Hello, I’m satisfied with Manjaro. Basically I got no problem but after I try gaming I got freezes over and over again no matter what kind of game is new/old.
Monitoring Result
I tried install recomended Kernel but CPU is getting high and high…
IDK if its ok but Swap got 0…
System Info
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=1e481acc-b0ec-4a3c-9b45-819e41715870 rw quiet apparmor=1
security=apparmor resume=UUID=128ff269-2717-44d9-ab16-25225fa22443
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
dm: SDDM Distro: Manjaro Linux base: Arch Linux -
Type: Desktop Mobo: ASUSTeK model: H61M-K v: Rev X.0x serial:
BIOS: American Megatrends v: 0801 date: 07/21/2014 -
Info: Quad Core model: Intel Core i5-2500 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26350
Speed: 1810 MHz min/max: 1600/3700 MHz Core speeds (MHz): 1: 1810 2: 1799
3: 1721 4: 1729
Type: l1tf
Type: tsx_async_abort status: Not affected -
Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:0fc6 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 103 s-size: 473x261mm (18.6x10.3")
s-diag: 540mm (21.3")
Monitor-1: VGA-0 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 650/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes -
Local Storage: total: 465.76 GiB used: 82.29 GiB (17.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD502HJ size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 7200 serial: rev: 00E4 scheme: MBR
Maybe I have to set High Performance in Batery but IDK how to do this…
Sorry for my bad English.
