2000000-0xd2ffffff 64bit]
[ 0.225161] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0xbfffffff 64bit pref]
[ 0.225164] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.225175] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.226030] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.226046] pci 0000:00:12.0: reg 0x10: [mem 0xd451c000-0xd451cfff 64bit]
[ 0.226886] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.226899] pci 0000:00:14.0: reg 0x10: [mem 0xd4500000-0xd450ffff 64bit]
[ 0.226950] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.227780] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.227796] pci 0000:00:14.2: reg 0x10: [mem 0xd4518000-0xd4519fff 64bit]
[ 0.227806] pci 0000:00:14.2: reg 0x18: [mem 0xd451d000-0xd451dfff 64bit]
[ 0.228598] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[ 0.228619] pci 0000:00:14.3: reg 0x10: [mem 0xd4510000-0xd4513fff 64bit]
[ 0.228715] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.229536] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.229553] pci 0000:00:16.0: reg 0x10: [mem 0xd451e000-0xd451efff 64bit]
[ 0.229620] pci 0000:00:16.0: PME# supported from D3hot
[ 0.230452] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.230464] pci 0000:00:17.0: reg 0x10: [mem 0xd451a000-0xd451bfff]
[ 0.230471] pci 0000:00:17.0: reg 0x14: [mem 0xd4522000-0xd45220ff]
[ 0.230477] pci 0000:00:17.0: reg 0x18: [io 0x5080-0x5087]
[ 0.230483] pci 0000:00:17.0: reg 0x1c: [io 0x5088-0x508b]
[ 0.230488] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.230494] pci 0000:00:17.0: reg 0x24: [mem 0xd4521000-0xd45217ff]
[ 0.230527] pci 0000:00:17.0: PME# supported from D3hot
[ 0.231412] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[ 0.231491] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.231514] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 0.232480] pci 0000:00:1c.0: [8086:a33c] type 01 class 0x060400
[ 0.232549] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.232569] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.233533] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.233613] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.233636] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.234600] pci 0000:00:1f.0: [8086:a304] type 00 class 0x060100
[ 0.235556] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.235585] pci 0000:00:1f.3: reg 0x10: [mem 0xd4514000-0xd4517fff 64bit]
[ 0.235621] pci 0000:00:1f.3: reg 0x20: [mem 0xd4100000-0xd41fffff 64bit]
[ 0.235696] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.236615] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.236637] pci 0000:00:1f.4: reg 0x10: [mem 0xd451f000-0xd451f0ff 64bit]
[ 0.236664] pci 0000:00:1f.4: reg 0x20: [io 0x5040-0x505f]
[ 0.237477] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.237490] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.238305] pci 0000:01:00.0: [10de:1f91] type 00 class 0x030000
[ 0.238314] pci 0000:01:00.0: reg 0x10: [mem 0xd3000000-0xd3ffffff]
[ 0.238322] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.238329] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.238334] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.238339] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.238383] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.238426] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.238501] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.238510] pci 0000:01:00.1: reg 0x10: [mem 0xd4000000-0xd4003fff]
[ 0.238615] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.238616] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.238617] pci 0000:00:01.0: bridge window [mem 0xd3000000-0xd40fffff]
[ 0.238619] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.238698] pci 0000:02:00.0: [144d:a808] type 00 class 0x010802
[ 0.238716] pci 0000:02:00.0: reg 0x10: [mem 0xd4400000-0xd4403fff 64bit]
[ 0.238922] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.238926] pci 0000:00:1b.0: bridge window [mem 0xd4400000-0xd44fffff]
[ 0.238989] pci 0000:03:00.0: [10ec:5287] type 00 class 0xff0000
[ 0.239006] pci 0000:03:00.0: reg 0x10: [mem 0xd4305000-0xd4305fff]
[ 0.239061] pci 0000:03:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
[ 0.239153] pci 0000:03:00.0: supports D1 D2
[ 0.239154] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.239281] pci 0000:03:00.1: [10ec:8168] type 00 class 0x020000
[ 0.239298] pci 0000:03:00.1: reg 0x10: [io 0x3000-0x30ff]
[ 0.239322] pci 0000:03:00.1: reg 0x18: [mem 0xd4304000-0xd4304fff 64bit]
[ 0.239337] pci 0000:03:00.1: reg 0x20: [mem 0xd4300000-0xd4303fff 64bit]
[ 0.239433] pci 0000:03:00.1: supports D1 D2
[ 0.239434] pci 0000:03:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.239552] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.239554] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.239556] pci 0000:00:1c.0: bridge window [mem 0xd4300000-0xd43fffff]
[ 0.239706] pci 0000:04:00.0: [8086:f1a8] type 00 class 0x010802
[ 0.239728] pci 0000:04:00.0: reg 0x10: [mem 0xd4200000-0xd4203fff 64bit]
[ 0.249569] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.249578] pci 0000:00:1d.0: bridge window [mem 0xd4200000-0xd42fffff]
[ 0.570172] ACPI: EC: interrupt unblocked
[ 0.570173] ACPI: EC: event unblocked
[ 0.570188] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.570188] ACPI: EC: GPE=0x3
[ 0.570190] ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
[ 0.570190] ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
[ 0.570242] iommu: Default domain type: Translated
[ 0.570249] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.570249] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.570249] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.570249] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.570249] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.570249] vgaarb: loaded
[ 0.570249] SCSI subsystem initialized
[ 0.570249] libata version 3.00 loaded.
[ 0.570249] ACPI: bus type USB registered
[ 0.570249] usbcore: registered new interface driver usbfs
[ 0.570249] usbcore: registered new interface driver hub
[ 0.570249] usbcore: registered new device driver usb
[ 0.570249] pps_core: LinuxPPS API ver. 1 registered
[ 0.570249] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.570249] PTP clock support registered
[ 0.570249] EDAC MC: Ver: 3.0.0
[ 0.570249] Registered efivars operations
[ 0.570249] NetLabel: Initializing
[ 0.570249] NetLabel: domain hash size = 128
[ 0.570249] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.570249] NetLabel: unlabeled traffic allowed by default
[ 0.570249] PCI: Using ACPI for IRQ routing
[ 0.614794] PCI: pci_cache_line_size set to 64 bytes
[ 0.614922] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.614923] e820: reserve RAM buffer [mem 0x37457000-0x37ffffff]
[ 0.614924] e820: reserve RAM buffer [mem 0x3dd21000-0x3fffffff]
[ 0.614924] e820: reserve RAM buffer [mem 0x4df6e000-0x4fffffff]
[ 0.614925] e820: reserve RAM buffer [mem 0x4fd0f000-0x4fffffff]
[ 0.614926] e820: reserve RAM buffer [mem 0x4a0800000-0x4a3ffffff]
[ 0.614929] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.614929] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.619522] clocksource: Switched to clocksource tsc-early
[ 0.626730] VFS: Disk quotas dquot_6.6.0
[ 0.626740] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.626788] pnp: PnP ACPI init
[ 0.627071] system 00:00: [io 0x1800-0x18fe] has been reserved
[ 0.627072] system 00:00: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.627073] system 00:00: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.627074] system 00:00: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.627075] system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.627076] system 00:00: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.627077] system 00:00: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.627080] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.627320] system 00:01: [io 0x2000-0x20fe] has been reserved
[ 0.627323] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.627365] pnp 00:02: disabling [io 0x3322-0x3323] because it overlaps 0000:00:1c.0 BAR 13 [io 0x3000-0x3fff]
[ 0.627382] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.627383] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.627385] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.627398] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.627471] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.627474] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.627493] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.627543] pnp 00:06: Plug and Play ACPI device, IDs SYN1222 PNP0f13 (active)
[ 0.627793] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.627794] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.627795] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.627796] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.627797] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.627797] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.627798] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.627799] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.627801] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.939885] pnp: PnP ACPI: found 8 devices
[ 0.945187] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.945222] NET: Registered protocol family 2
[ 0.945320] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.946559] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.946617] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.946734] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.946780] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.946829] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.946867] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.946896] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.947028] NET: Registered protocol family 1
[ 0.947032] NET: Registered protocol family 44
[ 0.947036] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.947038] pci 0000:03:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[ 0.947046] pci 0000:01:00.0: BAR 6: assigned [mem 0xd4080000-0xd40fffff pref]
[ 0.947047] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.947049] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.947050] pci 0000:00:01.0: bridge window [mem 0xd3000000-0xd40fffff]
[ 0.947052] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.947054] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.947063] pci 0000:00:1b.0: bridge window [mem 0xd4400000-0xd44fffff]
[ 0.947068] pci 0000:03:00.0: BAR 6: assigned [mem 0xd4310000-0xd431ffff pref]
[ 0.947069] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.947070] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.947073] pci 0000:00:1c.0: bridge window [mem 0xd4300000-0xd43fffff]
[ 0.947077] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.947081] pci 0000:00:1d.0: bridge window [mem 0xd4200000-0xd42fffff]
[ 0.947086] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.947087] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.947088] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.947089] pci_bus 0000:00: resource 7 [mem 0x5d800000-0xdfffffff window]
[ 0.947089] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.947090] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.947091] pci_bus 0000:01: resource 1 [mem 0xd3000000-0xd40fffff]
[ 0.947091] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.947092] pci_bus 0000:02: resource 1 [mem 0xd4400000-0xd44fffff]
[ 0.947093] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.947093] pci_bus 0000:03: resource 1 [mem 0xd4300000-0xd43fffff]
[ 0.947094] pci_bus 0000:04: resource 1 [mem 0xd4200000-0xd42fffff]
[ 0.947215] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.948691] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.948838] PCI: CLS 64 bytes, default 64
[ 0.948864] Trying to unpack rootfs image as initramfs...
[ 1.032318] Freeing initrd memory: 12300K
[ 1.032348] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.032349] software IO TLB: mapped [mem 0x00000000492d9000-0x000000004d2d9000] (64MB)
[ 1.032620] check: Scanning for low memory corruption every 60 seconds
[ 1.032794] Initialise system trusted keyrings
[ 1.032803] Key type blacklist registered
[ 1.032844] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 1.033499] zbud: loaded
[ 1.039312] Key type asymmetric registered
[ 1.039313] Asymmetric key parser 'x509' registered
[ 1.039317] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.039341] io scheduler mq-deadline registered
[ 1.039341] io scheduler kyber registered
[ 1.039355] io scheduler bfq registered
[ 1.039402] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 1.041642] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 1.041803] pcieport 0000:00:1b.0: PME: Signaling with IRQ 123
[ 1.041843] pcieport 0000:00:1b.0: AER: enabled with IRQ 123
[ 1.041877] pcieport 0000:00:1b.0: DPC: enabled with IRQ 123
[ 1.041879] pcieport 0000:00:1b.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.042056] pcieport 0000:00:1c.0: PME: Signaling with IRQ 124
[ 1.042217] pcieport 0000:00:1d.0: PME: Signaling with IRQ 125
[ 1.042255] pcieport 0000:00:1d.0: AER: enabled with IRQ 125
[ 1.042284] pcieport 0000:00:1d.0: DPC: enabled with IRQ 125
[ 1.042285] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.042354] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.042376] efifb: probing for efifb
[ 1.042386] efifb: showing boot graphics
[ 1.043242] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 1.043242] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 1.043243] efifb: scrolling: redraw
[ 1.043243] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.043269] fbcon: Deferring console take-over
[ 1.043270] fb0: EFI VGA frame buffer device
[ 1.043275] intel_idle: MWAIT substates: 0x11142120
[ 1.043275] intel_idle: v0.5.1 model 0x9E
[ 1.043444] intel_idle: Local APIC timer is reliable in all C-states
[ 1.043571] ACPI: AC Adapter [AC] (on-line)
[ 1.043610] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.046210] ACPI: Power Button [PWRB]
[ 1.046230] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 1.049576] ACPI: Sleep Button [SLPB]
[ 1.049599] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 1.052904] ACPI: Lid Switch [LID0]
[ 1.052931] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.056239] ACPI: Power Button [PWRF]
[ 1.057085] ACPI: Invalid active0 threshold
[ 1.057199] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.057200] ACPI: Thermal Zone [TZ0] (44 C)
[ 1.057314] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.058229] Non-volatile memory driver v1.3
[ 1.058231] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 1.058506] nvme nvme0: pci function 0000:02:00.0
[ 1.058566] nvme nvme1: pci function 0000:04:00.0
[ 1.058581] ahci 0000:00:17.0: version 3.0
[ 1.058861] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x10 impl SATA mode
[ 1.058863] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[ 1.059218] scsi host0: ahci
[ 1.059289] scsi host1: ahci
[ 1.059339] scsi host2: ahci
[ 1.059390] scsi host3: ahci
[ 1.059437] scsi host4: ahci
[ 1.059455] ata1: DUMMY
[ 1.059455] ata2: DUMMY
[ 1.059456] ata3: DUMMY
[ 1.059456] ata4: DUMMY
[ 1.059461] ata5: SATA max UDMA/133 abar m2048@0xd4521000 port 0xd4521300 irq 127
[ 1.059486] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.059489] ehci-pci: EHCI PCI platform driver
[ 1.059500] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.059502] ohci-pci: OHCI PCI platform driver
[ 1.059509] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.059537] usbcore: registered new interface driver usbserial_generic
[ 1.059540] usbserial: USB Serial support registered for generic
[ 1.059560] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:SENM] at 0x60,0x64 irq 1,12
[ 1.065196] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1.071052] nvme nvme0: 4/0/0 default/read/poll queues
[ 1.072892] nvme0n1: p1 p2 p3 p4 p5
[ 1.370083] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 1.372904] ata5: SATA link down (SStatus 4 SControl 300)
[ 1.688162] i8042: Detected active multiplexing controller, rev 1.1
[ 1.689493] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.689510] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.689520] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.689533] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.689534] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.689690] rtc_cmos 00:03: RTC can wake from S4
[ 1.690328] nvme nvme1: 4/0/0 default/read/poll queues
[ 1.690475] rtc_cmos 00:03: registered as rtc0
[ 1.690640] rtc_cmos 00:03: setting system clock to 2022-01-02T14:27:59 UTC (1641133679)
[ 1.690648] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.690680] intel_pstate: Intel P-state driver initializing
[ 1.690863] intel_pstate: Disabling energy efficiency optimization
[ 1.690864] intel_pstate: HWP enabled
[ 1.690870] nvme1n1: p1
[ 1.690892] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.691075] hid: raw HID events driver (C) Jiri Kosina
[ 1.691129] ashmem: initialized
[ 1.691205] intel_pmc_core intel_pmc_core.0: initialized
[ 1.691233] drop_monitor: Initializing network drop monitor service
[ 1.691295] Initializing XFRM netlink socket
[ 1.691350] NET: Registered protocol family 10
[ 1.691673] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.695042] Segment Routing with IPv6
[ 1.695043] RPL Segment Routing with IPv6
[ 1.695057] NET: Registered protocol family 17
[ 1.695218] microcode: sig=0x906ea, pf=0x2, revision=0xea
[ 1.695228] microcode: Microcode Update Driver: v2.2.
[ 1.695231] IPI shorthand broadcast: enabled
[ 1.695236] sched_clock: Marking stable (1694738688, 438280)->(1702869300, -7692332)
[ 1.695282] registered taskstats version 1
[ 1.695287] Loading compiled-in X.509 certificates
[ 1.697266] Loaded X.509 cert 'Build time autogenerated kernel key: 25c3f82ea3ebf755b7dd47a9b85c7dce3bd7fdf5'
[ 1.697732] zswap: loaded using pool zstd/z3fold
[ 1.697829] Key type ._fscrypt registered
[ 1.697830] Key type .fscrypt registered
[ 1.697831] Key type fscrypt-provisioning registered
[ 1.698724] PM: Magic number: 6:528:484
[ 1.698848] RAS: Correctable Errors collector initialized.
[ 1.951856] Freeing unused decrypted memory: 2036K
[ 1.952355] Freeing unused kernel image (initmem) memory: 1740K
[ 1.952433] Write protecting the kernel read-only data: 26624k
[ 1.953259] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.953661] Freeing unused kernel image (rodata/data gap) memory: 1072K
[ 1.994964] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.994967] rodata_test: all tests were successful
[ 1.994968] x86/mm: Checking user space page tables
[ 2.032905] tsc: Refined TSC clocksource calibration: 3791.990 MHz
[ 2.032909] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d519362d7b, max_idle_ns: 881590412320 ns
[ 2.032919] clocksource: Switched to clocksource tsc
[ 2.033961] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.033964] Run /init as init process
[ 2.033965] with arguments:
[ 2.033966] /init
[ 2.033966] with environment:
[ 2.033966] HOME=/
[ 2.033967] TERM=linux
[ 2.033967] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 2.142605] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.142610] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 2.143688] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 2.143694] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 2.143888] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.143889] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.143891] usb usb1: Product: xHCI Host Controller
[ 2.143892] usb usb1: Manufacturer: Linux 5.10.84-1-MANJARO xhci-hcd
[ 2.143893] usb usb1: SerialNumber: 0000:00:14.0
[ 2.144011] hub 1-0:1.0: USB hub found
[ 2.144031] hub 1-0:1.0: 16 ports detected
[ 2.146473] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.146476] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.146479] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.146515] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 2.146516] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.146517] usb usb2: Product: xHCI Host Controller
[ 2.146518] usb usb2: Manufacturer: Linux 5.10.84-1-MANJARO xhci-hcd
[ 2.146519] usb usb2: SerialNumber: 0000:00:14.0
[ 2.146610] hub 2-0:1.0: USB hub found
[ 2.146623] hub 2-0:1.0: 8 ports detected
[ 2.147255] usb: port power management may be unreliable
[ 2.164438] random: fast init done
[ 2.189582] PM: Image not found (code -22)
[ 2.225144] EXT4-fs (nvme0n1p4): mounted filesystem with ordered data mode. Opts: (null)
[ 2.355508] systemd[1]: systemd 249.7-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.370298] systemd[1]: Detected architecture x86-64.
[ 2.371299] systemd[1]: Hostname set to <tol-pc>.
[ 2.396239] usb 1-5: new low-speed USB device number 2 using xhci_hcd
[ 2.447979] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 2.541343] usb 1-5: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
[ 2.541345] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.541346] usb 1-5: Product: Usb Mouse
[ 2.541347] usb 1-5: Manufacturer: SIGMACHIP
[ 2.564710] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
[ 2.567662] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.568540] systemd[1]: Created slice Slice /system/getty.
[ 2.568753] systemd[1]: Created slice Slice /system/modprobe.
[ 2.568982] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 2.569126] systemd[1]: Created slice User and Session Slice.
[ 2.569182] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.569225] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.569343] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.569376] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.569389] systemd[1]: Reached target Login Prompts.
[ 2.569409] systemd[1]: Reached target Path Units.
[ 2.569423] systemd[1]: Reached target Remote File Systems.
[ 2.569434] systemd[1]: Reached target Slice Units.
[ 2.569462] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.569519] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.569876] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.571384] systemd[1]: Listening on Process Core Dump Socket.
[ 2.572180] systemd[1]: Listening on Journal Audit Socket.
[ 2.572308] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.572402] systemd[1]: Listening on Journal Socket.
[ 2.572513] systemd[1]: Listening on udev Control Socket.
[ 2.572582] systemd[1]: Listening on udev Kernel Socket.
[ 2.573260] systemd[1]: Mounting Huge Pages File System...
[ 2.573833] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.574448] systemd[1]: Mounting Kernel Debug File System...
[ 2.575312] systemd[1]: Mounting Kernel Trace File System...
[ 2.576365] systemd[1]: Starting Create List of Static Device Nodes...
[ 2.577210] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.578109] systemd[1]: Starting Load Kernel Module configfs...
[ 2.579066] systemd[1]: Starting Load Kernel Module drm...
[ 2.580051] systemd[1]: Starting Load Kernel Module fuse...
[ 2.580667] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.581294] systemd[1]: Starting Set Up Additional Binary Formats...
[ 2.581358] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.583116] systemd[1]: Starting Load Kernel Modules...
[ 2.584050] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.584137] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 2.585031] systemd[1]: Starting Coldplug All udev Devices...
[ 2.586737] systemd[1]: Mounted Huge Pages File System.
[ 2.586854] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.586944] systemd[1]: Mounted Kernel Debug File System.
[ 2.587033] systemd[1]: Mounted Kernel Trace File System.
[ 2.587327] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.587645] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.587866] systemd[1]: Finished Load Kernel Module configfs.
[ 2.588149] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.588360] systemd[1]: Finished Load Kernel Module drm.
[ 2.588494] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 214 (systemd-binfmt)
[ 2.589292] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 2.590140] systemd[1]: Mounting Kernel Configuration File System...
[ 2.591632] acpi_call: loading out-of-tree module taints kernel.
[ 2.591645] acpi_call: module verification failed: signature and/or required key missing - tainting kernel
[ 2.592255] EXT4-fs (nvme0n1p4): re-mounted. Opts: (null)
[ 2.593748] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.593893] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 2.594664] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 2.595422] systemd[1]: Starting Load/Save Random Seed...
[ 2.595490] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 2.595903] fuse: init (API version 7.32)
[ 2.596349] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.596950] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 2.597242] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.597396] systemd[1]: Finished Load Kernel Module fuse.
[ 2.597552] systemd[1]: Mounted Kernel Configuration File System.
[ 2.598426] systemd[1]: Mounting FUSE Control File System...
[ 2.598811] systemd[1]: Finished Set Up Additional Binary Formats.
[ 2.601177] systemd[1]: Mounted FUSE Control File System.
[ 2.614334] vboxdrv: Found 4 processor cores
[ 2.615321] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 2.621585] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.621680] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.621717] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 2.621736] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[ 2.623259] systemd[1]: Starting Journal Service...
[ 2.624642] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.636324] vboxdrv: TSC mode is Invariant, tentative frequency 3791982260 Hz
[ 2.636325] vboxdrv: Successfully loaded version 6.1.30 r148432 (interface 0x00320000)
[ 2.637778] VBoxNetAdp: Successfully started.
[ 2.639931] VBoxNetFlt: Successfully started.
[ 2.646779] Linux agpgart interface v0.103
[ 2.663074] systemd[1]: Finished Coldplug All udev Devices.
[ 2.663120] audit: type=1130 audit(1641133680.468:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.666203] usb 1-8: new high-speed USB device number 3 using xhci_hcd
[ 2.676571] systemd[1]: Started Journal Service.
[ 2.677975] audit: type=1130 audit(1641133680.482:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.681757] systemd-journald[226]: Received client request to flush runtime journal.
[ 2.693622] audit: type=1130 audit(1641133680.498:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.759968] audit: type=1130 audit(1641133680.565:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.809828] EDAC ie31200: No ECC support
[ 2.809858] EDAC ie31200: No ECC support
[ 2.821692] usb 1-8: New USB device found, idVendor=5986, idProduct=9102, bcdDevice= 6.01
[ 2.821695] usb 1-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.821696] usb 1-8: Product: BisonCam,NB Pro
[ 2.821697] usb 1-8: Manufacturer: Sonix Technology Co., Ltd.
[ 2.874258] input: Intel HID events as /devices/platform/INT33D5:00/input/input9
[ 2.912117] nvidia: module license 'NVIDIA' taints kernel.
[ 2.912119] Disabling lock debugging due to kernel taint
[ 2.946198] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[ 2.956673] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 2.964174] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.969946] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.972126] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 2.972828] nvidia 0000:01:00.0: enabling device (0106 -> 0107)
[ 2.972940] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.017458] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.44 Fri Oct 22 06:13:12 UTC 2021
[ 3.060122] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.060125] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.060126] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.060128] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 3.060365] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 3.067442] Intel(R) Wireless WiFi driver for Linux
[ 3.072088] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 3.072091] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 3.072092] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 3.072093] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 3.072094] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 3.072096] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 3.072097] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 3.072098] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 3.072099] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 3.072100] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 3.072101] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 3.072102] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 3.072103] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 3.072104] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 3.072105] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 3.072106] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 3.072108] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 3.072407] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 3.090423] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.090426] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.256529] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.44 Fri Oct 22 06:05:22 UTC 2021
[ 3.264519] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x318
[ 3.270452] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 3.304479] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 3.310048] Setting dangerous option enable_fbc - tainting kernel
[ 3.312022] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.312025] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 3.312542] checking generic (80000000 7f0000) vs hw (d2000000 1000000)
[ 3.312544] checking generic (80000000 7f0000) vs hw (80000000 40000000)
[ 3.312545] fb0: switching to inteldrmfb from EFI VGA
[ 3.312584] iwlwifi 0000:00:14.3: base HW address: 04:ed:33:2d:74:8b
[ 3.312693] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.313606] nvidia-uvm: Loaded the UVM driver, major device number 510.
[ 3.314369] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 3.314861] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 3.322316] audit: type=1130 audit(1641133681.125:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.331195] audit: type=1130 audit(1641133681.135:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.355694] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.355965] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 3.378568] Adding 16881660k swap on /dev/nvme0n1p3. Priority:-2 extents:1 across:16881660k SSFS
[ 3.386063] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 3.386120] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 3.387861] i2c i2c-4: 2/2 memory slots populated (from DMI)
[ 3.388718] i2c i2c-4: Successfully instantiated SPD at 0x50
[ 3.398809] audit: type=1130 audit(1641133681.202:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-745C\x2d3287 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.426202] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 3.445205] libphy: r8169: probed
[ 3.445362] r8169 0000:03:00.1 eth0: RTL8411b, 80:fa:5b:73:1f:22, XID 5c8, IRQ 147
[ 3.445363] r8169 0000:03:00.1 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 3.450337] intel-spi 0000:00:1f.5: w25q128 (16384 Kbytes)
[ 3.451942] input: PC Speaker as /devices/platform/pcspkr/input/input10
[ 3.455316] Creating 1 MTD partitions on "0000:00:1f.5":
[ 3.455319] 0x000000000000-0x000001000000 : "BIOS"
[ 3.520060] audit: type=1130 audit(1641133681.325:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.521587] audit: type=1334 audit(1641133681.325:10): prog-id=9 op=LOAD
[ 3.680714] urandom_read: 1 callbacks suppressed
[ 3.680715] random: avahi-daemon: uninitialized urandom read (4 bytes read)
[ 3.682065] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 3.682176] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 3.682177] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.682178] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.682179] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.682179] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.682180] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.711501] cryptd: max_cpu_qlen set to 1000
[ 3.716001] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 3.717084] random: polkitd: uninitialized urandom read (8 bytes read)
[ 3.805763] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 3.937396] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 4.054946] iTCO_vendor_support: vendor-support=0
[ 4.055396] ee1004 4-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 4.058311] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 4.058350] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 4.059371] NET: Registered protocol family 42
[ 4.059711] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.179999] SSE version of gcm_enc/dec engaged.
[ 4.273379] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 4.400103] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.402892] random: crng init done
[ 4.402893] random: 3 urandom warning(s) missed due to ratelimiting
[ 4.533125] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 4.533583] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 4.533786] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input13
[ 4.535296] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.535507] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input14
[ 4.535704] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.540427] fbcon: i915drmfb (fb0) is primary device
[ 4.540428] fbcon: Deferring console take-over
[ 4.540431] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 4.541317] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 4.579543] Generic FE-GE Realtek PHY r8169-0-301:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-301:00, irq=IGNORE)
[ 4.781386] psmouse serio2: synaptics: queried max coordinates: x [..5674], y [..4764]
[ 4.785946] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.785948] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.785950] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 4.785950] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.785951] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.785952] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 4.785953] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 4.785954] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 4.866437] r8169 0000:03:00.1 enp3s0f1: Link is Down
[ 4.873729] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1C4F:0034.0001/input/input18
[ 4.873804] hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:14.0-5/input0
[ 4.873843] usbcore: registered new interface driver usbhid
[ 4.873844] usbhid: USB HID core driver
[ 4.878151] Bluetooth: Core ver 2.22
[ 4.878169] NET: Registered protocol family 31
[ 4.878170] Bluetooth: HCI device and connection manager initialized
[ 4.878172] Bluetooth: HCI socket layer initialized
[ 4.878174] Bluetooth: L2CAP socket layer initialized
[ 4.878177] Bluetooth: SCO socket layer initialized
[ 4.883633] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 4.883677] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 4.883727] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 4.883784] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 4.883830] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 4.883882] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 4.883925] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 4.883969] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 4.896681] mousedev: PS/2 mouse device common for all mice
[ 4.896994] psmouse serio2: synaptics: queried min coordinates: x [1266..], y [1086..]
[ 4.896999] psmouse serio2: synaptics: Your touchpad (PNP: SYN1222 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 4.982600] usbcore: registered new interface driver btusb
[ 4.984213] mc: Linux media interface: v0.10
[ 4.984233] Bluetooth: hci0: Firmware revision 0.1 build 207 week 35 2021
[ 5.330879] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=io+mem
[ 5.333379] kauditd_printk_skb: 47 callbacks suppressed
[ 5.333380] audit: type=1106 audit(1641133683.138:58): pid=595 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.333868] audit: type=1104 audit(1641133683.138:59): pid=595 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 5.335989] intel_rapl_common: Found RAPL domain package
[ 5.335991] intel_rapl_common: Found RAPL domain core
[ 5.335992] intel_rapl_common: Found RAPL domain uncore
[ 5.335993] intel_rapl_common: Found RAPL domain dram
[ 5.335994] intel_rapl_common: Found RAPL domain psys
[ 5.338024] audit: type=1130 audit(1641133683.138:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rc-local comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.345210] videodev: Linux video capture interface: v2.00
[ 5.346653] audit: type=1130 audit(1641133683.148:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.373264] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.373266] Bluetooth: BNEP filters: protocol multicast
[ 5.373269] Bluetooth: BNEP socket layer initialized
[ 5.388114] audit: type=1130 audit(1641133683.192:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.396229] NET: Registered protocol family 38
[ 5.412585] psmouse serio2: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2b1, caps: 0xf00223/0x840300/0x26800/0x0, board id: 3189, fw id: 2302754
[ 5.449714] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input12
[ 5.503880] uvcvideo: Found UVC 1.00 device BisonCam,NB Pro (5986:9102)
[ 5.510455] input: BisonCam,NB Pro: BisonCam,NB Pr as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input26
[ 5.510505] usbcore: registered new interface driver uvcvideo
[ 5.510506] USB Video Class driver (1.1.1)
[ 5.669344] audit: type=1130 audit(1641133683.472:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.150387] audit: type=1100 audit(1641133683.955:64): pid=757 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="tol" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.151349] audit: type=1101 audit(1641133683.955:65): pid=757 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tol" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.151557] audit: type=1103 audit(1641133683.955:66): pid=757 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tol" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.151629] audit: type=1006 audit(1641133683.955:67): pid=757 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 7.944655] Bluetooth: RFCOMM TTY layer initialized
[ 7.944660] Bluetooth: RFCOMM socket layer initialized
[ 7.944665] Bluetooth: RFCOMM ver 1.11
[ 14.016156] kauditd_printk_skb: 15 callbacks suppressed
[ 14.016160] audit: type=1131 audit(1641133691.818:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.411157] audit: type=1131 audit(1641133713.215:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.526908] audit: type=1334 audit(1641133713.335:85): prog-id=15 op=UNLOAD
[ 35.526913] audit: type=1334 audit(1641133713.335:86): prog-id=14 op=UNLOAD
[ 35.526915] audit: type=1334 audit(1641133713.335:87): prog-id=13 op=UNLOAD
[ 63.186074] audit: type=1100 audit(1641133740.988:88): pid=1204 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tol" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 63.187025] audit: type=1101 audit(1641133740.992:89): pid=1204 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tol" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 63.187578] audit: type=1110 audit(1641133740.992:90): pid=1204 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 63.189236] audit: type=1105 audit(1641133740.992:91): pid=1204 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
There’s nothing unusual on the ACPI logs for both kernel version 4 and 5.
Have you tried removing from the /etc/rc.d/rc.local:
sudo modprobe nvidia “NVreg_DynamicPowerManagement=0x02”
sudo echo on > /sys/bus/pci/devices/0000:01:00.0/power/control
sudo echo ‘_SB.PCI0.PEG0.PEGP._OFF’ > /proc/acpi/call
sudo echo -n 1 > ‘/sys/bus/pci/devices/0000:01:00.0/remove’
during your use with kernel 5 and see if your system works without erratic fan?
The only insight I have is that the kernel loads NVIDIA driver and disabling NVIDIA discrete graphics afterward may cause issue:
[ 3.670581] nvidia: module license 'NVIDIA' taints kernel.
[ 3.670583] Disabling lock debugging due to kernel taint
[ 3.686638] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[ 3.767327] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 3.770238] nvidia 0000:01:00.0: enabling device (0106 -> 0107)
[ 3.770325] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.781498] pci 0000:01:00.1: Dropping the link to 0000:01:00.0
[ 3.813070] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.44 Fri Oct 22 06:13:12 UTC 2021
[ 3.823718] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 3.837566] nvidia-uvm: Loaded the UVM driver, major device number 237.
[ 3.841231] audit: type=1130 audit(1641133466.069:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.847664] audit: type=1130 audit(1641133466.079:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.867574] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.867576] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.970840] random: crng init done
[ 3.974844] audit: type=1130 audit(1641133466.199:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4.030643] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.056654] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.44 Fri Oct 22 06:05:22 UTC 2021
[ 4.058830] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.058831] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
Also check your mhwd -li. Based on your system, I suspect the driver used is either video-nvidia or video-hybrid-xxx.
Well, I ran tests with and without Nvidia disabling lines in rc.local. The result is quite surprising:
Kernel 4 with lines: 12-15 Watt (sometimes 8 Watt).
Kernel 4 without lines: 30 Watt.
Kernel 5 with lines: 30 Watt.
Kernel 5 without lines: 19 Watt.
So the positive results are kind of change places after changing the kernel version. However, kernel 4 with lines is still 5 Watts lower than kernel 5 without lines. What’s more surprising is that when I unplug the AC cable, the power consumption drops to 0.6 Watt!!! I think Nvidia card turns off completely at this moment. I wonder if it’s ever possible to get this result with the AC cable. I feel that nvidia driver is too blame, it doesn’t turn off the video card completely and doesn’t put it to power-saving mode by default. This ACPI call in rc.local is required to put it to power-saving mode, this is why nvidia driver is used instead of free driver, at least it worked before. Maybe they changed something for kernel 5 that makes it work different now. But as far as I know, free drivers don’t provide ANY possibility to disable nvidia or put it to power-savings mode.
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-nvidia 2021.12.18 false PCI
Do you know why kernel 4 cannot copy files and what Errno 18 is? I tried to search it but found only few pages that mention this error and they don’t seem to help much.
It’s already a de facto standard for OSes, that using AC power will default the system to be in a state with higher performance and higher power consumption than with battery (typical design trade-off). Discrete graphics already support power state on its own and it’s the kernel job how to properly set the power state of the discrete graphics.
From here, it seems that kernel version 4 doesn’t handle well with NVIDIA driver 495.xx or 470.xx; in your case, it’s power management on discrete graphics is at a terrible 30 Watt. As if kernel 4 doesn’t properly manage the discrete graphics power state. Kernel 5 is the latest and should support well with the latest NVIDIA driver 495.xx and 470.xx. I say 19 Watt is still normal for a notebook. And I’m quite surprised that using battery (no AC power) reduces the power consumption to 0.6 Watt (almost the same as mobile phone on normal performance).
For me, it’s still normal since your case with kernel 5 used NVIDIA discrete graphics while the kernel 4 didn’t.
Errno 18 has something to do with UNIX / Linux system programming C programming language API as defined in the POSIX or SuS standard. Most of these APIs are a system call, and most GNU/Linux terminal commands make use of these APIs, like cp, mv, rm just to name a few.
It’s an error returned from the kernel system call which means “Invalid cross-device link”; roughly means the current operation between 2 different device isn’t allowed. In your case, this is copying from internal drive to external drive. It’s still odd though that kernel 4 return this error just for copying between drives. Maybe the respective system call is fixed in kernel 5, that’s why you can perform this opereation on kernel 5. Idk, it’s just weird.
Overall, kernel 5 seems problematic when you disable NVIDIA graphics. I can only suspect the NVIDIA driver keeps trying communicating with a ghost NVIDIA discrete graphics that you have disabled. And somehow this cause higher power consumption.
See the temperature of pch (chipset) on kernel 5, it’s too high, but CPU temperature is normal:
Chipset is the bridge of communication between CPU and others like GPU. So maybe it’s really the NVIDIA driver keeps trying to communicate with the GPU. Idk.
My advice:
- Keep using kernel 5. Your problem with errno18 is the limitation of kernel 4, Idk. But kernel 5 has many features improvements and bug fixes, so it’s much better to use this latest version.
- Keep the NVIDIA on, but install the hybrid driver if you still not satisfied with the current power consumption. The name is like video-hybrid-intel-nvidia-prime or video-hybrid-intel-nvidia-prime-bumblebee something via
mhwd. This driver will use Intel integrated graphics by default and will use NVIDIA when there’s a need for more graphics performance. The driver you’re using now is always NVIDIA.
For reference:
It feels that I have to use kernel5 because I need to copy files
I may want to switch to kernel 4 when I need to keep the notebook running all night, for example, for video rendering, otherwise it will be too loud on kernel 5. Initially kernel 4 could copy files to USB devices without problems, and this error seems to appear after some update, I don’t know, because I used kernel 5 only recently. Maybe clean reinstalling manjaro will fix it but I don’t have much time for it now. These rolling updates is quite a weird thing and it may brick the system. I have another notebook in different location that I use rarely, I updated it last time in April 2021, and in 31-Dec-2021 I came to that place and decided to update it and after a successful update I just couldn’t log in anymore. I could login in command line but not in GUI. I found the same post of another user and the best suggestion was to reinstall Manjaro completely, and I did the same. So you never know what these updates may result in…
My notebook has a connected heat removal system - GPU is connected with CPU by means of 2 thick copper wires that are connected to 2 fans, and when the GPU is on, it adds some heat to CPU as well, because the GPU fan turns on at 60 degrees celsius or so, and when the GPU temperature is lower than that, the heat from it goes to CPU and then to the CPU fan. It’s probably stupid, but this is how it works. So when the GPU is not used, it turns completely off, there is no heat from it, the CPU doesn’t get excessive heat and all fans are stopped, the notebook is completely quiet. When there is little load, only the CPU fan is used, and at high load both CPU and GPU fans are used. At least this is how it works in Windows. But in Linux CPU fan is on almost all the time. I hope Linux driver will work the same way like in Windows some day, but now it doesn’t.
I tried hybrid drivers a year ago, Linux just hung up with these drivers when loading no matter what I tried. Maybe something changed since that time, I will try it again later.
Anyway, thanks for your suggestions, 19W on kernel 5 is still better and more quiet than 30W ![]()
