Hello. I have weird problem and I don’t know how to debug or find what is the problem. Every time I copy some files or downloading multiple files from cloud or some program is doing something with disk, my system is tanked and load jumps to 10+ up to 40. It’s nvme disk so why is this happening? Is my disk failing? Thanks for suggestions/explanation.
Summary
$ inxi --full --admin --filter --width
Kernel: 6.6.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=75b4a339-3527-4ddf-a52a-6c47b44e6130 rw
cryptdevice=UUID=aa016456-ecb8-4596-89b8-1ca0be5e009e:luks-aa016456-ecb8-4596-89b8-1ca0be5e009e
root=/dev/mapper/luks-aa016456-ecb8-4596-89b8-1ca0be5e009e
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81B0 v: Lenovo V330-14IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo V330-14IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: 6UCN54WW(V4.09) date: 11/23/2018
ID-1: BAT1 charge: 20.4 Wh (96.7%) condition: 21.1/30.0 Wh (70.5%)
power: 2.9 W volts: 8.6 min: 7.5 model: 0x53 0x4D 0x50 0x00 0x31 0x42 0x4C
0x31 0x37 0x4D 0x32 0x50 0x42 type: Li-ion serial: <filter>
status: charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 749 high: 800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 799 2: 800 3: 800 4: 800
5: 799 6: 800 7: 800 8: 400 bogomips: 28808
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x06bb built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.3-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Lenovo driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:3166 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0a2a
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 238.47 GiB used: 167.58 GiB (70.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS256GD9TNG-62A0A size: 238.47 GiB block-size: physical: 512 B
fw-rev: 80001E00 temp: 55.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 167.57 GiB (74.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-aa016456-ecb8-4596-89b8-1ca0be5e009e
used: 408 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 45.0 C pch: 43.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 242 Uptime: 11m wakeups: 0 Memory: total: 20 GiB note: est.
available: 19.28 GiB used: 1.46 GiB (7.6%) Init: systemd v: 254
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2229 libs: 567
tools: pacaur,pamac,yay pm: flatpak pkgs: 0 Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
$ sudo smartctl -a /dev/nvme0
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.3-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: HFS256GD9TNG-62A0A
Serial Number: EJ84N698211504P3G
Firmware Version: 80001E00
PCI Vendor/Subsystem ID: 0x1c5c
IEEE OUI Identifier: 0xace42e
Controller ID: 1
NVMe Version: 1.2
Number of Namespaces: 1
Namespace 1 Size/Capacity: 256 060 514 304 [256 GB]
Namespace 1 Utilization: 255 810 449 408 [255 GB]
Namespace 1 Formatted LBA Size: 512
Local Time is: Wed Dec 6 00:44:21 2023 CET
Firmware Updates (0x14): 2 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x001f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x02): Cmd_Eff_Lg
Maximum Data Transfer Size: 32 Pages
Warning Comp. Temp. Threshold: 79 Celsius
Critical Comp. Temp. Threshold: 81 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 6.00W - - 0 0 0 0 5 5
1 + 3.80W - - 1 1 1 1 30 30
2 + 2.40W - - 2 2 2 2 100 100
3 - 0.0700W - - 3 3 3 3 1000 1000
4 - 0.0070W - - 3 3 3 3 1000 5000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
1 - 4096 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 35 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 12%
Data Units Read: 17 335 375 [8,87 TB]
Data Units Written: 18 222 274 [9,32 TB]
Host Read Commands: 123 901 075
Host Write Commands: 68 745 221
Controller Busy Time: 19 074
Power Cycles: 2 135
Power On Hours: 1 087
Unsafe Shutdowns: 61
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 35 Celsius
Temperature Sensor 2: 37 Celsius
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
Self-test Log (NVMe Log 0x06)
Self-test status: No self-test in progress
Num Test_Description Status Power_on_Hours Failing_LBA NSID Seg SCT Code
0 Short Completed without error 1087 - - - - -
