So im using manjaro 21.0.2 kde on my kingston ssd 120gb , i just noticed in system monitor that disk usage is at 54% is it normal? or theres something working in the background?
ystem:
Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.21.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H97-PRO GAMER v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2503 date: 02/26/2016
Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L2: 8 MiB
bogomips: 57629
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 1678
3: 1249 4: 826 5: 1159 6: 932 7: 2431 8: 2478
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel
bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting resolution: 1920x1080
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.11.14-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
bus-ID: 3-13.1:6
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.25 running: yes
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
bus-ID: 00:1f.2
Device-1: md126 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 488391680 chunk-size: 128k
Components: Online: 0: sdb 1: sda
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 5488 chunk-size: N/A
Components: Online: N/A Spare: 0: sda 1: sdb
Local Storage: total: 1.47 TiB used: 562.23 GiB (37.3%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-08WN4A0
ID-4: /dev/sdd vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-1: / size: 109.18 GiB used: 9.91 GiB (9.1%) fs: ext4 dev: /dev/sdd2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sdd1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 997
Processes: 242 Uptime: 3h 28m Memory: 23.43 GiB used: 1.92 GiB (8.2%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1204 Shell: Bash
v: 5.1.0 inxi: 3.3.04
