Hibernation problem
Hello everybody! I have some hibernation problems on my laptop. I’m using swapfile, and I think that problem with it. When I turn on the computer, it starts a fresh start. What could be the problem?
Here’s my inxi -Fxz:
  Kernel: 5.11.22-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: GNOME 40.3 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ZenBook UX434DA_UM433DA v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: UX434DA v: 1.0 serial: <filter>
  UEFI: American Megatrends v: UX434DA_UM433DA.307 date: 12/09/2020
  ID-1: BAT0 charge: 5.1 Wh (11.8%) condition: 43.3/50.0 Wh (86.5%)
  volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery status: Discharging
  Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen rev: 1 cache: L2: 2 MiB
  bogomips: 33550
  Speed: 1222 MHz max: 1400 MHz boost: enabled Core speeds (MHz): 1: 1222
  2: 1222 3: 1360 4: 1252 5: 1221 6: 1221 7: 1227 8: 1222
  Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus-ID: 03:00.0
  Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
  bus-ID: 3-2:3
  Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
  loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
  5.11.22-2-MANJARO LLVM 12.0.0)
  v: 4.6 Mesa 21.1.4 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  v: kernel bus-ID: 03:00.1
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  driver: snd_pci_acp3x v: kernel bus-ID: 03:00.5
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 03:00.6
  Sound Server-1: ALSA v: k5.11.22-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: no
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
  bus-ID: 01:00.0
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  v: 0.8 bus-ID: 1-4:2
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 238.47 GiB used: 58.78 GiB (24.6%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDJTNG-8310A
  size: 238.47 GiB temp: 38.9 C
  ID-1: / size: 233.38 GiB used: 58.78 GiB (25.2%) fs: ext4
  dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
  dev: /dev/nvme0n1p1
  ID-1: swap-1 type: file size: 12 GiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 54.4 C mobo: 54.0 C gpu: amdgpu temp: 54.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 293 Uptime: 5m Memory: 5.81 GiB used: 2.11 GiB (36.3%)
  Init: systemd Compilers: gcc: 11.1.0 Packages: 1319 Shell: Zsh v: 5.8
  inxi: 3.3.05
Swap info:
NAME      TYPE SIZE USED PRIO
/swapfile file  12G   0B  100
In my grub file I got this:
GRUB_CMDLINE_LINUX_DEFAULT="resume=088ef75f-4872-4f47-8e9d-ceb0144a7e82 resume_offset=17661952 quiet splash apparmor=1 security=apparmor udev.log_priority=3"
And this line in mkinitcpio.conf:
HOOKS="base udev resume autodetect modconf block keyboard keymap plymouth filesystems fsck"
Am I missing smth? Thanks in advance!
:arrow_down:
resume=UUID=088ef75f-4872-4f47-8e9d-ceb0144a7e82
Just tried it. But it won’t work because I am using a swapfile. It is also necessary, in addition to the UUID of the section, to indicate the offset, as I understand it.
yes add resume_offset but nothing change for resume : use resume=UUID= if you pass uuid partition
Kernel 5.11 is no longer supported, switch to another one, for example 5.10 LTS. After the change, update your system.
Have you considered all details of the wiki:
Power management/Suspend and hibernate - ArchWiki
resume should go after block if I remember it correctly. On my system it is right before the filesysmes btw.
Also make sure that 088ef75f-4872-4f47-8e9d-ceb0144a7e82 is the UUID of your root partition.
After editing mkinitcpio.conf do sudo mkinitcpio -P to regenerate initrds.
And re-read @megavolt’s message once again. It was meant to advise you that you missed UUID= part in GRUB_CMDLINE_LINUX_DEFAULT string when assigning value to resume parameter.
Yes, I got what u wanted to say! LMAO, I forgot to write UUID after resume!
