Hello Manjaro community,
I’ve encountered an issue on my Manjaro Linux system where a process with a constantly changing PID is causing high CPU usage at constant intervals. After some investigation, I’ve observed that the process runs the command:
/usr/bin/ps ax -weo pid,rssipmem,vsize,uname:50,pcpu,start_time,state,groupinice,cputime,session,cmd --no-headings
This process consumes 100% CPU at times and then disappears, only to respawn with a different PID later withing seconds. This behavior has been quite disruptive to my system’s performance.
Note: The process does not show up on “top” or “htop” it only shows up while looking through “Stacer”
I’ve tried running a backtrace using gdb, but since the PID keeps changing, it’s challenging to pinpoint the root cause of the issue.
Here’s what I’ve tried so far:
- Using pgrep to dynamically identify the PID of the process.
- Running gdb with the identified PID to gather a backtrace.
However, I haven’t been successful in identifying the cause of this mysterious process.
I would greatly appreciate any insights or suggestions from the community on how to further diagnose and resolve this issue or how I can reduce my CPU usage overall. Additionally, if anyone has encountered a similar problem or has any tips on debugging high CPU usage caused by processes with changing PIDs, please share your experiences.
Thank you in advance for your help!
System Information:
- Operating System: Manjaro Linux x86_64
- Kernel: 6.6.19-1-MANJARO
- Desktop Environment: Xfce 4.18
- CPU: Intel i3-2120 (4) @ 3.300GHz
- GPU: NVIDIA GeForce 8400 GS Rev. 2
