I am a noob. Ill go ahead and get that out there. Hibernation has not been working since I installed manjaro Kde Plasma Kernel 5.13.13 this past weekend. It is installed on a 500 Gb external SSD. I installed it using the swap file option.
Once it goes into Hibernation I just get a black screen when I open the computer or click any buttons. I’ve been reading up on some hibernation issues with others. I have noticed that my swapfile is under sized. I have 7.5 Gib of RAM.
grep SwapTotal /proc/meminfo
SwapTotal: 524284 kB
~ swapon
NAME TYPE SIZE USED PRIO
/swapfile file 512M 0B -2
I found the mistake. I had written
sudo dd if=/dev/zero of=/swafile bs=1M count=4096 status=progress → example (I changed count)
swafile instead of swapfile. I found the new file, removed and started over. I went by the recommended swapfile space for 8G RAM and now have 11G (based on the table provided by swap article on wiki manjaro) for swapfile. Maybe Hibernate will work now ??
