How can I hide or remove Grub background at shutdown? I’ve made some custom configuration and I am satisfied how it looks when system starts but I want to shutdown without background or any text and as fast as possible:
cat /etc/default/grub
GRUB_DEFAULT=0
GRUB_TIMEOUT=1
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=1280x1024x24,auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER=false
I am sure it is possible because I remember there was a topic about it on old Manjaro forum but I lost my notes.
