Hello,
During charging on Manjaro KDE, the CPU temperature reaches ~77C.
The reason seems to be the CPU load that is higher than usual (normally it stays at the minimum 1.20 GHz in idle with the conservative governor).
$ sudo cpupower frequency-info && cat /proc/cpuinfo | grep "MHz"
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 1.20 GHz - 4.46 GHz
available frequency steps: 3.20 GHz, 1.30 GHz, 1.20 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 1.20 GHz and 3.20 GHz.
The governor "conservative" may decide which speed to use
within this range.
current CPU frequency: 1.20 GHz (asserted by call to hardware)
boost state support:
Supported: yes
Active: yes
Boost States: 0
Total States: 3
Pstate-P0: 3200MHz
Pstate-P1: 1300MHz
Pstate-P2: 1200MHz
cpu MHz : 2814.759
cpu MHz : 2930.085
cpu MHz : 2988.454
cpu MHz : 3966.650
cpu MHz : 3651.625
cpu MHz : 4170.143
cpu MHz : 2488.129
cpu MHz : 3335.907
cpu MHz : 3227.493
cpu MHz : 3164.581
cpu MHz : 3247.575
cpu MHz : 3350.503
cpu MHz : 3348.081
cpu MHz : 3072.870
cpu MHz : 3233.953
cpu MHz : 3336.623
Running top, I see this command/process with high CPU usage:
irq/79-ACPI:Eve
What is this and why itās using the CPU so much?
The temperature drops to ~60C when the battery reaches 90% charge and that process is gone when itās fully charged.
Also, as a side question, why does cpupower report 1.20 GHz frequency while /proc/cpuinfo shows above 3 GHz?
System info:
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2c7eabfe-e72e-4af0-88fc-ee6f581a53cd rw quiet udev.log_priority=3
nowatchdog resume=/dev/disk/by-uuid/2c7eabfe-e72e-4af0-88fc-ee6f581a53cd
resume_offset=1413120
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TIMI product: RedmiBook Pro 15S v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: TIMI model: TM2019 v: V44B2 serial: <filter> UEFI: TIMI
v: RMACZ5B0P0303 date: 03/26/2021
ID-1: BATT charge: 71.7 Wh (100.0%) condition: 71.7/70.0 Wh (102.4%)
volts: 15.4 min: 15.4 model: SCUD R15B02W type: Li-ion serial: <filter>
status: Full cycles: -1
RAM: total: 15.05 GiB used: 3.23 GiB (21.4%)
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB bogomips: 102243
Speed: 1135 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
1: 1135 2: 1141 3: 1297 4: 1296 5: 1135 6: 1134 7: 1297 8: 1296 9: 1135
10: 1133 11: 1135 12: 1134 13: 1135 14: 1135 15: 1135 16: 1135
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Xiaomi driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
type: USB driver: N/A bus-ID: 1-3:2 chip-ID: 05c8:03ec class-ID: 0e02
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x2000 s-dpi: 192 s-size: 423x264mm (16.7x10.4")
s-diag: 499mm (19.6")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.59-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: AMD vendor: Xiaomi driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Xiaomi
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Xiaomi driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: N/A bus-ID: 1-4:3
Local Storage: total: 476.94 GiB used: 29.59 GiB (6.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNV512G KIOXIA
lanes: 4 type: SSD serial: <filter> rev: AEXA0102 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 406.39 GiB size: 398.94 GiB (98.17%)
used: 29.57 GiB (7.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 2c7eabfe-e72e-4af0-88fc-ee6f581a53cd
ID-2: /boot/efi raw-size: 550 MiB size: 547.8 MiB (99.61%)
used: 25.4 MiB (4.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CE2B-6F80
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 17 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 70 GiB fs: ntfs label: N/A
uuid: 74AC585FAC581DC4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2
info: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
type: Video driver: N/A interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: N/A
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: FPC Sensor Controller type: <vendor specific>
driver: N/A interfaces: 2 rev: 1.1 speed: 480 Mb/s power: 100mA
chip-ID: 10a5:9200 class-ID: ef00 serial: <filter>
Device-2: 3-4:3 info: Xenta 2.4G Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1d57:fa60 class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Processes: 334 Uptime: 1h 20m wakeups: 3771 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1082 lib: 297
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
