I have a laptop running manjaro gnome and I’ve noticed that battery life while playing any sort of video tends to be abysmal. I’m talking about a drop of 20-30% in a little more than an hour in VLC and it tends to be even worse if I’m playing anything online from Youtube (I’ve enabled VA-API but the effects, if there are any, are negligible).
output of inxi:
Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=d7737d6c-758c-4ace-933d-05aad7acbdcb rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 mem_sleep_default=deep
resume=UUID=d7737d6c-758c-4ace-933d-05aad7acbdcb resume_offset=15343616
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1
Type: Laptop System: Dell product: XPS 13 9360 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0N0TW9 v: A02 serial: <filter> UEFI: Dell v: 2.14.2
date: 07/13/2020
ID-1: BAT0 charge: 51.1 Wh (85.2%) condition: 60.0/60.0 Wh (100.0%)
volts: 8.1 min: 7.6 model: SMP DELL TP1GT61 type: Li-poly serial: <filter>
status: Discharging
RAM: total: 7.66 GiB used: 2.51 GiB (32.7%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 6 MiB bogomips: 28808
Speed: 900 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 901 6: 901 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:670c class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :1
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel port: f040
bus-ID: 3a:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-3:2 chip-ID: 0cf3:e300 class-ID: e001
Message: No LVM data was found.
Local Storage: total: 232.89 GiB used: 117.7 GiB (50.5%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.94 GiB (98.00%)
used: 117.7 GiB (51.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d7737d6c-758c-4ace-933d-05aad7acbdcb
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A9BD-4512
ID-3: /run/timeshift/backup raw-size: 232.59 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: file size: 16 GiB used: 535.8 MiB (3.3%) priority: -2
file: /swapfile
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
Device-2: 1-5:3 info: Microdia Integrated Webcam HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 241 Uptime: 3d 20h 50m wakeups: 11 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1549 pacman: 1540 lib: 447
flatpak: 9 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.03
Any solutions?
