Howdy, @BG405 - thanks for the note!
Full output of inxi -zv8 is below-
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=5f3b7b80-596b-4e48-9294-ddf631a074a2 rw apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS v: Rev 1.xx
UEFI: American Megatrends v: 1017 date: 07/12/2021
System RAM: total: 32 GiB available: 31.18 GiB used: 6.37 GiB (20.4%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: spec: 2667 MT/s actual: 3600 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Crucial Technology part-no: BL8G36C16U4BL.M8FE1
serial: <filter>
Device-2: Controller0-ChannelA-DIMM1 type: DDR4 detail: synchronous
serial: <filter>
Device-3: Controller0-ChannelB-DIMM0 type: DDR4 detail: synchronous
serial: <filter>
Device-4: Controller0-ChannelB-DIMM1 type: DDR4 detail: synchronous
serial: <filter>
Info: model: 11th Gen Intel Core i7-11700KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x62
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4700 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4700 2: 4700 3: 4700
4: 4700 5: 4700 6: 4700 7: 4700 8: 4700 9: 4700 10: 4700 11: 4700 12: 4700
13: 4700 14: 4700 15: 4700 16: 4700 bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
erms est f16c flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vpclmulqdq x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu
unloaded: modesetting,radeon,vesa alternate: fbdev dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Acer ED347CKR
serial: <filter> built: 2017 res: mode: 3440x1440 hz: 100 scale: 100% (1)
dpi: 110 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.200
y: 0.690 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
size: 795x334mm (31.3x13.15") diag: 869mm (34.2") modes: 3440x1440,
2560x1080, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:744c
memory: 19.53 GiB unified: no
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xdriinfo,
xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7+
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 1038:220e class-ID: 0300
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Local Storage: total: 7.28 TiB used: 1.57 TiB (21.6%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Smart Modular Tech.
model: SHGP31-2000GM size: 1.82 TiB block-size: physical: 512 B
fw-rev: 31060C20 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 614300WD temp: 48.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Smart Modular Tech.
fw-rev: 31060C20 temp: 37.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Smart Modular Tech.
model: SHGS31-1000GS-2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0Q00
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 528.18 GiB (57.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 5f3b7b80-596b-4e48-9294-ddf631a074a2
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 27F6-3339
ID-3: /mnt/Aragorn raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 543.61 GiB (29.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:7
label: Aragorn uuid: 38dd73c8-7534-420a-8415-dc8eac44bb36
ID-4: /mnt/Boromir raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 219.18 GiB (12.0%) fs: ext4 dev: /dev/nvme2n1p1 maj-min: 259:8
label: Boromir uuid: 20896da6-3d4a-4aaf-9e9f-7e5485246e19
ID-5: /mnt/Gandalf raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 320.04 GiB (17.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Gandalf
uuid: 5722fb59-6815-4cb5-8fcb-87f0749c03ad
ID-1: swap-1 type: file size: 8 GiB used: 256 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 389A-4EC6
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs label: Sauron
uuid: 60E69D1FE69CF70E
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 881EE30D1EE2F35C
Device-1: 1-1:2 info: SteelSeries ApS Arctis 7+ type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-6.1:5 info: NZXT USB Device type: HID
driver: nzxt_kraken3,usbhid interfaces: 1 rev: 2.0
chip-ID: 1e71:2007 class-ID: 0300 serial: <filter>
Hub-3: 1-7:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-7.1:7 info: Evision Gaming Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:507a class-ID: 0301
Device-2: 1-7.2:9 info: pulsar Xlite V3 type: keyboard,HID,mouse
lanes: 1 mode: 1.1 power: 98mA chip-ID: 3554:f508 class-ID: 0301
Device-3: 1-11:6 info: Microsoft Xbox Wireless Adapter for Windows
type: WiFi driver: xone-dongle interfaces: 1 rev: 2.0
Device-4: 1-13:8 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-5: 2-6:2 info: Realtek Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
mem: 60.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1410 libs: 461 tools: pamac,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
7: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
11: http://mirror.fcix.net/manjaro/stable/$repo/$arch
12: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
13: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
16: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
19: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://muug.ca/mirror/manjaro/stable/$repo/$arch
21: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
22: https://manjaro.kurdy.org/stable/$repo/$arch
23: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
24: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
25: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
28: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
29: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
30: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
31: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
32: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
33: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
35: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
36: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://mirror.init7.net/manjaro/stable/$repo/$arch
38: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
39: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
40: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
41: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
42: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
43: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
44: https://linorg.usp.br/manjaro/stable/$repo/$arch
45: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
46: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
47: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://manjaro.ynh.ovh/stable/$repo/$arch
49: https://mirror.koddos.net/manjaro/stable/$repo/$arch
50: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
51: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
52: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
53: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
54: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
55: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
56: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
57: https://mirror.easyname.at/manjaro/stable/$repo/$arch
58: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
59: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
60: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
61: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
62: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
63: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
64: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
65: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
66: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
67: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
68: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
69: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
70: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
71: https://mirror.zetup.net/manjaro/stable/$repo/$arch
72: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
73: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
74: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
75: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
76: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
77: http://manjaro.grena.ge/stable/$repo/$arch
78: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
79: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
80: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
81: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
82: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
83: https://mirror.23m.com/manjaro/stable/$repo/$arch
84: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
85: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
86: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
87: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
88: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
89: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
90: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
91: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
92: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
93: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
94: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
95: https://mirror.dc.uz/manjaro/stable/$repo/$arch
96: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
97: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
98: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
99: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
100: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
101: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
102: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
103: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
104: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
105: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
106: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
107: http://manjaro.mirror.ac.za/stable/$repo/$arch
108: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
109: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
110: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
111: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
112: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
113: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
114: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
115: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
116: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 364
1: cpu: 7.5% command: firefox pid: 31837 mem: 798.3 MiB (2.5%)
2: cpu: 6.1% command: firefox pid: 33923 mem: 255.2 MiB (0.7%)
3: cpu: 4.1% command: steam pid: 21787 mem: 363.1 MiB (1.1%)
4: cpu: 3.1% command: firefox pid: 33836 mem: 272.4 MiB (0.8%)
5: cpu: 1.9% command: Discord pid: 14034 mem: 455.8 MiB (1.4%)
Memory top: 5 of 364
1: mem: 798.3 MiB (2.5%) command: firefox pid: 31837 cpu: 7.5%
2: mem: 512.2 MiB (1.6%) command: ./steamwebhelper pid: 22048 cpu: 0.5%
3: mem: 503.0 MiB (1.5%) command: WebKitWebProcess pid: 1552 cpu: 1.6%
4: mem: 466.8 MiB (1.4%) command: steamwebhelper pid: 22142 cpu: 1.3%
5: mem: 455.8 MiB (1.4%) command: Discord pid: 14034 cpu: 1.9%
Processes: 364 Power: uptime: 4h 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 256
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
