Hi!
I noticed high power consumption on my laptops with AMD Ryzen 3500U and 2500U CPU after kernel upgrade to 5.8.x, 5.9.x, 5.10.2. The last good working kernel is 5.7.19.
Battery powered, all Tunables in powertop set to Good, the same screen brightness, fan off:
- kernel 5.7.19: ~3.9W
- kernel 5.10.2: ~5.5W
Increased power consumption is visible also on AC powered on wattmeter.
sensors output shows:
- kernel 5.7.19: Vsoc 800 mV , Isoc 2.00 A
- kernel 5.10.2: Vsoc 1.04 V , Isoc 5.00 A
Vcore and Icore are similar in both kernels.
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=6117344d-bbf4-4fbd-9695-69be3c50f3fb rw apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1 idle=nomwait
rcu_nocbs=0-7 iommu=soft
Desktop: MATE 1.24.1 info: mate-panel wm: Openbox 3.6.1 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: HUAWEI product: NBLK-WAX9X v: M1010 serial: <filter>
Mobo: HUAWEI model: NBLK-WAX9X-PCB v: M1010 serial: <filter> UEFI: HUAWEI
v: 1.07 date: 06/02/2020
ID-1: BAT1 charge: 55.2 Wh condition: 55.9/55.3 Wh (101%) volts: 17.2/15.3
model: Sunwoda-H HB4692Z9ECW-41 type: Li-ion serial: <filter>
status: Discharging cycles: 106
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 2 MiB
bogomips: 33548
Speed: 1365 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1365 2: 1222 3: 1269 4: 1381 5: 1244 6: 1306 7: 1256 8: 1396
disabled, RSB filling
Device-1: AMD Picasso vendor: Huawei driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15d8
Device-2: IMC Networks ov9734_azurewave_camera type: USB driver: N/A
bus ID: 1-4:2 chip ID: 13d3:56db serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.2-2-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.3.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Huawei
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 2000 bus ID: 02:00.0 chip ID: 10ec:c822
Local Storage: total: 476.94 GiB used: 50.72 GiB (10.6%)
model: PC SN730 SDBPNTY-512G-1027 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 11110000 temp: 30.9 C
ID-1: / raw size: 238.41 GiB size: 235.01 GiB (98.57%)
used: 50.68 GiB (21.6%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 116 MiB size: 96 MiB (82.76%)
used: 47.2 MiB (49.2%) fs: vfat block size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) priority: -2
file: /var/swap
System Temperatures: cpu: 35.2 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 251 Uptime: 1m wakeups: 1 Memory: 6.72 GiB
used: 921.3 MiB (13.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1466 lib: 442 Shell: Bash v: 5.1.0
running in: mate-terminal inxi: 3.2.01
Is it possible to fix it, or I have to use kernel 5.7.19? Thanks!
